09-10-2018, 04:19 PM | #23 |
Rep 5,392
09-11-2018, 08:58 PM | #24 |
Rep 523
Bootmod3 recommends the NGK 97506's gapped to 0.02". I cant offer anything more than a link.
https://bootmod3.atlassian.net/wiki/.../pages/2558945
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
johnung4528.00 |
09-12-2018, 09:22 PM | #25 |
Rep 801
My NGK 97506’s just lasted 4k miles. Crazy misfires on the dyno today. 2014 335xi, 411awhp/502awtq @ 18psi, FBO, 93 and meth. I had to pull the plugs on the dyno, re-gap them (they moved to .025 from 0.20) down to .018. Helped for a few more pulls but misfires came right back.
Do I stick with the 97506’s? Last edited by HKD126; 09-13-2018 at 07:26 AM.. |
09-16-2018, 10:07 PM | #26 |
Rep 547
I've been running the NGK 97506 gapped to .030 on my FBO MHD stage2+ tuned 435i for about 7k miles now and have not ran into any problems. Max boost is about 16psi tho, and I've been running mostly full 100 octane fuel so not sure if that has anything to do with it.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
09-16-2018, 10:19 PM | #27 | |
Rep 740
johnung4528.00 |
09-17-2018, 11:44 AM | #29 | ||
Rep 5,392
09-20-2018, 01:47 PM | #31 |
Rep 5,392
09-27-2018, 04:38 PM | #32 |
Rep 821
Drives: Bmw 335i f30 N55 ( sold)
My car has 59k miles. Files rough also. I never thought sparks may be an under lying issue. If I plan to flash tune would sticking with the bmw oem be fine or should I do what others are saying and gap them?
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
09-27-2018, 08:10 PM | #33 |
Rep 1,827
I think it depends on the aggressiveness of the tune. I would ask whoever is doing your flash what their recommendation is.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
Tpriest7893216.50 |
09-28-2018, 08:52 AM | #34 |
Rep 775
Have read many spark plug threads over the years. Unless you're pulling over 18psi, stock plugs are 100% fine. Actually they seem to be fine until you hit 21psi and higher. New sparks and maybe wires too just for the heck of it due to your mileage... while you're in there you may as well do the wires. JMHO
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
Tpriest7893216.50 badbread332.50 |
09-28-2018, 10:43 AM | #35 | |
Rep 821
Good point! Just for the miliahe I will deff do the spark plugs, stock does seem fine. When I do the flash tune I'll double check with the company and see what they recommend. I don't think my psi will be that high. I plan on just doing stages 2 tune and keeping it there. Just a fun daily. I appreciate the responses!!
2012 bmw 335i sedan
badbread332.50 |
10-02-2018, 02:50 PM | #36 | |
Rep 5,392
The general consensus that I have received seems to be to use an NGK5992 (discontinued) or NGK95770 (its replacement). These are considered to be the same heat range as the stock Bosch plug. But people with tunes added to their car usually gap them down to 0.022" Rule of thumb that I was told in tuned cars is to replace Bosch plugs every 20K-30K miles. NGK plugs should be replaced every 15K-20K miles. With 60K miles on your car I would think that you would want to replace the coil packs at the same time. I've seen heavier duty coil packs advertised but haven't researched them on the forum so not sure if they would apply. Hope this helps. |
Tpriest7893216.50 |
10-02-2018, 03:53 PM | #37 |
Rep 93
10-06-2018, 07:34 PM | #38 |
Rep 808
It's been posted to death but count me in favour of the 97506's as well. I am bootmod3 stage 2 and sometimes run E30, car is smooth as hell and timing looks solid. I have better timing and fewer knock events (very rare now) than I did on stock plugs with same configuration (FBO)
johnung4528.00 |
10-07-2018, 06:48 PM | #39 | |
Rep 5,392
10-07-2018, 07:31 PM | #40 | ||
Rep 808
johnung4528.00 |
10-14-2018, 04:21 PM | #41 |
Rep 1,499
I ran the NGK 97506 for about 20k miles and recently the car was idling a bit rough and didn't seem to pull as hard (I should have logged) so I swapped them out for new stock BMW plugs (P/N 12120037582 that had been given to me by the dealer. plug 1 measured 0.027" gap, 2-3 measured 0.028" gap and 4-6 0.027" out of the box. I torque them to 18 ft-lbs. Below is my log. I'm running bm3 stage 2 93 octane OTS tune version 6.1. Loog looks super clean and timing is good. Timing advances to 10 degrees in the upper RPM range. I may get into the low teens with an E30 mix running the E30 map. I'll mix some E85 in the next fill up and see how that logs. Log below.
http://www.bootmod3.net/log?id=5bc3ace0d10b434f3ca86830
johnung4528.00 |
10-14-2018, 05:53 PM | #42 | ||
Rep 5,392
12-12-2018, 04:50 PM | #43 |
Rep 516
https://www.ebay.com/itm/6pcs-Bosch-...4383.l4275.c10
any thoughts on these? I typically shy away from too good to be true scenarios, and shipping from China/HK/Taiwan doesn't make me feel any better. 1/2 price is tempting, anyone gone in on something like this?
07 e90 335i 13 mk6 GTI 13 f30 335i |
12-12-2018, 05:46 PM | #44 | |
Rep 1,827
