BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Flickering Xenon Lights
      01-05-2016, 02:10 AM   #1
Gorsh
Drives: 330d F31 Luxury sDrive
I've had a quick look and didn't find anything, so apologies if this has been asked before.
I was going to phone my dealer today but thought I'd ask here first about my Xenon adaptive lights. I have noticed lately when pulling up behind another vehicle the lights flicker - rather than going on and off I think they are jumping up and down a little. The lights are in auto mode and the adaptive main beam hadn't been turned on. Has anyone else had this?
TIA.
F31 330d Luxury RWD, MG, Black Leather, Vis Pack, Adv Parking, Adaptive Suspension, Sunroof, Elec sports seats, plus more...
For Weekends and sunny days:
981 Boxster GTS
      01-05-2016, 02:12 AM   #2
JustChris
JustChris's Avatar
Its been reported while raining Gorsh, was this in the recent bad weather?
BMW X3 M40d Performance Auto
Sophisto Grey Metallic with Oyster Leather
Comfort Package + M Sport Plus Package + Technology Package
      01-05-2016, 02:12 AM   #3
335dJa
Drives: Yes
Likely it was raining?
Quite a common issue, rain drains off the bonnet across the lights and refracts it all over the show.
      01-05-2016, 02:13 AM   #4
335dJa
Drives: Yes
Ah, beat me to it
      01-05-2016, 02:35 AM   #5
ajfoggy
ajfoggy's Avatar
England
1449
Drives: C63s - S205 - Brilliant Blue
Yep mine do it all the time most notice when I first set off in the morning and all the rain falls of the bonnet.
      01-05-2016, 02:39 AM   #6
TomJ79
TomJ79's Avatar
Drives: F31 330d
+1 on the rain diagnosis!
F31 330d
      01-05-2016, 04:33 AM   #7
JD6
Drives: F30 335d MS+ ACS springs MPS4S
It does feel like the engineering and styling departments were in different buildings when they designed this - not something you would expect from BMW. For a car which works so well in most respects, it is a very odd problem to have. A slight redesign of the bonnet to shift the water flow by a few cm would solve it.
I guess that the LED lights of the LCI could be less affected, since the beam is wider as it passes through the headlight cover
      01-05-2016, 11:23 AM   #8
Gorsh
Thanks for your replies everyone. Yes, I do believe the car was wet or it was raining - if it does it when dry I will get it checked. It is a strange problem as the light jumps quite a bit.
981 Boxster GTS
      01-05-2016, 11:54 AM   #9
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
Drives: BMW 330d M Sport
Can't change the law of physics so it's a problem you'll have to live with
Scott
2017 BMW 330d M Sport : 2015 BMW 220d M Sport
2008 Mini Cooper
      01-05-2016, 11:57 AM   #10
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Another +1 for the rain
Not sure about the design comment, what could they do short of fitting guttering above the headlights!?
Current: X3 ///M40d in PB/Tartufo
Previous: F30 335d, F30 330d, E90 320d, E46 320d, E46 330ci
      01-05-2016, 12:54 PM   #11
ukbeemerboy
Beemer Heaven
Agreed and the only time I notice it is when I first set off in heavy rain or if the car is very wet. There are bigger issues with the F30 than this
Scott
2008 Mini Cooper
      01-05-2016, 01:42 PM   #12
335dJa
Drives: Yes
Got me thinking after replying earlier, I would have thought something as simple as a little line of clear nail varnish or similar across the top of the headlight would alleviate a lot of the problem, or treat the headlamp with a "rain x" style product?
      01-05-2016, 03:11 PM   #13
Mattyk
Mattyk's Avatar
Drives: F36 435d
Rain + xenons = impromptu disco lights
F36 435d
Gone
F30 335d
      01-05-2016, 03:13 PM   #14
Drives: xxxx
have you a make up kit or a tool kit?
      01-05-2016, 03:14 PM   #15
k44ENT
k44ENT's Avatar
Drives: M2 LCI DCT
I have the same effect when raining or the water has beaded on the bonnet and it runs off as I exit the drive on dark mornings. One thing I have noticed is the lights moving over sharp bumps in the road like they are loose. The lights aren't loose so it must be the shutter over the bulb moving which controls main and dipped.
      01-05-2016, 05:46 PM   #16
335dJa
Drives: Yes
Depends what day of the week it is..
I've noticed the lights wobble over bumps too. Quite annoyed me at first, felt like an old banger with broken brackets
      01-06-2016, 09:19 AM   #17
JD6
They should have slightly altered the shape of the bonnet (or the lights) so the stream of water doesn't form in the exact same place as the xenon beam width. A couple of cm either way would probably do it. This problem seems to be unique to the F30/31.
While it isn't a big issue, almost every other car design seems to avoid it, so it shouldn't be beyond BMW's development team.
      01-06-2016, 09:30 AM   #18
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
Are you winding us up you lil rotter?
      01-06-2016, 09:42 AM   #19
JD6
I think I've just become obsessed with rain, having not seen that hot orangey thing in the sky for a while.
I'm off to Wickes to buy a some guttering and a couple of downpipes...
      01-06-2016, 09:48 AM   #20
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
I think they're far more concerned about aerodynamics and pedestrian safety!
      01-06-2016, 09:51 AM   #21
JD6
I'll make sure I use flexible guttering.
      01-06-2016, 10:06 AM   #22
NISFAN
NISFAN's Avatar
.....or buy an older BMW
