01-16-2019, 06:27 PM | #1 |
Rep 125
A little back story to my situation, my idiot self wasn't paying attention and ran up on a curb and hit a traffic delineator. No chassis warning, rim is fine and alignment seems fine there's no noticeable pull to the steering. But for whatever reason I opened my coolant reservoir so the hot coolant flowed back into the reservoir way above the fill line. Drove home which took about 15 minutes through city street hoping it would just suck it back in to the system but it didn't. I want to take the car into the shop but won't have funds to do that until next week and I have a really important job interview tomorrow so I can't really afford to be with out a car right now. Any advice if I can hopefully remedy this problem myself or any information as to what's going on would be very much appreciated. Wondering how bad it would be still drive like this. My engine oil temperature never went above normal operation although it got close but started dropping again quickly.
EDIT: Let the car cool off a bit and the coolant level is dropping within the expansion tank, it's close to normal range. I'm still slightly concerned about the curb I hit about what problems might arise from that even though everything seems fine now. |
01-16-2019, 06:41 PM | #2 |
Rep 1,905
You likely have air entrapped into the cooling water from opening the system when it was hot. Go here https://www.newtis.info/tisv2/a/en/ and put in the last 7 digits of the car's VIN number and search for 'cooling system'...you may have to dig a bit but you should be able t find a procedure to 'bleed' the air from the system.
I'd be VERY cautious about driving the car any distance/time as it sits right now......you do NOT want to overheat the motor, doing so can do major damage in a short length of time. Your car if it gets too hot will likely go into 'limp mode' and it will slow down and tell you to get it to a shop or turn off the motor, etc. IF you bleed this system and need to add coolant...use distilled water instead of tap water. Be mindful that that 'reservoir' is an expansion tank - it should NOT be filled to the brim, there needs to be a fair amount of air in there for the coolant to expand when it gets hot (you know all about that now) and NOT create overpressure that could crack that plastic tank. Look in the bottom of the tank as there will be something there to indicate to you the proper fill level. Good luck/Bill Last edited by Wgosma; 01-16-2019 at 07:03 PM.. |
NoobCola31.50 |
01-16-2019, 07:17 PM | #3 | |
Rep 125
01-16-2019, 07:29 PM | #4 | |
Rep 1,905
This would be a good thing to do next time you get the car going - you can watch both the analog dash gauge (Oil temp) and water temp at same time (via hidden menu)....water temp should run around 100C when car is at full operational conditions. If you see water temp stable at/near 100C or so you should be ok driving the car. Good luck/Bill |
NoobCola31.50 |
01-16-2019, 07:42 PM | #5 | ||
Rep 125
01-16-2019, 07:46 PM | #6 | |||
Rep 1,905
NoobCola31.50 |
01-16-2019, 09:28 PM | #7 | ||||
Rep 125
01-16-2019, 10:02 PM | #8 | |
Rep 5,089
NoobCola31.50 |
01-16-2019, 10:02 PM | #9 |
Rep 1,905
Level is not super critical- if near the mark it's fine. Looks like temp is stable- just keep eye on temp gauge it tomorrow's drive.
Just open to check level with cold motor- level drops bit as water cools, and dangerous to open when hot, just never do that. |
NoobCola31.50 |
01-16-2019, 10:11 PM | #10 |
Rep 125
Yea I have no idea why I did that I was panicking and decided to open it I have no idea why. I realized immediately after I messed up
01-17-2019, 08:50 AM | #11 |
Boost Addict
334
Rep 349
If they havent made it clear yet, you need to bleed the system again.
Opening the coolant system when hot will depressurize it, and cause the hot areas in the block and head to boil and create massive air pockets. If you are not comfortable running the bleeding procedure, at least run the car when its cold with the cap open for 5mins to allow the air to reach the expansion tank again.
S55 M2C | Three Pedal Club | E30TU
NoobCola31.50 |
01-17-2019, 11:29 AM | #12 | |
Rep 125
01-17-2019, 12:09 PM | #13 |
Rep 1,905
It's possible there is air; air will often cause erratic high spikes in coolant temperature, often quite short duration.
Since you don't have a water coolant gauge on the dash you have no way of detecting a spike in temp (unless you always engaged the parameter via hidden menu, bit of a pain). The other posters idea of running the motor from few minutes with expansion tank cap loose/removed is of value to get air out - not as good as full bleed procedure but most likely adequate in your situation. |
NoobCola31.50 |
01-17-2019, 12:46 PM | #14 | |
Rep 125
01-17-2019, 12:51 PM | #15 | ||
Rep 1,905
A true 'spike' due to trapped air would say drive the reading to 125C or higher ....and very quickly, wham up it goes/went. |
NoobCola31.50 |
01-17-2019, 01:00 PM | #16 | |||
Rep 125
01-17-2019, 02:14 PM | #17 |
Rep 125
Thanks again though everyone for all the information. The community here in this forum is great the willingness to want to help every restores my faith in humanity. I'm just a little worried about the curb still. I'm taking the car in for an alignment check as soon as I can to see if that's still good but is there anything else I should look for? I'm going to put the car up on ramps ASAP(it's currently raining in my area or i would have already) and visually inspect the side that went over the curb with the side that didn't to see how it's looking. I'm chalking this up to dumb luck that I didn't get any chassis error or anything like that even the rim is completely fine.
01-18-2019, 11:13 AM | #18 | |
Boost Addict
334
Rep 349
Zero special tools required. And on the F-series, it's even easier with the electric water pump and their programed bleeding operation. But no matter what the expansion tank is where the air will eventually go. So even if you dont bleed it right or any at all, most of the air will end up there as it should. Id just check on alignment and call it a day. I think you are over worried.
01-18-2019, 02:09 PM | #20 | ||
Rep 125
