BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Fan sounds different after FMIC install
      06-02-2019, 04:08 PM   #1
jack10525
jack10525's Avatar
Drives: 435i GC
I installed a VRSF charge pipe and 5" fmic. After the install when I took the car for a test drive it seemed ok but a few miles into the ride I got a drive train malfunction warning. So it looks like I didn't have the silicon coupler positioned correctly or clamped tight to to the 2 charge pipe halves. I re-adjusted everything and got it aligned correctly. Car runs great and I have no codes. I do have a different fan sound than before with the stock intercooler. I'm thinking the bigger fmic makes the fans sound different. Had anyone had this experience?
2015 435i GC M-Sport Mineral Grey
( o )Y( o )
      06-03-2019, 10:56 PM   #2
SilkySmoooth
Drives: '13 335i MSport Estoril BlueII
I cant say I noticed this after my FMIC install. Did you secure the bottom of the fan to the intercooler tabs?
      06-03-2019, 11:32 PM   #3
harkes
harkes's Avatar
China
676
Drives: M135i, NSX and AE86
I experienced the same. Forgot about it quickly again though
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      06-03-2019, 11:57 PM   #4
Kraftwerk
Kraftwerk's Avatar
Drives: 2015 335i M Sport
Mine sounds a bit different too.
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
      06-04-2019, 08:17 AM   #5
ProjectBoost
Mod addict
ProjectBoost's Avatar
Drives: Black AWD N55
Normal.
      06-04-2019, 09:38 AM   #6
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
more air can move through the FMIC thus changing the sound of the fan
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      07-15-2019, 02:08 PM   #7
Troy27
Drives: Bmw f30
I just installed a fmic and my fan sounds different also. No codes everything is running fine. The fan is just louder now. I'm guessing it's normal because the intercooler is bigger and the fan is just echoing off of it. At least I hope that's what it is...
      07-18-2019, 09:35 AM   #8
jack10525
jack10525's Avatar
Drives: 435i GC
This is my hope too!!!
( o )Y( o )
      07-18-2019, 09:51 AM   #9
Polo08816
Drives: 2014 335i M Sport
When you install a larger intercooler (heat exchanger) in front of the radiator (another heat exchanger), you're altering the air flow through both heat exchangers. The fan make sound different because it's working harder due to air flow being more restrictive.
FastF30277.50
Troy2730.00
      07-18-2019, 10:37 AM   #10
wdeerfield
A family of bimmers
my fan was loud as well but it turns out mine was shot and not running as it should. I just got the new replacement installed and its noticeably quieter than the old one. I also finally bent the wrong tabs on my VRSF FMIC to lock in the fan correctly.
      07-18-2019, 12:28 PM   #11
XutvJet
Drives: 2016 M235 6MT
^This.
      07-18-2019, 12:35 PM   #12
Polo08816
Originally Posted by XutvJet View Post
^This.
This may not be a problem for drag racing or roll racing, but it creates a cooling problem if you're tracking the car for sure because you need to balance the need of cooling the intake charge vs the engine coolant.
      07-18-2019, 01:51 PM   #13
Troy27
Drives: Bmw f30
Mine definitely has a different tone but I wouldn't say I think anything is wrong with it. Hopefully...
