BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > XHP and shiftpoints
European Auto Source (EAS)
      07-20-2019, 07:47 PM   #1
fantanas
Drives: F33 435d
XHP and shiftpoints
Hello all!
I installed XHP to my 435d a few days ago and was patiently waiting for the 50 miles of learning to finish. The gear changes feel faster and D mode is useful now.
I can see that the car when in S mode it shifts above 5k RPM. My car is still stock and I feel like it is revving too high. Has anybody played with the shiftpoints? Maybe it can be improved. I think stage 3 that I am using is more for mapped cars, so maybe that is why it seems like the WOT shiftpoints are off for my stock car.
Also, has anybody tinkered with the launch control? I am a bit afraid I am going to break something with the x drive, but I think it can help a lot with the acceleration, since with the x drive there is a lot of traction to play with.
Overall I am quite happy with it and it gives more life to the car The main reasons I got it is to remove the torque limiters and to disable the torque converter (earlier at least).
      07-20-2019, 08:43 PM   #2
Hooded
Hooded's Avatar
England
983
Drives: F30 330d M-Sport
Shift points above 5k are not optimum for your car. Try stage 2 instead?
      07-20-2019, 09:29 PM   #3
fantanas
Drives: F33 435d
Reading the description on their website, I feel like stage 3 is what I want. But probably need to lower the shiftpoints until I get a remap. What do you think?
435d xDrive Cabriolet Stage 1
- Gear Display in all modes
- Removed Torque Limiters
435d xDrive Cabriolet Stage 2
- Torque Limiter removed
- Quicker, yet still comfortable shifts in D/Comfort
- Revised, more Driver-Oriented Shift-Points in D/Comfort
- Raised Launch-Control Shiftpoints for Tuned Cars
- DTC and DSC-OFF modes no longer revert to Comfort-Shifting, but activate the fastest Shift-Speeds and the transmission won't upshift at redline in Manual. This is perfect for playing around with your car.
- Retains full ECO-Pro functionality
435d xDrive Cabriolet Stage 3
- Factory Torque Limiter removed. This enables your Tuner to setup his engine tune correctly and prolong your transmissions life!
- Raised Line Pressure for very High-Torque applications
- Even faster and harder shifts in Sport and Sport+
- Revised S-Shiftmaps to make it actually useful for spirited driving
- Torque Converter slip minimized in lower Gears
      07-21-2019, 03:28 AM   #4
The Flasher
Drives: 340i
Hi fantanas
I've been running xhp for a few weeks now and think it's fantastic. It's totally changed the feel of the car for the better and is really easy to use. I'd certainly recommend it for B58 owners based on my experience.
After trying the flashes I've settled on Stage 2 as the best for me. When you have the chance to use Sport it's brilliant. I have found though that the up-shifting is a bit aggressive in D in the lower gears in day to day driving so I have used the shift point editor to calm them down a bit and it's worked very well. It's great how quickly you can change settings to try them.
A tip on using the editor as it wasn't 100% obvious to me from the documentation. You make the changes you want in the app, save them (the app checks you haven't done anything stupid) and then re-flash your map.
So I would say have a play with the editor - just be organised enough to keep a note of what you're trying for reference.
Watsey2424.00
launch control, xhp, xhp flashtool, zf 8hp
