BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
European Auto Source (EAS)
      01-24-2020, 01:18 PM   #2729
JaredG_F30
JaredG_F30's Avatar
953
Drives: 2014 335i, M-Sport, Manual
You can use your iPhone, I do as well as many others, but you need the WiFi agent. You can build one for like $60.
Originally Posted by BradMacklin View Post
I was saying I'd rather run it on my iPhone than Mac since I hate Mac. I know it will work with the laptop.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      01-24-2020, 01:21 PM   #2730
JaredG_F30
JaredG_F30's Avatar
953
Same here. I went through 3 test maps with Halim with no real improvement. I sent him the log from test map 3 on Monday and haven't' heard back from him. I switched back to v6.4.
Originally Posted by trialmountain View Post
Further update on my v7.0 STG 2 ACN OTS saga. PTF suggested I run a 10% boost reduction across all gears to help. Now I'm seeing HPFP crash, overboost to 20 psi and 2nd cylinder timing is not keeping up as well as others. Any thoughts? Time to just get a custom tune?
BMW DIY Guy did you have any trouble with the 92 octane in WA like I am having?
http://www.bootmod3.net/log?id=5e2860b3ae729b14d8182f62
      01-24-2020, 01:27 PM   #2731
JaredG_F30
JaredG_F30's Avatar
953
HCP is Halim's side gig. I believe HCP is his initials. Halim and Dzenan started Pro Tuning Freaks (PTF) who developed bootmod3 but they also both tune. So yes, the OTS maps are made in house either by Halim (HCP) or Dzenan.
Originally Posted by 5soko View Post
Someone mentioned HCP, but i guess bm3 does the OTS maps in house it seems, as i cant find any info on it.
ronanz1662.50
5soko248.50
      01-24-2020, 08:32 PM   #2732
OUGrad05
Drives: 2010 Corvette, 2015 335i
Ok guys I have a charge pipe and TIC pipe ready to go on the car along with exhaust on the 31st. Appt is set with the shop. I've also got all my bootmod3 stuff ready to go. Would you wait and flash to stage 1 after install of hardware just to make sure you don't blow a CP or something in the meantime?
2015 335i M-Sport
2015 Lexus RX
2010 Corvette Grand Sport
      01-24-2020, 08:36 PM   #2733
thejeremyman9
Drives: 2015 BMW 335i
Yes wait. Stock CP is a ticking time bomb.
Also, highly recommend getting an intercooler... although i guess technically that is easy to install yourself even after you have the TIC and CP installed. Not sure why you opted for a TIC but not an IC?
Also, i would recommend logging before your CP+TIC install, after your CP+TIC install, and then after the install and flashing the tune. That way, if you are seeing something off (mostly boost off target because of a leak), you know when it happened.
      01-25-2020, 09:39 AM   #2734
5soko
5soko's Avatar
249
Drives: M5
Thanks for clearing that up.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i
Previous: E92 N54 335i ||| FBO E90 LCI M-Sport 335i N54
      01-25-2020, 01:19 PM   #2735
OUGrad05
Hey guys, having issues getting this to work. I've downloaded the agent to my Mac, but it won't run.
It says “bootmod3 OBD Agent Installer__0.10.092.app” can’t be opened because Apple cannot check it for malicious software. This software needs to be updated. Contact the developer for more information."
Any ideas? I'd like to do some logging but the agent won't run.
Edit also, I am using my android phone and the wifi agent and can connect, but my dashboard is blank, and I can do no data logging. It says it's not configured if I hit the + sign it is asking me for channel numbers. The dropdown is blank. Looking at the tutorial it seems as if this dashboard auto populates as they went through no setup and it was all just there.
2015 335i M-Sport
2015 Lexus RX
      01-25-2020, 02:37 PM   #2736
F36GC_NYC
Drives: 2016 EB 435GC xdrive
seems like your anti virus is blocking something?
there is a way to allow 3rd party equipment to be installed and run on mac, google that real quick should help you out.
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust 102mm diamond black tips
      01-25-2020, 02:49 PM   #2737
OUGrad05
I don't have an anti virus. And yes I install stuff on my Mac all the time, much of it third party.
Edit: it wasn't the firewall or antivirus, both of those are shutoff. It was oddly enough the more stringent file checking in the new OS. I was able to get around it.
Now on to fixing the dashboard issues
2015 335i M-Sport
2015 Lexus RX
      01-25-2020, 02:58 PM   #2738
F36GC_NYC
but unless u have that feature turned off, it will keep interfering(this is my guess on what is happening) otherwise you have to do it manually each time for the Operating system to install whatever you just downloaded.
      01-25-2020, 03:02 PM   #2739
OUGrad05
It is turned off, but the OS still forces the check, I've added the app to the approved list, an extra step. Appreciate the help!
2015 335i M-Sport
2015 Lexus RX
      01-25-2020, 03:05 PM   #2740
F36GC_NYC
ya mac is funny like that, BUT i think thats the hold up, it should allow you to install.
Make sure the agent is up to date and let the logging begin!
      01-25-2020, 05:09 PM   #2741
OUGrad05
Having issues. The agent on my phone through the OBD wifi box won't allow me to see any dashboard settings or data logging settings. However, on my laptop I can see the dashboard and add things to the dashboard and create data logs.
If I do this and then log back in through the phone I can see the data logs but can't create them or see dashboard items.
Items to note: I have reinstalled BM3 on my phone, I have unplugged the negative battery terminal on the car for 10 minutes, have updated the agent twice and restarted, still no dice on the phone. Probably need a help ticket.
2015 335i M-Sport
2015 Lexus RX
      01-25-2020, 05:14 PM   #2742
F36GC_NYC
yes this sounds beyond the scope of what i know...
truth be told im new to coding as well...however i didnt have any of these issues with the app. The gauges came up although i didnt try to change any of them as im still learning what is what... and i had no issues logging either, the only issue i did have was the copy link to share my data log, but i found a work around for that.
FYI i am using an iPhone with the obd wifi agent connected via enet cable.
reach out to PTF they are quite responsive atleast from my experiences..keep in mind its the weekend so the response might not be as quick. or even until Monday.
      01-27-2020, 06:23 AM   #2743
ChristosD
ChristosD's Avatar
South Africa
78
Drives: m135i
How is everyone finding the v7 maps (the FB bm3 page seems to be littered with issues with regards to v7) I have been dailying the stage 2 91 map and haven't picked up any issues, so far logs look good. Low range torque seems to be ever so slightly better, however not sure if its placebo but i think there is still a faint bit of hesitation.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// GFB DV+ //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 OTS STG 2 93 AGG//
      01-27-2020, 08:19 AM   #2744
OUGrad05
I will be running stage 1 and 91 octane but haven't downloaded the map yet. Looks like I have a couple options of 91 octane stage 1.
2015 335i M-Sport
2015 Lexus RX
      01-27-2020, 12:39 PM   #2745
JaredG_F30
JaredG_F30's Avatar
953
Can you post a log?
      01-27-2020, 12:44 PM   #2746
thejeremyman9
There are numerous people here who ran into issues (e.g., overboost, HPFP crash, etc) - just check this thread, the BM3 v7 thread, and i think the "do these look good" thread. I think a lot of people switched back to 6.4
      01-27-2020, 04:46 PM   #2747
romemedrano
Drives: BMW F30
Phantom10R this your spot to shine also!
      01-27-2020, 04:46 PM   #2748
romemedrano
Drives: BMW F30
Phantom10R and JaredG_F30 including myself have had some issues all on V7.0 we switched back to V6.4
      01-27-2020, 05:50 PM   #2749
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
Yep... Hard pass on 7.0 for me right now.
Whats funny is, from a roll im okay. fuel pump and boost looks good through the gears.. but a solid single gear low rpm fuel all hell breaks loose.
Im gonna wait and see if any more revisions come out or when the weather warms up here Im gonna try again and see what the logs say. I think there was a guy in Puerto Rico who had decent luck with 7.0 but its warmer there.
2015 335i xDrive
2015 X3 x35i
IG: @N55David
      01-28-2020, 12:00 AM   #2750
Erics440i
Drives: BMW 440i MSport Coupe
Can someone explain what the difference in the Octane is between the tunes? How would I know if I need the 91 octane map or the 93 octane map?
