BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > any major issues to worry about with '17 430i GC?
European Auto Source (EAS)
      07-18-2019, 10:03 AM   #1
mastapro
Drives: none
I'm really looking into getting the 2017 430i Gran Coupe in the next few days. I've only owned one other car in my life and it was a Japanese car. The only thing I had to do to maintain it was regular oil changes. It ran perfectly for 4 years and now I'm wondering what kind of maintenance I'm looking at if I were to own the 430i.
      07-18-2019, 01:12 PM   #2
Gen13 F36
Drives: 428i Gran Coupe
Base on what you say 4 yrs from new should be the same just oil change but cost more.
      07-18-2019, 01:20 PM   #3
mastapro
Drives: none
Yea that's what I'm hoping for. I already budgeted for the oil change costing a bit more but I'm just worried about major things like engine.
      07-18-2019, 03:19 PM   #4
Gen13 F36
I have 2016 428i GC, currently sitting at 29k miles going to be 3 yrs old next month. Most of it is oil change and little detail like wiper blade, brake fluid but that's because my car is the last years free maintenance was offered.
Only warranty work done was antenna module due to water got in the shark fin.
The 430i got newer engine...which people say BMW fixes issues found on the N20/26. You should be good
      07-18-2019, 03:48 PM   #5
Solidjake
Shifting
Solidjake's Avatar
Poland
449
Drives: '13 328i Msport 6MT
For the newer models you shouldn't have to worry about much. Suspension components/brakes/serpentine belt/etc as routine maintenance and the rest is just changing all of the fluids on a mileage basis (engine oil, diff, trans, brake fluid)
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      07-18-2019, 05:55 PM   #6
gbca2000
Drives: 2018 440i Gran Coupe
I have an 18 GC with 38K miles and have not had a single issue other than regular maintenance and tires.
      07-19-2019, 09:06 AM   #7
mastapro
Drives: none
Awesome thanks guys. This is really helping me with my decision
      07-19-2019, 10:09 AM   #8
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
We have a 2016 428i GC with 27K miles. It's had 3 oil changes, new set of tires, a/c compressor replaced due to faulty sensor, door lock actuator cable updated per my request, and a speaker screw tightened (rattle). Other than that, it's coming up to the end of the 4 year warranty, so I'm planning on having the dealership do a thorough check at the next upcoming oil change plus brake fluid change. Everything except the tires have been done under warranty service. Your proposed 2017 should have at least another year left of the warranty; if it's a CPO it should have an extended warranty coverage as well.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      07-19-2019, 10:11 AM   #9
PK2348
Drives: 2018 F30 340 xdrive M-Sport
Not to sound like an a-hole, but if you need to budget for an oil change you might be looking at a wrong car
      07-19-2019, 10:51 AM   #10
F30ZHP
F30ZHP's Avatar
Drives: 2018 BMW 340i ZHP
This is definitely a valid point. If you own a BMW you should have the money to cover any sort of maintenance...Just sayin.
2018 Melbourne Red 340i ZHP
Previous BMW's:
2012 Le Mans Blue 335i Coupe / 1990 Alpine White M3
      07-19-2019, 11:43 AM   #11
Gen13 F36
You sound like an a-hole tho, you either don't read or don't understand the OP. The OP came from Japanese brands which to my experience from owning a few is very reliable. You really can get away with just oil change for the first 5 yrs. I'm pretty sure the OP can afford it, just want a heads up on what he/she getting into.
      07-19-2019, 12:35 PM   #12
mastapro
Drives: none
This ^, thanks bro haha. Yea it's not that I can't afford it, I definitely can but when I said "budgeted", I meant that I am prepared for the higher costs of BMW oil changes compared to my car. I just wanted to make sure there isn't something crazy that can cause me to pay thousands per year.
