03-27-2020, 05:56 AM | #1 |
Rep 14
Squealing noise while pulling away??
After having not drove the car for a few days due to us being in lockdown, I took it out to get the food shop and while I was rolling away there was a continuous squeal. Thought it was brakes but I wasn't applying the brakes at all while the noise was occurring. Has anybody else experienced this?
Christopher Scott
03-27-2020, 06:01 AM | #2 |
Rep 810
Its probably still your brakes. Pads contact the discs ever so slighly all the time. Any kind of surface corrosion that has built over that time will cause a squeak.
It could also be the inboard handbrake drums. You could also have a tiny stone stuck next to the disc and caliper, or disc and splash shield - they can cause a horrific squealing! |
03-27-2020, 06:06 AM | #3 |
Rep 4,935
Drives: 340i MPPSK
Sorry when I saw the thread title I thought it was something to do with interfering with pigs!
Anyway, have you checked you don't have a stone lodged between the disk and the guard at the back of the disk? If it is, reversing up a few metres will often dislodge it.
Life is a state of mind |
ZedsRedBaby1762.50 M3anLantern249.50 |
03-27-2020, 06:56 AM | #5 |
Rep 941
I was expecting the 'is it coming from the passenger seat?' comment
2019 640i GT MSport & 2016 X3 3.5D X-Drive MSport
Previous - 2016 530D MSport - 2016 335D Touring M Sport X-drive - 2014 335D GT X-Drive MSport |
03-27-2020, 07:24 AM | #6 |
Rep 785
Drives: 2018 F80 M3 CP YMB
There is a common problem where the handbrake mechanism gets dirty/needs lubrication and is slow to release - so you get a squeal for 20 yards or so and then it is fine and it ends up happening every time you release the handbrake. No amount of braking will solve it. Obviously it may be the disc brakes as others have suggested but if braking doesn't make it go away I'd suspect handbrake (unless of course you don't use it!).
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
03-27-2020, 06:56 PM | #7 |
Rep 251
A slack alternator drive belt can cause a squeal as you accelerate away, but tends to go quiet if you back off and run at a steady speed.
03-28-2020, 02:36 AM | #8 | |
Rep 73
Even my F32 does it but only very, very briefly when moving off after being parked a while. Of course, you could leave the handbrake off in Park if you have an Auto but that could be another can of worms... |
03-28-2020, 04:23 AM | #9 |
Rep 14
Thanks for the replies guys! It seemed to have went away after driving for around 20/30 metres and didn't happen any time after that. Will get into a garage at some point for it to be looked at though! Thanks again.
Christopher Scott
03-28-2020, 12:33 PM | #11 | |
Rep 15,858
The procedure used to be put in the User Manual. I'll see if I can find a quote. |
03-28-2020, 12:38 PM | #12 |
Rep 1,455
Very unlikely on a BMW. This was common in the old days with simple V belts, these days ribbed serpentine belts with tensioners are used.
03-28-2020, 12:47 PM | #13 | ||
Rep 15,858
An example from an E90 User Manual:
03-31-2020, 01:49 PM | #14 | |
Rep 487
MarkJS50.00 |
03-31-2020, 01:52 PM | #15 | |
Rep 622
Ishan Achar
Former: 2004 BMW E46 325i Current: 2017 BMW F30 320i Follow @Black_Lux_Cars on IG |
03-31-2020, 01:57 PM | #16 | ||
Rep 14
Christopher Scott
04-01-2020, 02:05 PM | #18 | |
Old Fart
361
Rep 694
When wifey is driving there's a much more pronounced squeal pulling away from the lights, I tracked it down to the tyres though
The doctors said it's OK to listen to the voices..... just don't do what they tell me
