BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Best Oil for our N55 Turbo Motors?
      03-05-2018, 06:00 PM   #45
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Originally Posted by Orion4 View Post
Wonder why while all the rest of sample read below or right at the Universal Averages, Manganese, Titanium, Magnesium and zinc read high? Are they considered sacrificial elements in engine performance?
You can read an explanation to the different elements on Blackstone webpage.
(A Dane in China)
      03-06-2018, 07:37 AM   #46
AshlandTE87
Drives: 2015 335i M-Sport 6sp
I like to change the oil midway through the dealership maintenance schedule....approx. every 5-6k miles. Late last summer when I went to change it again and went to the dealership to buy the BMW (Shell) 5w-30, I was informed they were out as BMW now uses 0W-30. So I asked the guy at the parts counter (who I know) what he thought of the change as he drives an F10 with N55, JB4, FBO. Said he car now eats a quart every 3k miles because it's so thin but BMW went that direction due to normal MPG pressure from the gub.
So I didn't buy and went on in search of Shell Euro 5W-30 which is LL01 but only to find out it is only offered (in the US at least) in 55 gallon drums. Maybe that has changed but I have yet to see any of it in a 5-qt or qt bottle. So I ended up going with Shell Euro 0W-40. The lack of LL01 certification drove me crazy but I convinced myself to move forward with it due to the certification it carried for MB, Porsche, and the two VW specs that are usually also listed on oils that carry the LL01 cert. Soooooooooo, I thought if it meets these same specs for the other mfg's that LL01 oils also meet then I can't be doing any harm to the engine by using it.
After reading the thread which is basically a freshening of a much discussed topic, I am hopeful that the Shell Euro 0W-40 gets LL01 soon just to pacify my brain. The car ran great with the oil but the lingering question persists.....is this oil actually good enough even though it meets these other high performance specs. Ugh!
      03-06-2018, 01:54 PM   #47
Polo08816
Drives: 2014 335i M Sport
Why not just get Castrol Edge 0w-40 which is LL-01 certified and available at Walmart for $26 for 5 quarts?
I change it every 5,000 miles so I'm not worried if it's not the absolute best snake oil available.
harkes1078.00
jh_f301307.00
      03-07-2018, 07:28 AM   #48
AshlandTE87
I did consider the Castrol as I've been using that in my E39. I guess it's because I've boughten into the Shell PurePlus gas to oil as having superior lubricating and thermal characteristics. At least that seems to be how it's marketed. Plus, BMW has switched to it (maybe only due to price idk).
      03-07-2018, 03:20 PM   #49
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Mobil 1 0W40 since my 540i days
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
sspade2466.00
      03-07-2018, 04:09 PM   #50
Schmidty_
Drives: 2014 F22 M235 2012 E70 X5M
2005 330I ZHP  [0.00]
2014 BMW M235i  [0.00]
2012 E70 X5M  [0.00]
Motul 8100 X-Max 0w40
in both the M235 N55 and E70 X5M S63
      06-10-2018, 01:12 PM   #51
Musashi
Drives: BMW 335i XDrive Laguna Seca
Originally Posted by F30RiK View Post
liqui-moly leichtlauf high tech is LL01, I just checked on my jug.
https://products.liqui-moly.com/leic...h-5w-40-5.html
Yes, but not 0W40 for 0- to -40C climates.
      06-23-2018, 04:40 PM   #52
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Originally Posted by badbread View Post
Here's mine with over 10k miles on BMW oil:
And this is another after I added a magnetic drain plug. As you can see the oil test reflects the plug being added:
A side effect of using that drain plug is that you won't have an accurate picture of what metals are in your oil. So if it's shedding a lot of metal you might not be aware since it won't show up in the report and your drain plug is catching it.
badbread332.50
      06-24-2018, 08:37 AM   #53
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
You can always check the PDS of the 0w40 in other countries (eg UK). It appears that for marketing reasons oil companies will sometimes not list all of the OE approvals on a label.
Shell's GTL product (BMW label or otherwise) is top knotch.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
123Britt289.00
      10-13-2018, 08:46 PM   #54
blakep8
blakep8's Avatar
Drives: 2014 Black F32 435i
I have to add a quart of oil to my car... I used liqui molly at the oil change and I don't want to order another 5L just for 1 quart. If the weight is the same can I use a different brand
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram
      10-13-2018, 09:10 PM   #55
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Castrol Edge 0W-30 Euro Formula for me. Car loves it.
      10-13-2018, 10:58 PM   #56
FastF30
FastF30's Avatar
521
Vargas oil recommendation....
http://performance.vargasturbo.com/products/
      10-14-2018, 07:59 AM   #57
cosmicdebris48059
cosmicdebris48059's Avatar
Drives: Estoril Blue 2014 335i M Sport
Technically, it "probably" won't hurt as long as it's a synthetic of the same grade, but I personally wouldn't want to make a habit of it. I always like to have extra in case I need to add some in between oil changes. Have you noticed any difference using the Liqui Moly?
      10-16-2018, 02:00 PM   #58
simplebimmer
Drives: F30
So far been using 0w-40 from wal mart...no issue filter i used oem.
Polo088161610.00
      10-17-2018, 11:35 AM   #59
TSA8151
Drives: 2013 F30 335i msport
I often had to top off my oil between oil changes with warranty oil change. Once I switched to royal purple my car stopped needing top offs between oil changes.
      10-20-2018, 03:30 PM   #60
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Again Amsoil or nothing at all!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      10-20-2018, 11:53 PM   #61
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Best oil is the one that gets changed often. Thread closed
Lemania 2320
Polo088161610.00
      10-21-2018, 09:33 PM   #62
AGONXF30
AGONXF30's Avatar
Drives: 2012 335i S-Line/Melbourne Red
I use Castrol 0W-40 and I found it to last longer than BMW Shell product from the dealer. Generally my car burns a 1/2 quart to a quart at around 8K miles with the Castrol. With the BMW LL oil I was burning a quart as early as 5K miles. Basically the BMW oil was breaking down sooner. I stick to Castrol and 8K or so oil changes.
      10-22-2018, 08:26 AM   #63
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
That's not what it means but OK.
      10-22-2018, 11:16 AM   #64
AGONXF30
AGONXF30's Avatar
What does it mean JR? Enlighten us with your fluid dynamic expertise.
      10-22-2018, 01:09 PM   #65
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
You're applying an oil performance term (IE. last longer) to describe oil consumption. Oil consumption has nothing to do with oil oxidation (i.e. breakdown).
      10-23-2018, 12:57 PM   #66
lo_xyooj
lo_xyooj's Avatar
57
Drives: Alpine 335i
My maintenance ended 10/1. I just did my oil change over the weekend and put in Liqui-Moly 5w40.
