07-09-2019, 10:34 AM | #1 |
Rep 1,755
Paid $1850 + $400 for Swift springs, not including install. One advantage of this setup vs others is the dampening adjustments on the rear are located at the base of the shock, so depending on your height, you just have to reach into the wheel well and turn the knob. My current ride height is 26.5" front and 26" rear from ground to fender, which leaves about 1~ finger gap rear and slightly higher up front. 15 way adjustable dampening and of course height adjustment also. I'm at max height rear and front has more adjustment. Purchased around October 2018. I have driven about 5k miles since. To put things in perspective I've driven my car about 7k miles in the past year. Reason for selling: I want to raise my car higher and also recoup some money while going a different route. The car is too low for my parents to comfortably get in and out of, and my front lip scrapes. Planning on painting my front lip and looking to avoid damaging that. Performance: much improved handling and overall feel of car has changed. These are supposed to be KW V3 equivalents. Unfortunate no photos of the actual coilovers since they are still in the car. Price: $1500 Cash Located in Los Angeles. Shipping is extra. Thanks for looking.
09-08-2019, 09:51 PM | #2 |
Rep 21
Would you share more info on the swift springs (spring rates or part # -- trying to speculate the ride comfort level and quality). Also will you be retaining any cks parts (ie. End links) or selling without missing parts.
09-12-2019, 01:14 PM | #3 |
Rep 1,934
These are single adjustable, but aren't v3 double adjustable?
