BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Heating
      11-06-2024, 01:31 PM   #1
hxavier93
Drives: BMW 320i F30 2014 (RHD)
Heating
Hello. I have a bmw f30 320i 2014 (RHD). It recently started to heat up when it's at high revs or I'm at speeds above 100km/h. The coolant level is normal and usually has no error. The car does not heat up when it is stopped or at low speeds.Hello. I have a bmw f30 320i 2014 (RHD). It recently started to heat up when it's at high revs or I'm at speeds above 100km/h.
Is it a fuse problem? Thermostat or even the pump? How can I identify?
      11-06-2024, 03:47 PM   #2
MooLard
Drives: 335d touring
Yes maybe the thermostat isn't opening fully anymore so that the coolant can't pump enough through the engine to cool it. I don't know this engine specifically but I'd try that first.
You could also idle the car with the coolant cap off and see if coolant is returning back to the tank as that would suggest if the pump is or is not working.
      11-08-2024, 03:54 AM   #3
PETED678
Drives: 420D Gran Coupe F36
More than likely the water pump needs replacing, you can do it yourself or take it to a garage/BMW
      12-02-2024, 05:04 AM   #4
hxavier93
Hello everyone. Thank you for the suggestion. I took the car to a garage and we did the diagnosis. I had to replace the electric water pump and the problem was solved. I paid the equivalent of 400USD.
Wires2029.00
