12-26-2018, 03:36 AM | #112 |
Rep 7
12-26-2018, 03:48 AM | #113 | |
Rep 1,693
Looking forward to XHP. I'm just going to make a backup, increase the 3rd and 6th limits a little, enable gear display in D and flash that for now. I'm pretty happy with the stock calibration otherwise. As soon as I sort out a cost effective way to flash my FEF v129_180, I'll put my downpipe in and start working on a tune. |
12-26-2018, 07:28 AM | #114 | |
Rep 7
It is more to do than rising Limiters in a Gearbox that is Tuned for higher HP and Torque Rating. You Spend more Time for a Gearbox tune compared to a Engine Tune when you want a good Function and long Durability. This is my experience with 8HP Audis like RS6 and 3.0BiTdi. Drive a car without Gearbox Tune and one with a Full Tuned and you feel the Difference. What is the Problem with the last PWG Flash ? What I-Stufe is it ? |
12-26-2018, 10:22 AM | #115 | |
Rep 1,693
I'm happy with the stock calibration and only need a small increase to the 3rd and 6th limits. The other tables are still scaled beyond those limits with legitimate values. I'll make further changes down the track. FEF v180 came out very early 2018 I believe. I do not want my ROM downgraded to v160 from 2016 as MHD does. Yes it will work but I want to use the latest. |
12-27-2018, 02:43 AM | #116 |
Rep 504
01-16-2019, 10:41 AM | #117 |
Car Hypochondriac
335
Rep 901
Just 5 more days... who wants to bet it'll be pushed back again?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
01-16-2019, 05:41 PM | #119 |
Rep 470
Fortunately, the turbo in my car killed itself, so a delay here won't bother me.
PS2 here I come.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
01-16-2019, 05:43 PM | #120 |
Rep 470
PS2 here I come.
Current mods
01-16-2019, 08:45 PM | #121 |
Mike: Everyone's Pal
2042
Rep 2,972
Drives: F80 M3
I have faith itll be out
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
02-07-2019, 11:02 AM | #122 | |
Rep 15
05-01-2019, 06:09 AM | #123 | |
Rep 1,291
Would it be possible to share a screenshort of what the map looks like in WinOLS for you? So can see if it looks remotely similar
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-01-2019, 09:29 AM | #124 |
Rep 2,653
Looks like PTF have some testing going on with some people regarding the torque limiters on the 8HP. Hopefully they are working on a fix. Glad I didn't pull the trigger on xHP just yet.
05-01-2019, 09:33 AM | #125 |
Modder of everything I own
147
Rep 491
Same
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
05-01-2019, 01:37 PM | #126 |
Rep 1,291
xHP is more than just a torque limiter removal, so I'd still like to have it even if I have bm3.
05-01-2019, 02:39 PM | #127 | |
Rep 2,653
12-15-2019, 04:20 PM | #128 |
Rep 394
bumping a mega old thread....
been exploring my n55 bin and came across a section with a table header of 0-9 (assuming RN12345678) and noticed that all cells on my F25 Xdrive were filled with 492 Interestingly enough, I've also had issues with requesting more than 492NM torque. Not wanting to bump and screw with load to torque tables, I'm wondering if anyone has seen these before.... both values (column labels and values) have not been scaled. EDIT - NOPE. No change on outputs. Last edited by anjuna; 12-16-2019 at 08:57 AM.. |
12-06-2020, 01:42 PM | #129 |
Rep 743
12-06-2020, 05:02 PM | #130 | |
1296
Rep 3,533
12-06-2020, 05:43 PM | #131 |
Rep 7,602
Post above is correct. The torque limiters are exactly what they sound like - they are limiting the amount of torque in 3rd and 6th, so regardless of how much power the tune can put out, you wont get all of it. I don't think you hit them with stage 1 tunes (although close) but you will hit with stage 2 or above. MHD allows you to see it in the logs, not sure about BM3.
12-06-2020, 08:45 PM | #132 | |
Rep 743
