01-20-2020, 10:30 AM | #2223 | |
Rep 51
So if i understand it right, Snapdragon\GS_20191127\CIC-1054.rar is the right file? Checked also the first post mega link and now i am confused because there is no GS_20191129 folder don't want to update it multiple times since i will factory reset the device |
01-20-2020, 11:19 AM | #2225 |
Rep 237
now that idrive works systemwide you can install any launcher without any issue at all. Set as default and voila'
01-20-2020, 11:32 AM | #2227 | ||
Rep 1,048
It will work if you have no CIC installed, you just have to control the whole unit with touch until you get your CIC System. Kri |
01-20-2020, 11:38 AM | #2228 | |
Rep 79
Currently using automate as launcher but its a bit buggy and dated. I have tried all available launchers and none of them have been good, automate is still the best one IMO. I think AA would be good if it worked properly as standalone app,but it doesnt. |
01-20-2020, 11:45 AM | #2229 |
Dirk
Rep 52
01-20-2020, 12:02 PM | #2230 |
Rep 80
01-20-2020, 12:07 PM | #2231 |
Rep 28
The problem with not saving the volume or equalizer settings is a MCU problem or more specifically a problem of combining the latest mcu with the latest firmware . When i had 3.8.0 firmware with my initial mcu 190812 there was no problem. After i put latest mcu the problem appeared. When i downgrade my firmware to 2.8.3 retaining the mcu then the problem does not apply again.
Also for some reason the 2.8.3 appears to give better sound qulaity to me although the sound quality in general is very poor and i i did not yet get to uninstall the aux cable.from the armrest as it was suggested to see if it improves anything. Anyway, Does anyone have the 190812 mcu lzh for ccc to install again ? Last edited by Kostisuk; 01-20-2020 at 04:02 PM.. |
01-20-2020, 12:38 PM | #2232 |
Rep 51
Fixed. Used the wrong mcu files. CIC-High is nbt... uff... lucky me
Mhm what could be the cause that i cant Switch to idrive. Switching through the Android ui gives me no Signal. Also idrive Control doesnt work Last edited by DarkIrata; 01-20-2020 at 02:28 PM.. |
01-20-2020, 03:54 PM | #2235 | ||
Rep 1,048
How far does it boot at all ? any screenshots ? Check Page 1 of this thread, there are links to Recovery for PX6 and SD625 with Android 9. Quote:
Kri |
01-20-2020, 04:10 PM | #2236 |
Rep 11
So following up on my previous post about a flickering screen. It's definitely heat causing it with the screen starting to flicker at 60degrees. Vendor sent me a new MCU but it turns out I'm already running this "newer version" from following this forum.
01-21-2020, 01:19 AM | #2238 | |
Rep 399
01-21-2020, 01:42 AM | #2239 |
Rep 51
01-21-2020, 02:08 AM | #2240 |
Rep 1,048
because when it does get no CAN signal it would turn up as soon as you unlock the car = when it does get power.
so Dashboard does also work ? (CAN). Does switching Radio on the OEM HU (keys on Steering wheel) do work in background (OEM HU is up and running) ? and i assume you have already tried the different Can bus Protocoll settings (4 different) Kri |
01-21-2020, 04:09 AM | #2241 | |
Rep 80
Thank you soo much! And do you know if the ccc idrive controller will work on the cic navi? or i need to buy a cic controller? I dont know a lot of the topic, thank you! |
01-21-2020, 04:19 AM | #2242 | |
Rep 1,048
But i recommend you anyways to upgrade to the 7-Button controller, its much easier to control the Units with it. Kri |
01-21-2020, 04:25 AM | #2243 | |
Rep 80
Thank you! |
01-21-2020, 05:27 AM | #2244 | |
Rep 1,048
The CIC Controller has been built in in many other cars so it is easy to get, check the compatiblity list here. the Controller has also been used for MASK-2 , and CCC with latest update also support the 7-button controller. To get the CIC-trim is indeed an issue for the E87 (same as E81/E82/E88). Sometimes people do sell the centerconsole with the controller trim, so this way you maybe also find one. It would be possible to mount it into the CCC Trim with modification use an E90 CIC Controller which is normally sold with an additional adapter, so you can glue this in. Other way would be to 3D print a trim, i started designing one some time ago but then switched to the F20 Center console. Kri |
