06-11-2022, 05:39 PM | #1 |
Rep 7
Misfires and Issues, Need help pls
About two weeks ago I did a Full Throttle pull while logging MHD. After the pull, the car began to misfire badly and codes began to appear. While driving home it of course sounded like a tractor and would backfire once or twice extremely loud when coming to a stop or letting off the throttle. The original set of codes are in Code Section 1 + the log from literally a minute or less of this all starting.
I borrowed some n54 working coils to see and it felt better, but not 100% there. Still ran rougher but not as bad as day 1. I began to fear loss of compression on cyl5 so Got a tester from Oreilys and got these numbers 1: 180 2: 175 3: 180 4: 178 5: 180 6: 180 Did a compression test on that running n54 I borrowed the coils from and had the same values, just to make sure gauge was reading correct. After that I figure it was coils/plugs so I bought all 6 of each and replaced them today. Still having the issues and car runs in that "better" state but a lot more codes now, still in the same field of what I was with before. These codes are in Section 2 + two logs from idle today and little throttle blips. Listening to the injectors with a screwdriver they all sound to be firing but cylinder 5 is less "clicky" in sound. Not sure if that is because of the DME code saying it shut it off or what (weirdly the plug from cyl 5 will have fuel on it even with that code). It smells very fuel-ly when running today but after a couple start ups, the smoke stopped coming out the exhuast. Please if any tips or where to look I will greatly appreciate it. 2013 F30 335i 93k~ miles FBO STG2+ XHP Section 1: Original Codes after misfire started DataZap Log: https://datazap.me/u/71percent/53120...og=0&data=3-18 Codes from Day 1 of issue 6/1/2022 12:54:04 AM - DME active codes - 102A01 - Hot film air mass meter, signal: Electrical fault. 108001 - Intake air temperature sensor, electrical: Short circuit to B+. 108010 - Intake air temperaturč sensor, electrical: Signal not plausible. 140001 - Combustion misfires, several cylinders: Fuel injection is switched off. 140010 - Combustion misfires, several cylinders: detected. 140501 - Combustion misfire, cylinder 5: Fuel injection is switched off. 140510 - Combustion misfire, cylinder 5: detected. 1C4002 - Engine oil level: Too low. - ME shadow (inactive) codes 108932 unknown 135704 - Valvetronic system: Warning threshold value, feedback control deviation exceeded. 140011 - Misfire: Fuel injection deactivation. 1FB501 - Check Control message (ID 27): Engine oil level! Add engine oil. 231501 - Fault entry: Send buffer full. - Transmission active codes - None —— 6/1/2022 9:02:14 AM - ME active codes None - DME shadow (inactive) codes - 11A401 - Fuel high pressure during fuel injection release: Pressure too low. 11B401 - Fuel high pressure or after enabling injection (2nd ambient condition set after delay): Pressure too low. Section 2: After Plug and Coil replacement DataZap Log:https://datazap.me/u/71percent/61120...og=0&data=3-18 Codes from today after 6 new plugs and coils installed 6/11/2022 4:02:00 PM - ME active codes - 108010 - Intake air temperature sensor, electrical: Signal not plausible. 111030 - Injection system, cylinder 1, rise in current: Too slow. 111031 - Injection system, cylinder 2, rise in current: Too slow. 111032 - Injection system, cylinder 3, rise in current: Too slow. 111033 - Injection system, cylinder 4, rise in current: Too slow. 111034 - Injector cylinder 5, current increase: Too slow. 111035 - Injector cylinder 6, current increase: Too slow. 140001 - Combustion misfires, several cylinders: Fuel injection is switched off. 140002 - Combustion misfires, several cylinders: Damaging exhaust gas after. starting up. 140010 - Combustion misfires, several cylinders: detected. 140302 - Combustion misfire, cylinder 3: Damaging exhaust gas after starting up. 140310 - Combustion misfire, cylinder 3: detected. 140501 - Combustion misfire, cylinder 5: Fuel injection is switched off. 140502 - Combustion misfire, cylinder 5: Damaging exhaust gas after starting up. 140510 - Combustion misfire, cylinder 5: detected. 150102 - Ignition, cylinder 1: Combustion period too short. • DME shadow (inactive) codes - 108932 unknown 140011 - Misfire: Fuel injection deactivation, 21A023 - Combustion engine: Unsuccessful start or engine stopped without driver influence. 231501 - Fault entry: Send buffer full. - Transmission active codes None |
06-11-2022, 08:23 PM | #2 |
Rep 1,597
I'd like to say you may have a badly leaking injector but those electrical problems give me pause. I would have those addressed by an expert before moving forward. Check around the engine bay for damaged wiring.
06-14-2022, 11:52 AM | #5 |
Rep 7,602
n55david1295.50 terryd5150507.00 |
codes, f30, fuel, misfire, n55 |
