03-13-2018, 04:57 AM | #1 |
Rep 195
Audio Upgrade
Hi i have a f30 with the base audio i already have a sub in my boot but i want to Amp up the speakers in the doors as I'm going to upgrade them but not sure how to do it as i don't think such a harness exist to achieve what i want Help!!!!
03-13-2018, 05:42 AM | #2 |
Rep 775
Am sure you checked, but just in case .... www.technicpnp.com
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
03-13-2018, 04:58 PM | #3 | |
Rep 195
03-13-2018, 05:01 PM | #4 |
Rep 195
I'm currently leaning towards getting a 6ch amp to power my speakers individualy but I'm stuck as how I'm going to connect my sub in my boot as its currently tapped in to one of the front speakers i don't think it will be possible if i use this this harness so basically can i amp up all 6 speakers and a sub using this harness https://technicpnp.com/product/stereo-46-harness/ any input or help is very much appriciated
03-13-2018, 05:12 PM | #5 |
no relation
130
Rep 442
I would send inquiry to them and they should be able to answer all your questions. When I was looking at getting upgraded sound system, I asked them a bunch of questions and they were very helpful. Unfortunately, I didn't end up upgrading my sound system (I do have BavSound ghost underseat subs installed, but nothing crazy).
03-13-2018, 06:01 PM | #6 |
Rep 8,942
Bimmertech amp is plug and play replacement for stock. Very easy and high quality.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
03-14-2018, 09:47 AM | #7 |
Rep 26
My car has the HK system but the same basic idea applies.
The harness just connects you to the stock system on both sides. You would then need an LOC/DSP/EQ/XOVER between that harness and the amp(s). Technic is very responsive to emails so if you have any questions just ask, he is quite knowledgeable about these systems. Or there's threads around that talk about upgrading the base stereo. |
03-17-2018, 08:08 PM | #8 |
Rep 7
I have a 2013 328i with the base system. Im new to this and want to know what id be able to do upgrade wise. I had a hyundai with a kicker 12" sub.
03-18-2018, 06:10 AM | #9 | |
Rep 195
my new setup will include .[*]https://technicpnp.com/product/stereo-46-harness/ .[*]https://www.amazon.co.uk/XD600-Audio.../dp/B004E9QK3E .[*]https://www.ebay.co.uk/itm/BMW-3-SER...-/152919939296 .[*]https://www.ebay.co.uk/itm/BMW-4-FRO...YAAOSw7FRWXZY3 .[*]https://www.ebay.co.uk/itm/Vibe-BMW-...4AAOSw1JVZ-6Nz .[*]https://www.ebay.co.uk/itm/BMW-NEW-G...sAAOSwFyhaFsPH .[*]https://www.ebay.co.uk/itm/Vibe-Slic...EAAOSwX61ZCvrY . Last edited by Youngjnr; 03-18-2018 at 06:16 AM.. |
04-17-2018, 08:22 AM | #11 |
Rep 66
I'm not confident that those Vibe speakers are good quality since their price is 300GBP for 2 subs and 2 front speakers.
I just grabbed a pair of Eton B100W for the front doors and thinking of a pair of Match 8BMWD: https://www.ebay.co.uk/itm/Eton-B100...oAAOSwBiBaoumm https://www.ebay.co.uk/itm/Match-MW-...sAAOSwmSdaYc~u |
08-05-2018, 02:03 PM | #12 |
Rep 195
I didn't end buying the technic harness I just built my own harness for about 20 pounds so saved big time and I then upgraded the speakers and installed a 4ch and mono bass amp just need to tidy all the wires now its done but it does sound so much better now especially with two 10 inch subs working hard on the boot to round off the bass
08-07-2018, 12:53 PM | #15 |
Rep 195
got round to trying to clean up the wires for this install I'm thinking of getting a stealth box with one 10 or 12 but just not sure if it will hit as hard as my two 10inch subs in a ported enclosure what are some of the sub boxes are you guys running pref with pics?? I'm thinking of saving space over a big massive box I have now also I will be upgrading the amps to jl audio these amps was just to make sure buildung my own harness worked and the whole system overhaul went to plan
08-07-2018, 01:57 PM | #16 |
Rep 195
Quick question also should I code my base head unit (cic) to hifi and does any one know what I need to change to code this I'm thinking it should improve my sound
08-18-2018, 03:01 PM | #17 |
Rep 1
standard hifi speakers/subs/amp upgrade: bavsound vs other aftermarket?
I have a 2017 330i xDrive sportwagon with standard hifi, I own the car, not leased. I have heard lots of great reviews for bavsound, so I'm sure they sound great AND they are plug and play. BUT, has anyone compared to other high quality aftermarket speakers and amps (e.g., JL Audio)? The question for me is, if I plan to pay an professional to install/rewire aftermarket speakers, subs and amp, is bavsound still the best choice? I guess the same question could be asked if I was just considering an amp only upgrade as I think that may be the weakest link in the audio system. Thanks!!!
(Disclaimer - I have not done a side by side cost comparison yet with installation costs.) |
08-18-2018, 03:24 PM | #18 |
Rep 16,079
If you were well versed in how speakers work you'd use data sheets like this to compare different drivers:
https://www.parts-express.com/pedocs...ifications.pdf Doing so in hi-fi and pro-sound is standard operating procedure. In auto sound driver data sheets are pretty much non-existent. There's no excuse for it, the gear required to take all the measurements shown comes to less than $500, but it is what it is. You'd also need the data for the stock BMW drivers for comparison. That I do have, because being a professional loudspeaker designer I have the necessary measurement tools. The data tells me what you already suspect, that the BMW drivers are perfectly OK. A better amp wouldn't hurt, as would a good DSP for fine tuning the sound. Where the amp is concerned anything less than doubling the power of the stock amp isn't worth the cost or effort. As for purely subjective reviews, they're as useful as opinions on which tastes better, Coke or Pepsi. When you expect something will sound better it will, especially if you spent big bucks on it. I suspect very few have actually priced out what the stock drivers cost. I have. This is the breakdown for the Bavsound Stage One versus the H-K system: Bavsound Stage 1 $ 900 BMW H-K Center Tweeter $ 83 Center Midrange $ 67 Door Tweeters (4) $ 288 Door Midrages (4) $ 480 Rear Tweeters (2) $ 166 Rear Midranges (2) $ 128 Total $1209 So based on price, and the lack of any objective data, one would conclude that the H-K speakers are just fine. Last edited by Billfitz; 09-25-2021 at 10:25 PM.. |
08-20-2018, 01:25 PM | #19 |
Rep 195
decided to put my amps on show still not done need to get a new distribution block as I broke it so this one is just temporary also add the wav link 4 it is a must have if your not using amps like a jl audio with balanced differential inputs I could have hidden everything but thats not me
