BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Front pads and discs
European Auto Source (EAS)
      04-09-2019, 01:12 PM   #1
Panchoa
Drives: BMW F30 330d M Sport
Hi all
How much should i expect to pay for the m sport pads and discs on a 2013 330d? Any recommendations on brand too please?
      04-09-2019, 01:27 PM   #2
335d Rocco
335d Rocco's Avatar
England
74
Drives: F31 335D M Sport Plus
Blue calliper brakes??
£740 front & £450ish rear at BMW
You can enter your car details on bmw service site and get different dealer prices
      04-09-2019, 02:08 PM   #3
SkyJawa
SkyJawa's Avatar
England
2267
Drives: 335d
There’s been a few threads on this recently worth doing a search.
      04-09-2019, 03:16 PM   #4
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Go on Autodoc and order aftermarket two piece discs, their app is cheapest.
Current: X3 ///M40d in PB/Tartufo
Previous: F30 335d, F30 330d, E90 320d, E46 320d, E46 330ci
      04-09-2019, 04:10 PM   #5
DriveS
Drives: F30 335d
I just paid £644 for a full set of front & rear M Performance discs (TRW) and full set of EBC yellow pads. A few extras like cleaner, grease, threadlock, a pin punch and a set of small wire brushes and total price is £665 as doing the job myself at the weekend.
BMW robbers
      04-09-2019, 04:23 PM   #6
Panchoa
What size discs and pads do i need for the m sport brakes (blue calipers)? Think discs are 370mm but im a bit confused on what i am looking for tbh!!!
      04-09-2019, 04:28 PM   #7
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
BMW robbers
That sounds expensive! On Autodoc the TRW fronts are £230 a pair and rears are £120, so plus £150 for the pads should be around £500 total!?
      04-09-2019, 04:31 PM   #8
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
370mm front, 345mm rear. Stick with TRW or Brembo imo:
https://www.autodoc.co.uk/car-parts/...lier%5B%5D=trw
      04-09-2019, 04:46 PM   #9
DriveS
Drives: F30 335d
I paid - Discs - 230 fronts and 118 rears - Pads 161 front and 136 rear
Have I been ripped off on the pads or have you forgotten to add the rears on?
https://www.ebay.co.uk/itm/DP42133R-...53.m2749.l2649
https://www.ebay.co.uk/itm/DP42130R-...53.m2749.l2649
      04-09-2019, 04:48 PM   #10
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Oh ok, I didn't realise EBC's were that expensive!
      04-09-2019, 04:49 PM   #11
DriveS
Drives: F30 335d
They better be good!
      04-09-2019, 04:52 PM   #12
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Apparently they're very good for fast road use, but no good on track.
      04-09-2019, 04:56 PM   #13
DriveS
Drives: F30 335d
Perfect. I will post when they are bedded in and I have tested them
      04-10-2019, 05:47 AM   #14
Quiet_Riot
No Longer on Here
Quiet_Riot's Avatar
Drives: Mercedes C63S
So what brakes did you go for OP?
I think some drilled and grooved ones would be nice but think Brembo only do a perforated ventilated disc.
      04-10-2019, 08:03 AM   #15
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Brembo and TRW both do an M Performance style one.
Quiet_Riot5475.50
      04-10-2019, 10:55 AM   #16
DriveS
Drives: F30 335d
Here are some options on the 370 & 345 discs. I went for TRW
https://www.onlinecarparts.co.uk/spa...eyword=DF6600S
https://www.onlinecarparts.co.uk/spa...eyword=DF6601S
      04-10-2019, 11:57 AM   #17
Watsey
Drives: F31 330D sDrive M Sport
Uhm, pretty rubbish for either. I had them a couple of years ago and they fade quickly even with moderately fast road use. On track they were useless.
Sorry DriveS - if you've not opened them you might want to considering changing them.
I'm now running Pagid Blue (RS4-2) on the front; Pagid Yellow (RSL1) on the rear. Yes they're more expensive but they're brilliant, even during an all-day track session pounding round Spa.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech BBK with Pagid RS4-2 pads, Birds ARBs.
      04-10-2019, 12:21 PM   #18
Craig-SM
Drives: BMW 320d M Sport - F30
Iíve used EBC on cars and motorbikes but wonít anymore. On both the pad material came away from the backing plate. Even before that happened they werenít anything special. Pagid have been much better value, lasted longer and felt better. Added bonus is they donít give off too much brake dust either.
      04-10-2019, 01:36 PM   #19
teaston
Pirate
teaston's Avatar
Drives: Black Pearl
Oh, I remember a couple of people saying they started to disintegrate on track, but didnít realise theyíre also not great on road!
Ferodo also make good pads, i had the DS Performance at around £100 a set which were great on road, DS2500 also very highly rated at around £170 a set.
      04-10-2019, 02:36 PM   #20
Panchoa
Cheers buddy. Assume the 370mm are for the front? What size pads do i need?
      04-10-2019, 02:47 PM   #21
Craig-SM
On the car they were EBC Red Stuff on a Mondeo Diesel estate so performance should have been well within the specs of the pads. Investigating noisy braking from the front and found the material detached from the backing plate. The pad material was only held in place by the pad carrier. Checked all the brakes and one of the rears had big chunks missing from the material as well as cracks. Pads were returned to EBC who blamed fitting, I fitted them and have never had an issue before or after. After much complaining they offered to replace them as goodwill but wouldn’t refund. Took the replacements and sold them on.
The motorbike was rear brake locking up briefly after braking for a corner. Luckily wasn’t going fast and was able to run wide onto the verge. Couldn’t figure out why it had locked up at the side of the road so went straight home to strip the brake and found one of the pads had lost its material and they were EBC fitted by the previous owner.
      04-10-2019, 04:03 PM   #22
SkyJawa
SkyJawa's Avatar
England
2267
Drives: 335d
I got ebc discs and green stuff pads years ago on my Impreza. The discs warped in less than 1000 miles, and the pads were shite.
I’d never touch ebc ever again.
