07-15-2022, 02:26 PM | #67 | |
Rep 183
Drives: BMW F36 435i FBO
Fully agree 👍🏻 |
07-17-2022, 12:16 PM | #68 | |
Rep 2,639
1st to 5th https://www.bootmod3.net/log?id=62d4...729b01fc394441 anotha one: 1st to 4th https://www.bootmod3.net/log?id=62d4...0b435d150c757e
alohasurftoad3076.50 |
07-17-2022, 10:28 PM | #70 | |
1296
Rep 3,532
07-18-2022, 06:51 AM | #71 | |
Rep 2,639
Nova Scotia, Canada Temps were 83F, 85% humidity (living next to the ocean lol)
07-18-2022, 10:15 AM | #72 | |
Rep 190,725
07-18-2022, 10:17 AM | #73 |
Rep 2,639
07-18-2022, 10:19 AM | #74 | |
Rep 5,392
07-18-2022, 10:19 AM | #75 | |
Rep 190,725
It would help if you started with a less aggressive map to compensate for the bad fuel quality. If that does not fix your issue, upgrade your intercooler. Running a map with that many corrections is not a good idea.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 07-18-2022 at 11:06 AM.. |
07-18-2022, 02:29 PM | #76 | ||
Rep 2,639
Here's another log, with cooler temps. https://www.bootmod3.net/log?id=62cb...0b43079f4bec0e Quote:
This is also on a ACN91 map too lol
n55david1295.50 |
07-18-2022, 04:39 PM | #77 | |
Rep 190,725
Ambient temps here in Las Vegas are currently 120. If the map is fine, then your intercooler is not fine. You have a lot of corrections But it's your car so I'll butt out, good luck
07-18-2022, 08:54 PM | #78 | ||
Rep 1,148
Lake havasu native about 3 hours away, we usually teeter 5* over you guys there, feels hotter in Vegas from all that concrete and glass lol. For summer I run 91 map with 2 gallons 100 octane to 5 gallons 91 In the event I have to get into boost ( I drive very easy in this heat) my fuel quality won't be a problem but even so have logged with a lot cleaner logs than above, I would get better fuel in summer months with inconsistent timing like that imo. Heat and boost hate each other. |
07-19-2022, 06:16 AM | #79 | |
Rep 2,639
Don't forget to factor in high humidity, it's dry in Las Vegas I've got 280,000km on this car with this setup so I'm not too worried, worst comes to worst if I need to race it, I'll buy a bucket of E98 Ignite and do a E20-E30 mix as my maps are all flexfuel activated. For the FMIC, I may either get the PTF one or VRSF race. But again, even stock turbo, I saw barely an increase of IAT with any FMIC, upgrading to an hybrid, it doesn't matter what intercooler, you'll see a huge spike in IAT once you go multigear, and higher gears. Does anyone have a log of a PS2 or bigger turbo with the VRSF? I'd like to see the IATs.
07-19-2022, 11:57 AM | #80 | |
Rep 7,598
What you said about seeing a spike with mutigear isnt true though, here's a 0-150mph log of mine with VRSF race. No increase in IATs, and i am actually running more boost than in your log it looks like (17-18psi most of it), on stock turbo. https://datazap.me/u/thejeremyman9/d...0&data=4-10-17 Someone else might have a PS2 log with the race. Dont get the PTF, i already posted data about that in that thread. |
07-19-2022, 12:13 PM | #81 | |
Rep 2,639
You'd be surprised, on stock turbo @ 16psi, IAT was barely moving, but on PS2 on the higher gears, it would go higher as you see in my logs, bigger turbo=more air=more work for the FMIC to do for cooling. hybrids will flow considerably more air than stock turbo, which is why they make more power at the same boost and timing as stock turbo, my car made 260whp stock, with PS2 installed, it made 330whp stock tune, my car also made 330whp FBO stock turbo on pump 93, and it made 420whp with PS2 installed. I'm pretty confident that someone with a VRSF race would have a increase in IAT during a multi-gear pull, but just not drastic like mine. TBH, if noone comes forward, i'll buy the VRSF race myself and send logs.
07-19-2022, 01:26 PM | #82 | |
Rep 4,132
All have the intercooler and are on PS2 turbos I believe. But I think your incorrect - a stock turbo is going to generate more heat than a PS2 at the same boost range because the turbo is outside of its efficiency range. Anyhow, i'm just watching
Mods: Yes.
07-19-2022, 01:51 PM | #83 | |
Rep 7,598
07-19-2022, 02:02 PM | #84 | ||
Rep 142
Sold the car last month to move to a M240i so I cannot provide logs
2017 M240i
CD919 Custom E40/flex fuel tune | catless downpipe | TU Pump | XHP Stage 3 | MHD flexfuel kit |
07-19-2022, 02:14 PM | #85 | |
Rep 4,132
Yes it's 16PSI, but stock turbo is in the high 80 in WGDC and he's in the 60s, so yeah he's moving more air (bigger turbine) but his turbo clearly isn't working as hard.
Mods: Yes.
07-19-2022, 02:24 PM | #86 |
1296
Rep 3,532
I'll try and do one this week for you guys.. its been hot here so it should be telling
07-29-2022, 09:37 AM | #87 |
1296
Rep 3,532
I did a 2nd gear to 5th gear run yesterday.. literally 0 data in the log
Its not often I get that opportunity lol
johnung4526.50 |
07-29-2022, 10:05 AM | #88 | |
Rep 5,392
Hope this helps someone! https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
n55david1295.50 |
intercooler, ptf |
