07-08-2020, 07:38 PM | #1189 |
Rep 585
Nice time for the DA and slope
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
yokata156.00 |
07-08-2020, 07:46 PM | #1190 | |
Rep 585
VTT GC turbo on E30 would be nice
07-08-2020, 08:17 PM | #1191 |
Rep 57
Here's another log from tonight. Experiencing some serious rev hang, can anyone please offer any insight on what to look for? Just a con of using a manual tranny?
https://www.bootmod3.net/log?id=5f01...90c607ae580c24 |
petrosexxual20.50 |
07-08-2020, 08:58 PM | #1192 |
Rep 452
07-08-2020, 11:57 PM | #1193 | |
Rep 106
Sport+ only no pressing DTC etc. And go manual ...otherwise the car can downshift when you floor it. You can also go to redline in 4th and do one shift to 5th and continue to redline.
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
07-09-2020, 12:09 AM | #1194 |
Rep 106
Guys ! M140 costume tune with Dorch stage 2. One thing I wonder..Is it tuner who sets rail pressure ? Or he just "play" with timing and boost ?
My friends car, they hoping to go E50,now he running E38. Boost is crazy high and rail pressure is down to 2232 at one point. Stock turbo ! i was scared at 22 psi but this look strange.. https://datazap.me/u/pellepirat/dusa...og=0&data=3-19
07-09-2020, 02:09 AM | #1195 | |
Rep 585
Are you sure this is a Dorch Stage 2 HPFP? Mentions Spool in the file name in the log? This would be a walk in the park for a Dorch Stage 2 I wouldn't be surprised if it was a Spool FX-150, they don't seem to flow as well as claimed, however, this may be just a tuning issue in the tables related to fuel supply solenoid timing. The tune looks like it still needs some work, load required and load limits will be adjusted down, there's a torque limiter active from 3500 - 5000 RPM as actual load exceeds target and throttle closures assisting to reduce actual. Overall it looks OK and should go pretty well Should log target rail pressure too.
theone197360.50 |
07-09-2020, 02:33 AM | #1196 | |
Rep 106
Thx for explaining once again
07-09-2020, 02:59 AM | #1197 |
Rep 242
Thats the log from the dyno big timing corrections and high IAT but car makes 491whp today again with shit top end https://www.bootmod3.net/log?id=5f06...0b4307001536c9
OzBMR574.50 |
07-09-2020, 05:28 AM | #1198 |
Rep 192
Hi everyone!
I'm going crazy with the timing pulls on my car. Tried all stage1 BM3 maps, but the car also does it with the stock tune... Less, but it's still pulling timing It's an M140i, 45.000 miles on the clock, 93octane gas from reputable gas stations. Stock tune: You can see there are already corrections in place... And also, isn't the stock map supposed to target much higher timing advance? https://www.bootmod3.net/log?id=5efe...90c67f338e8b67 https://www.bootmod3.net/log?id=5efe...729b7db9fa96a3 BM3 91octane ACNI (low quality gas map) https://www.bootmod3.net/log?id=5f06...90c62825d99888 https://www.bootmod3.net/log?id=5f06...729b45a472f8c6 BM3 91octane (Standard 91oct map. Massive, constant corrections https://www.bootmod3.net/log?id=5efd...90c615fc46da18 https://www.bootmod3.net/log?id=5efd...0b4368f54bfd36 (sorry for the crappy log, forgot to stop the logging) BM3 93octane https://www.bootmod3.net/log?id=5f06...729b45a472f8dc https://www.bootmod3.net/log?id=5f06...729b451dd832b5 Corrections happen all over the rev range. I contacted BM3 and they told me it's bad gas, but I've filled up several times, every time in the biggest brand-name gas stations in Spain, so I find it a little hard to believe. This is compounded by the fact that that stock map also has low timing targets and even then it's still getting pulled... I'm thinking spark plugs next (they should have around 15.000 miles on them, so it shouldn't be time to replace them yet) but after reading through the first 20 pages of this thread or so, it appears that they help somewhat with the timing pulls but I'm not sure they're gonna fix the MASSIVE correction that's happening here. At first I though it was the scorching temperatures we're having in Madrid at the moment, close to 39ºC (more than 100ºf), so I started taking the logs at night when they are closer to 25ºC (77ºf) and it did improve somewhat, but it certainly didn't go away... What else could it be? I'm starting to run out of ideas, and getting desperate... Thanks! |
07-09-2020, 06:01 AM | #1199 | |
Rep 106
So low timing..how is the power in the car ?
07-09-2020, 06:34 AM | #1200 |
Rep 192
It seems okayish with the stock tune, but it doesn't seem to pull quite as hard as a friend's brand new M140i. It feels pretty smooth, but not as smooth as it should be almost certainly due to the timing corrections.
BM3 maps all feel marginally faster, but they ran 10.5second 100-200 pulls and they should be down in the 9.5second range, so VERY down on power. Considering that each degree the timing is retarded costs around 10-15bhp, it's no surprise... |
07-09-2020, 07:09 AM | #1201 | |
Rep 585
Do you have access to E85/ethanol? If so, add some ethanol to your fuel and re-test the Stage 1 91 tune and see if it makes it better.
07-09-2020, 09:53 AM | #1202 | |
Rep 192
Perhaps 95oct fuel has spent less time in the station's tanks and is this fresher... I might try a tank of 95 with both stock and 95oct stg1 maps |
07-09-2020, 01:20 PM | #1203 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
New logs are up for rev 1.7.
https://datazap.me/u/tnilson/pure800...og=0&data=4-22 From my very basic understanding it looks like he's pretty much solved the boost overshoot/wobbly boost. Timing corrections are basically non-existent or at very low boost/rpm. Timing is hitting 16 by 6K rpm. I asked him a few other questions about what other things he's looking at and what his objective is for the next couple of revs. I'll let you know what I hear back.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
07-09-2020, 02:49 PM | #1204 |
Rep 125
https://www.bootmod3.net/log?id=5f07...90c62825d99bf5
E30 bm3 stage 2 I autologged this one so I think it starts late into first but I went all the way through 5th
2012 335is-stage 2 plus VTT turbos, catless, DCI, stage 2 LPFP, 2 inch inlets and outlets, VRSF CP with Tial BOV, VRSF 7.5 inch race intercooler, 3.5 bar map sensor, RB PCV valve
07-09-2020, 05:05 PM | #1205 | |
Rep 242
07-09-2020, 05:06 PM | #1206 | |
Rep 242
07-09-2020, 05:08 PM | #1207 | ||
Rep 125
07-09-2020, 05:11 PM | #1208 |
Rep 242
Me after hard pulls can see in real time how the IATs is going down when i start driving easy, if you stay in one place cant cool down that fast from my experience.The best option for cool down is just cruise around with around 60mph after hard pull
07-09-2020, 05:27 PM | #1209 | |
Rep 125
07-09-2020, 05:30 PM | #1210 |
Rep 242
