03-09-2020, 09:56 AM | #67 |
Rep 36
I already have an extra key FOB that I would like to see if it can be programmed to my car. Seems a bit shameful to get a brand new $300 key FOB, while at the same time throwing away a perfectly good $300 key FOB that I already have....
As some have mentioned, my only choice may be just that. |
03-09-2020, 07:04 PM | #68 | |
Rep 71
Gabo
03-10-2020, 08:41 AM | #69 | |
Rep 36
Thanks Gabo - I will try this in the next few days. I have also seen other similar videos. The issue I have is that I don't believe my second key is from MY car, I believe it is from another BMW on the used car lot where I purchased mine. Does anyone know if this procedure will work on a key [most likely] already programmed to another car? Or, better yet, is there a way to tell if my second key is actually programmed to my car, or another one (other than trying the mechanical key)? |
03-10-2020, 09:13 AM | #70 | |
Rep 71
Gabo
03-10-2020, 09:13 AM | #71 | |
Rep 3,748
03-10-2020, 02:01 PM | #72 | |
Rep 36
Laziness is my best friend.... I think I mentioned in an earlier post that I need to try the second key mechanically and see if it works. All I know at this time is that the buttons on the second FOB do not work, and it will not start my car. I assume you are saying that, if the mechanical key in the second FOB does not work, I have a $300 figurative boat anchor? |
03-10-2020, 03:01 PM | #73 |
Rep 2,805
Drives: F33 430 and F39 M35i
Yes, if the second key does not manually unlock your car then it's meant for another car.
Does the blade cut look the same as the one that works? |
03-11-2020, 08:59 AM | #74 |
Rep 36
Good news for the two or three people that may be following this thread: last night I tried the mechanical key from my second key FOB, and it works!
It still would not lock or unlock the doors, and with it in my pocket, would not start the car. However, I did receive a message on the dashboard saying to hold the FOB up to the steering column, and when I did, it started the car (I did it twice just to make sure). When I got back out of the car, I tried the lock/unlock buttons, but to no avail. I am thinking the battery just needs to be replaced? Anything else I may be missing? Thanks to everyone who posted here - I suppose I should have tried the mechanical key before I even posted about it. |
03-11-2020, 09:34 AM | #75 |
Rep 2,805
Change the battery and try again. Good news about everything else.
03-11-2020, 10:44 AM | #76 | |
Rep 3,748
Your now a proper owner of a BMW.... welcome to the family. |
03-11-2020, 10:52 AM | #77 |
Rep 7
03-11-2020, 11:18 AM | #78 | |
Rep 71
Gabo
03-12-2020, 01:24 PM | #79 |
Rep 36
And there is much rejoicing: after replacing the battery in my second FOB, everything works as it should, and I now have two working keys/FOBs. Some common sense and help from you guys just saved me $300+, or the equivalent of a 4-pack of toilet paper.... ;P
chowser512025.00 |
03-12-2020, 02:25 PM | #80 |
Rep 71
😂😂Happy for you my friend! 👌🏽
Gabo
08-30-2020, 01:06 PM | #84 |
Rep 16,082
02-01-2021, 09:06 AM | #85 |
Rep 15
Using HiTag2 and E/F Scanner
Since this thread keeps on going,.. I figure I should provide some insight.
Most BMW Dealerships in the US tend to charge around $300 USD for a new key to be made. You can find independent guys and some locksmiths that will do it for $150 or so. That cost should include a new FOB, programmed into your CAS, and the key blade cut. Note: You will either need to mail in your CAS module or bring your vehicle into them in order for the key to be programmed. If you're more of a DIY kind of person, computer savvy, and OK with the potential risks, you can also program your own FOB using HiTag2 to 'prep' the key and E/F Scanner (BMW Explorer clone) to write the key to the CAS. Blank/virgin keys are under $20 from Aliexpress. Note - Dont waste time with buying a "used" key and wanting to program it. Yes, it CAN be done by either de-soldering the transponder and soldering in a new transponder ($4 for the transponder chip but you have to have a re-work station and good with hot air soldering). Alternatively, you could buy a tool that erases data in the transponder but then you're spending a few hundred $ on a tool when you could have just bought a virgin key for $15). Here's the video on how it works: |
08-05-2021, 12:40 PM | #86 |
Rep 9
So I just got a second key
Since Carvana lost my key. Here's what they did. They ordered one from BMW direct and the guy was just here. What he needed to do was on the steering column there is a white square. They hold it up to that, press the key fob a few times to "program it" like an old school universal remote.
For the poster who wrote about how it started his car, he explained to me that if you hold the fob up to that spot it will start the car even if the battery in the fob is dead.
1999 328i 2006 328xi 2009 328xi 2012 328xi
and currently 2018 320i |
05-31-2023, 04:43 PM | #88 | ||
Rep 45
I knew these probably won't work out the box but they were too cheap not to try and surprise surprise they won't work so now I been searching how to actually code these keys for my F32 with CAS4 and it is more complicated that I thought. The most common option is removing the FEM module from the car and then "jailbreak it" to be able to add the new keys in the system, I'm pretty sure I won't risk my car trying to do that so that is not an option for me. The other option is using this tool: "Xhorse VVDI Key Tool Plus" it is pretty expensive but you don't need to dissamble anything from the car, here is a full video doing it the whole thing with that tool: I also found a cheaper version of this tool from the same company: "Xhorse VVDI Mini Key Tool", I wonder if I can use it for the same thing for BMW CAS4 but I can't find anything about it. If anyone have more info about this please let me know. Last edited by innovaciones; 05-31-2023 at 06:07 PM.. |
