12-06-2019, 12:21 AM | #1409 | |
Rep 63
Inverted colors is another problem with software decoding besides image being cropped. I has something to do with Software decoding as with HW decoding it doesn't invert colors. |
12-06-2019, 03:02 AM | #1410 | |
Rep 80
Amazing... Thank you soo much for this guide, i dont have studies of programing and soldering, but i see this can be only with a cic controller? In my case, i will prefer to do it with a ccc controler (with one button), because my car is a 1 series e87, and i have yet the controller installed on my center console, but it is not connected with anything of the android radio; soo thats the reason because i want to make it working with this controller.. I only know that when i try to wire the 4 pins of the ccc to the android radio, i use the quadlock of the radio profesional with the pins (15,12,9, and 11), and the light of the ccc knob light up when i activate my lights, soo its mean that it is connected, but it doesnt make any answer in the android radio.. that´s actually my problem... Could be a software program of the android radio that can be ''easily solved''? Before buying an cic knob an arduino piece, i want to solved this if i can, because if i do this, i need to pay a lot of money in pieces, because i need to adapt this to my central console and in spain the pieces of this is really hard and very expensive.. Thank you soo much for the answer, i really apreciate it! |
12-06-2019, 04:14 AM | #1411 | |
Rep 6
And it's not that expensive, I spent around 70€. Anyway, mine only worked when it received an init message and then it has to be polled in a loop. This is done by the Particle Photon. It's not as simple as just connecting it and expect it to work. The init message to activate mine was: Code:
initMessage.id = 0x273; initMessage.len = 8; initMessage.data[0] = 0x1d; initMessage.data[1] = 0xe1; initMessage.data[2] = 0x0; initMessage.data[3] = 0xF0; initMessage.data[4] = 0xFF; initMessage.data[5] = 0x7F; initMessage.data[6] = 0xDE; initMessage.data[7] = 0x4; Code:
pollMessage.id = 0x501; pollMessage.len = 8; pollMessage.data[0] = 0x1; pollMessage.data[1] = 0x0; pollMessage.data[2] = 0x0; pollMessage.data[3] = 0x0; pollMessage.data[4] = 0x0; pollMessage.data[5] = 0x0; pollMessage.data[6] = 0x0; pollMessage.data[7] = 0x0; This would have been much more difficult if it wasn't for this guy Jumpmaster: https://community.particle.io/t/phot...r-canbus/47643 I contacted him and he even gave me tips I wouldn't even need the android app because the Photon can emulate an HID usb device, meaning it could work as a keyboard. But then I'd lose all the costumization on the android side. As I said, this is not easy. But it became kind of a personal project and it was really satisfactory when I finally achieved it! |
12-06-2019, 06:36 AM | #1412 |
Rep 80
Thank you for the reply!
At now, i am trying to update my android radio (px6), and when i want to install an update, the radio doesnt recognize the usb and the update. I rename the .rar to px6.rar, but doesnt work... Any idea how can i update the radio? Thank you! |
12-06-2019, 07:12 AM | #1413 | |
Rep 67
12-06-2019, 07:27 AM | #1414 |
Rep 399
Why don't you just buy an Android iDrive retrofit? Plug and play without all this hassle.
12-06-2019, 08:24 AM | #1417 |
Rep 399
Like the one you can buy with the Android unit, can also be bought separately.
12-06-2019, 09:10 AM | #1418 |
Rep 80
Well, i try it again like 2 hours, but i cannot update the android radio, othing appears..
I try to rename it like px6_update.zip o .rar, px6_format.zip, PX6.zip ; i try with 3 differents usb but nothing... i am tired yet, i dont know what i am doing bad... |
12-06-2019, 09:35 AM | #1419 | |
Rep 114
Maybe start with a low level format with an utility like Hard Disk Low Level Format Tool , then format drive as FAT 32 , then copy upgrade file on flash drive. File should have .zip extension . |
12-06-2019, 10:50 AM | #1420 |
Rep 159
Did you check what filename was noted on your upgrade file from /oem ? For me it was PX6-9.0.zip
12-06-2019, 01:58 PM | #1421 | |
Rep 80
The name that i put in the usb (fat 32) was px6.zip, but i dont know why it doesnt recognice it. It is another way to install the update? Thanks |
12-06-2019, 07:50 PM | #1423 | ||
Rep 71
1.Download the "px6-9.0_format.zip" system recovery file 2. Copy the zip file (PX6-9.0_reset.zip or px6-9.0_format.zip) to an empty SD card or USB flash drive. 3. Insert the USB flash drive with the recovery zip into any USB port of the monitor as shown below:↓ 4. Power on the monitor by putting your car into ACC mode or start your car's engine. 5. Once you see the monitor powered on IMMEDIATELY power OFF the car and monitor then power back on the monitor again. Doing this will put the unit into upgrade mode. 6. Wait for the update process to fully complete. When the update is done you will see the message below "please remove the usb disk". Unplug the USB flash drive to automatically restart the monitor. 7. The monitor will automatically restart after unplugging the USB flash drive. It takes 5 minutes for the system to complete its first initial boot-up. Please be patient for it to complete. If you see the "NO SIGNAL" message appear as shown below you will need to power off the monitor wait 45 seconds and then power on the monitor again.
Gabo
12-06-2019, 08:20 PM | #1424 | |
Rep 62
maybe you could package it together and we could like purchase the whole package from you. |
12-07-2019, 08:50 AM | #1425 |
Rep 12
sorry off topic but as I mentioned earlier in this thread I am having trouble getting the Idrive screen to display properly. I currently have it stretched full screen but it looks awful tbh. The other working option is unstretched with the strange overlay.
I would ideally like it fullscreen unstretched on the Idrive. I have tried every which combination of DISPLAY_SIZE_RESOLUTION & DISPLAY_VARIANTE, programming with Bimmercode. Trying all combination with the android headunit (mines is the snapdragon type) resolutions. Each time I have disconnected the car battery and waited 12 mins for the headunit to reset. Is there anything else that can be tried? My BMW F30 is 2015 and the head unit is ENTRY_NAV so my understanding is an unstretched idrive screen should be achievable? I came from the 6.5" screen. I am at my wits end and anyone who helps me achieve this will be rewarded (via paypal). |
12-07-2019, 09:16 AM | #1426 | |
Rep 80
12-07-2019, 01:19 PM | #1428 | |
Rep 87
http://4pda.ru/forum/index.php?showtopic=405989 I'm still unwilling to try it as there is not yet failsafe recovery like TWRP. |
12-07-2019, 03:10 PM | #1429 | |
Rep 1,402
Drives: 13' F30 328i 6MT
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
12-07-2019, 04:18 PM | #1430 |
Rep 71
Recovery is used to update, try to rename the file but still try following the method... you are almost there!
Gabo
