04-14-2016, 10:16 AM | #1 |
Rep 38
Can't decide what to do with the suspension
I have a 328i Xdrive pre LCI which is equal with soft suspension.
My first thought was to only put on sport springs (Eibach, lowers 15 mm). Should I put on H&R sway bars as well? How will that affect the ride? Will it be stiffer or just less body roll? I'm also considering bilstein B8's. However, doing all three things will make the car to stiff, or? Anyone tried this? I want it to be perfect at the first try.
2014 BMW F30 328i Xdrive M-sport Alpine White. Wagner IC. Kelleners sport springs and Bilstein B8s.
04-14-2016, 03:07 PM | #2 |
Rep 10,264
There are many threads discussing pros and cons of various options: stock springs and new shocks, stock shocks and new lowering springs, and coilovers. Search, read, and by all means learn what other forum members evaluated and selected. Invaluable.
If you want to do this only once and your budget is within $2K range, coilovers are the only option providing matched shocks and springs. To contrast - soft shocks and stiffer lowering springs were not designed to work together. I suggest to explore KW Street Comfort coilovers as a start. That's what I selected after extensive research. Great product. |
04-16-2016, 12:27 PM | #3 | |
Rep 284
Drives: F30 335i EBII MPPK/BBK
Garage List 1999 Honda CR-V [0.00]
2013 BMW 335i [0.00] 1986 BMW 325e [0.00] 2014 Porsche 991 Ca ... [0.00] 2018 Audi SQ5 [0.00] 1971 Volkswagen Sup ... [0.00] |
Thanks! David
Current Garage
2018 Audi SQ5 2014 991 Porsche Carrera 4S 1986 BMW 325e 1971 VW Super Beetle |
04-16-2016, 08:36 PM | #4 | |
Rep 4,323
04-17-2016, 10:43 AM | #5 | |
Rep 10,264
When I decided to purchase KW Street Comfort coilovers for 2013 F30 335i xDrive, my requirements were: - Wanted to maintain suspension geometry; lower suspension by 10mm only - Adjustable rebound damping was sufficient for street and freeway driving B14 (PSS): not adjustable; minimum lowering 30mm B16 (PSS9/PSS10): fully adjustable (compression and rebound); minimum lowering 30mm; more expensive: +$1K Last edited by cfm56d7b; 04-17-2016 at 02:31 PM.. |
04-17-2016, 11:31 AM | #6 |
Rep 1,201
Please listen to the above poster and upgrade to a full coilover only instead of just springs which will make the ride unbearable - bouncy and crashing into every bump. If you do springs only you will end up spending more labor cost taking them off and putting a coilover set on.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
04-17-2016, 07:39 PM | #7 | |
Rep 284
Current Garage
04-17-2016, 11:24 PM | #8 |
Rep 10,264
It's worthwhile to take a look at www.allshocks.com. Very competitive prices.
I think both KW and Bilstein coilovers will offer what you are looking for: matched springs and shocks. When the installation is complete, please share pictures. It's good to see another forum member with xDrive vehicle make the suspension what it perhaps should have been from the first day. |
04-18-2016, 07:48 AM | #10 |
Rep 38
Unfortunately it is not possible on an Xdrive
