03-19-2020, 10:05 AM | #1 |
Rep 549
ID6 Connected Drive - What are people using and is there any point?
Just want to check what Connected Drive services people are using on the ID6 systems, will be for an F36? Looking to carry out the retrofit so just thinking whether I need the ATM Module or not. Apart from the remote lock/unlock/GPS and headlight flash is it worth it? TIA
F36 435D XD | Carbon Black | M Sport F36 BUILD THREAD | E93 BUILD THREAD | E92 BUILD THREAD Instagram - Gazzzillionaire |
03-19-2020, 11:05 AM | #2 | |
Rep 1,894
GOWRIN110.50 |
03-24-2020, 06:43 AM | #3 | |
Rep 549
Thanks for the help
03-24-2020, 07:25 AM | #4 |
Rep 2,127
I use send to car and the lock/unlock feature quite often.
The one thing that stops me using waze on carplay instead of the BMW navigation is that it doesnt work through the HUD.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
GOWRIN110.50 |
03-24-2020, 07:49 AM | #5 | |
Rep 549
I don't have the HUD option so I guess it won't be an issue, anything else on the ConnectedDrive you use? Thanks
03-24-2020, 03:02 PM | #6 | ||
Rep 2,127
I occasionally look at the news headlines, weather etc, and online searches for addresses for navigation. That's about it.
GOWRIN110.50 |
03-26-2020, 04:07 AM | #7 | |
Rep 549
In my NBT iDrive I have not used any of the options in the ConnectedDrive so far but with the retrofit I will get the ConnectedDrive options just not the remote options such as unlock/lock etc. I have done some googling and came across CarBridge which looks like if you have that on your iPhone you can run any apps. Might have a look into that and see how that works.
gasman8216.50 |
03-26-2020, 04:48 AM | #8 |
Rep 784
Drives: 2018 F80 M3 CP YMB
I've always used Pro Nav so I couldn't do without Real Time Traffic Information. That plus Send to Car are the only features I regularly use and the ones that would make me justify renewing the subscription. Occasionally handy to check how much fuel is in the car... If I didn't use the Nav not sure I could see the point in Connected Drive - certainly not enough to add it...
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
03-26-2020, 06:20 AM | #9 | |
Rep 549
But the fuel level can only be synced if the car is plugged in via USB right, that is what I've found it to be in NBT at least.
03-26-2020, 08:59 AM | #10 | |
Rep 784
GOWRIN110.50 |
03-26-2020, 10:07 AM | #11 | |
Rep 549
04-24-2020, 05:15 AM | #12 |
Rep 549
Okay so just a little update with regards to my ID6 retrofit with ATM Module just so that if anyone else does need this information it will be helpful.
ConnectedDrive Services work and you can subscribe to what is available for your own VIN such as RTTI, Online Entertainment, BMW Online, BMW Assist, Concierge Service, SOS/Emergency Call and TeleServices. What doesn't works is the USB Map Updates as that will online give you updates for NBT HU and not NBT Evo HU. And also the Remote Services don't work, can no longer remotely lock/unlock, flash lights or check location. What does seem to work which is a nice feature is the Fuel and Mileage are updated without having to plug the phone into the Car now. But this I need to test more as it seems it updates but once I view it once in the app it then disappears and goes black... The other thing is it does look like it shows the last location I left the car so might be useful when you park the car somewhere and not a clue where you left it. But again I will have to test this more in order to understand how it works. Just a little review of the ID6 retrofit. Will update my build threat with pictures and how it all looks.
