02-21-2023, 03:48 PM | #23 | |
Rep 1,818
2NH is SALAPA element and is coded there. (source: https://www.bimmerfest.com/threads/f...ements.966607/)
02-25-2023, 12:45 PM | #24 | |
Rep 481
I have a 335i so that means from the factory I have 4 piston brembo up front, 1 piston bosch rear. If you decode my VIN I do not have '2NH'. I read my VO with E-sys, there is no SALAPA Element for 2NH. Is there any other place to check where this setting would be? I have E-sys on my laptop, so its not too difficult for me to check. |
03-10-2023, 12:18 PM | #25 |
Rep 481
For anyone wondering, it looks like m235i come from the factory 'coded' with 370 mm rotors instead of 340. Found this very old post on 2addicts, where a 2 owner realized his fronts were coded with 370 (despite obviously being 340). So it seems like johnung was right in the sense that, you only need to VO Code 2NH ore HO-WORT with SPBR if you get bigger brakes. No need for FDL coding values.
https://www.2addicts.com/forums/show...3#post19477583 Last edited by rlesko; 06-13-2023 at 11:06 AM.. |
johnung4528.00 |
03-11-2023, 11:01 AM | #26 | |
Rep 99
03-11-2023, 03:44 PM | #27 |
Rep 5,392
03-17-2023, 09:00 AM | #28 | |
Rep 52
Again thanks for helping out if you can! |
03-17-2023, 09:17 AM | #29 |
Rep 495
For pad selection, has anyone switched from the OE Semi Metallic brakes and liked it?
I have the blue 370/345mm brakes, and the original pads dust and squeal so much I think I'm done. I've looked at Akebonos since FCP sells them, and keep getting mixed answers. ATE seems to have a ceramic line as well, but they don't have a front pad set. |
03-17-2023, 12:25 PM | #30 | |
Rep 5,392
I’m a little confused by your parts list. Do you have grey or blue brake calipers now? If grey, is it your intention to just replace your rear 330mm brake calipers & rotors with Brembo 345mm? Or are you also considering replacing your front 340mm with 370mm caliper & rotors? |
nahtanoj116.50 |
03-17-2023, 12:37 PM | #31 | |
Rep 5,392
https://www.bimmerpost.com/forums/sh...php?p=29944561 Avoid Akebono and other ceramic pads. Their performance is no better than average. Hawk 5.0 are by far the best street pads I’ve ever had in every category. Part numbers on attached photo. Replace brake fluid every two years for safety. At the same time upgrade rubber brake hoses to stainless steel to get rid of brake pedal mush and make brake pedal more responsive. Watch FCP prices carefully. They often jack up prices on certain types of items like brake pads to pay for their replacement warranty. I wouldn’t buy pads from FCP. It’s crazy to pay $360 for pads when the same thing is selling for $200 elsewhere. I’ve seen that big of a difference.. Hope this helps! |
nahtanoj116.50 |
03-17-2023, 01:17 PM | #32 |
Rep 495
Yeah I should try re-lubricating everything with ATE plastilube before changing pads. The pedal feel and durability of the OE pads are very good, I still have 1/2 or 3/5th life left in them.
Update They're disgusting View post on imgur.com Last edited by AspektUSA; 03-17-2023 at 06:05 PM.. |
03-17-2023, 07:59 PM | #33 | |
Rep 52
VIN - WBA8B7C51JA583300 I have grey front calipers and grey rear "square" calipers all that look like warn aluminum (aka ugly) I believe you were suggesting I have the option to paint my front 340mm grey calipers and buy rear calipers, but I will probably just buy new front and rear calipers since I plan to keep the car for a while and it only has 30k miles on it. I am definitely going to replace the rear with the Brembo 345mm and the front with the 370mm. Looks like these will be expensive but having the part numbers will help me be sure I have the right ones. Do I have a color option on these? And do i need new splash shields too on the front? Wondering if buying the BBK and then selling the front rotors might make sense? Also, I will need to part numbers for the StopTech rotors. I saw the photos you posted for the brake lines and pads so thanks for that info! Thanks for your help johnung! |
johnung4528.00 |
03-18-2023, 10:36 AM | #34 | |
Rep 5,392
You can sell your stock calipers and rotors. The F340/R330 setup is a nice brake upgrade for anyone with an F3x that has non-Brembo front brakes. There are three caveats. 1) their car must have factory rear e-brake that is 185mm, not the smaller 160mm. That’s easy to check with their VIN. See photo. 2) After installing they must have their brakes coded (to S2NH) with the e-sys application. Easy for any BMW mechanic to do in 1/2 hour. 3) With 185mm e-brakes they probably already have the larger rear dust shields which is easy to check in realoem. If not the new rear dust shields need to be cut before bolting them on. Very easy to do as per attached photo. If larger front dust shields are needed they just bolt on. The most valuable component is your front Brembo 340 grey calipers. They sell used for $450-$550. The rear 330 Bosch calipers might get you another $50. Both sets of rear rotors might get you $100-$200 more but shipping heavy rotors is so expensive that you’ll need to advertise in local BMW forums to try to avoid needing to ship. The F370/R345 calipers come in Blue from the factory as “M Sport Brakes”. This is the most likely color to find used. The exact same calipers are also sold as “M Performance Brakes” through BMW aftermarket parts. They only come in Red, Orange and Yellow. They are more scarce to find on the used market. A used set of F370/R345 calipers is typically $1100-$1250 in good to excellent condition. It’s easy to change brake caliper color yourself with G2USA Caliper Paint. Or by having them powder coated which takes longer and is more expensive. Buying just the four calipers individually new would cost over $3,000, discounted. So new is not a good option. They sell the M Performance Brake kit. See link. It costs over $2,000 discounted. It comes with new calipers, new very noisy dimpled & slotted front rotors, just average BMW pads and no rear rotors (which must be purchased separately. If I couldn’t find a used set and had to buy the MP kit then I’d sell the front rotors and set of F&R pads as new. And buy Hawk 5.0 pads and full crossdrilled rotors. .https://www.getbmwparts.com/oem-part...ed-34112450468 Note: There is also a full floating 370x30 full crossdrilled rotor from Paragon Brakes that is an upgrade to the StopTech full crossdrilled in the photo. I’m going to post more about Paragon this weekend Hope this helps! |
nahtanoj116.50 |
03-21-2023, 12:23 PM | #36 | |
Rep 52
"BMW recommends having the brake/DSC module re-coded to match these bigger brakes. This can be done at the BMW dealer." Is this needed for my particular setup, where I am going from F340/R330 to F370/R345? Thanks for all of your help!! |
03-21-2023, 12:43 PM | #37 | |
Rep 5,392
nahtanoj116.50 |
03-22-2023, 08:27 AM | #38 |
Rep 52
Hi again Johnung. Will a 225x45x18 wheel be a problem with these larger brakes/rotors? How about my winter wheels which are 17s?
03-22-2023, 10:04 AM | #39 | |
Rep 495
17" is likely a no go on that size of brake disc as well. |
03-22-2023, 10:15 AM | #40 |
Rep 52
Ok. My Factory wheels are the 400M wheels pictured in this URL so those should fit right? https://www.turnermotorsport.com/p-6...RoCyAYQAvD_BwE
03-22-2023, 10:30 AM | #41 | |
Rep 495
My winter set is 400m 18" on Pirelli Sottozeros, my summer set (OE with the car) is the 19" 442m on S001s. |
nahtanoj116.50 |
03-22-2023, 11:14 AM | #42 | |
Rep 5,392
If you test fit a wheel, Brembo specifies that there’s at least 3mm of clearance between brake components and the wheel’s barrel and spokes. Too little clearance risks road debris like rocks and sticks getting caught and scratching up wheels and brakes. Quality wheel manufacturers can tell you if brakes will fit. For example, APEX does laser scans of all of the BMW brake systems in the BMW car’s wheel well, plus they laser scan many aftermarket brake kits. Before I ordered a specific APEX 18” wheel model, I told them that I had BMW Brembo F370/R345. I also told APEX which aftermarket brakes I could potentially install in the future. They told me that all of the brake kits that I asked about will fit. That gave me even more confidence in ordering APEX wheels! Photo shows the APEX wheel setup that I chose. Hope this helps! |
nahtanoj116.50 |
03-29-2023, 10:29 AM | #44 |
Rep 592
