07-01-2019, 07:28 PM | #1 |
Rep 5
Display NO SIGNAL
Hello Dear Forum & BMW "User"
I'm writing here now, because I have a problem with the Android Display 10.25 " and i Feel kind of desperate... When I try to get to the original menu I get a "No Signal" on the left side ,,,, and on the right side several blue lines and 8L (8 liter tank left probably, which is true). I tried in the settings to select me almost same model (F4x half screen 6.5 ") as I have. Then comes the explained “no signal” left side ,,,, and right side blue lines + 8L. If I, however select Fx4 6.5 "fullscreen, I get a no signal in the middle of the Screen. ,,, at the right side there is nothing this time! Have a F31, built 2016, and had the little RADIO professinal WITHOUT navigation. I do not even have an optical audio cable. Have no camera installed or other optional festures. The PDC (at the back, because I have only factory at the back) work, but a bit slow but they work ... Anyone here has a solution, Or what could I do? I am so desperate ... please help me..... |
07-02-2019, 01:36 AM | #2 |
Rep 584
I'm no expert but I'd start by making sure all the quad lock connections are still nice and firm. After that you'll need someone who knows what they are talking about!
Mick |
07-02-2019, 10:22 AM | #3 |
Rep 3,016
Drives: 2019 M2 Competition
Any time I have seen this issue of "no signal" it was the cable was loose, even just by 1/16th of an inch.
Also, its maybe possible (depends if you car could have the 8.8 screen in the first place) to code your car from the OEM 6.5 screen to the OEM 8.8. *IF* those options are in your car code, you can use something like Bimmercode to flip that option on. That will cause the Idrive screen to be FULL screen for you, rather than half screen with the info panel (blue lines and fuel etc) on the right. It HAS to do that with the OEM 6.5 because stretching that screen out to 10.25 would look awful. So... 1. Check your cables, always been the issue I have seen for no signal 2. Check your car options with bimmercode or similar to see if you can flag to 8.8 OEM screen. The "expert mode" code lines you need to change are here on the forums.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
Tags |
android, display, idrive |
