10-14-2019, 01:23 PM | #1 |
Rep 231
Stock intake holes with AFe dry air filter
Since i got the CEL ON with the Injen intake on my 435i,
I started thinking to do the holes on the stock box and putting the AFe dry air filter, Is this mod will make turbo sound louder and more noticeable than stock? I loved the turbo sound with the Injen intake Thanks all |
10-16-2019, 12:36 PM | #3 |
Rep 2,665
Is this worth trying generally? Anyone have good exp with this? The holes?
10-16-2019, 01:13 PM | #4 | |
Rep 1,079
I think johnung had a post about it that I can't find anymore. |
floridaorange10144.00 |
10-16-2019, 01:39 PM | #5 | ||
Rep 5,393
If I had the stock box now I would just cut or drill the holes in the same location and drop in a aFe Pro Dry air filter. The opening is in the lower part of the front of the box so I wouldn't even be able to spot mine if I didn't see the red plastic outline. I'll post it here if I find my original post. The photos are on a laptop that's to be repaired so don't have access to them right now. |
10-16-2019, 02:22 PM | #6 |
Rep 426
I think this is what you're looking for: https://f30.bimmerpost.com/forums/sh...d.php?t=956841
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
10-16-2019, 02:31 PM | #7 | |
Rep 231
But i was wondering if the holes with afe filter will make a noticeable turbo sound? I'm okay with the Injen intake it's amazing but I don't know I feel it's not good for the engine. |
10-16-2019, 02:52 PM | #8 |
Rep 426
Ah, gotcha. Not sure from personal experience. I'll be doing it this weekend with the AFE pro dry S filter, so I can tell you next week ;-)
10-16-2019, 02:54 PM | #9 | |
Rep 231
Good luck |
BeerHerder250.50 |
10-16-2019, 05:28 PM | #10 | |
Rep 2,665
https://www.turnermotorsport.com/p-1...CABEgIL_vD_BwE Last edited by floridaorange; 10-16-2019 at 05:51 PM.. |
10-16-2019, 05:36 PM | #11 |
Rep 191
I've ran my oem intake with a hole similar size to the mperformance intake with no cel or issues for over a year before I swapped to a cts turbo intake. Turbo wasn't much louder than stock imo especially compared to my open intake. Would sell my cut intake for cheap if anyone is interested as I have no use for it anymore.
10-16-2019, 11:44 PM | #13 | ||
Rep 5,393
10-17-2019, 12:09 PM | #14 |
Rep 2,665
Removed my filter housing and it turns out the previous owner had cut a nearly 2 inch hole on the top part above the filter facing front of car. Debated on covering it with duct tape - decided just to leave it.
Drilled 4 dime size holes on the side where the air comes in and 4 dime size holes on the side where hole is on the MP intake. Additionally added about 10 smaller holes on the side as well, like 1 cm. We'll see how she does for a while and if I don't like it I'll buy another OEM intake lower housing. Has time for a 5 min spin and it definitely sounded more aggressive. Seemed to idle smoother too. Once I have time for a longer drive I'll know more. |
10-19-2019, 02:30 PM | #15 |
Rep 426
I did it this afternoon. Sound difference is pretty imperceptible. I agree with the one guy's assessment of maybe 5-10% more noise. I did 3x 3/4" holes, and 5x 1/2" holes. I used a regular drill bit to make a pilot, then a wood spade bit to make the holes. Step drill bit would have definitely been cleaner. After drilling I cleaned up the holes with a round bastard file, then a razor knife to get the last little bit. Blew out the dust, dropped in my new AFE pro dry S filter, and called it a day.
One thing as an install note, I didn't detach the MAF or breather tubes... just removed the large engine cover, lifted up the top of the airbox, and pulled the lower box out. It would have been slightly easier if I did, but it wasn't necessary. I always hate detaching those little clips that hold the sensors in... I have a bad habit of snapping them.
zeyad.habeeb58.50 thatBimmerBloke872.50 |
11-17-2019, 07:10 AM | #16 |
Rep 2,665
So yesterday replaced my 2013 intake air box that actually came with a hole drilled in the top front side of the air box. Since I've owned the car I've only known how it's been with an air box hole. Anyway as I mentioned earlier I added more holes to see if there was a difference. There was more engine noise and I think the original hole added some swish sound.
Anyway I replaced the entire box with a 2016 air box that had no holes. I gotta say I was stunned at first at the amount of perceived low end torque I guess I'd been missing this whole time. Even in regular nonsport drive the car seemed to know what it was dealing with the correct oem air values - revs were much better and idle was quieter. I recently changed spark plugs too - but I had driven with the air box that had the drilled hole and then multiple holes a lot. My question is - is it possible the intake system is THAT sensitive? I don't know about the higher gear responsiveness yet because I didn't get on the highway but lower end is like a different car. I will be keeping this setup and not changing the intake in anyway way again! (Besides the k&n drop in) |
11-17-2019, 07:01 PM | #17 | |
Rep 231
11-17-2019, 07:27 PM | #18 | ||
Rep 10,473
alohasurftoad3076.50 |
11-17-2019, 10:42 PM | #19 | |
Rep 1,079
BeerHerder confirmed there wasn't a huge difference in sound after drilling the holes. I wonder if he is noticing any loss/gain in low-end torque or rough idle. |
11-17-2019, 11:49 PM | #20 |
Rep 2,665
Obviously without a dyno who knows. Gonna spend more time driving it with holed air box, after less than desirable performance today.
Mate - you very well may be right. In fact today there was throttle lag and power wasn't really there today. My previous statement shows correlation does not imply causation with non holed airbox. |
11-18-2019, 08:53 AM | #21 | |
Rep 426
11-18-2019, 11:03 AM | #22 | ||
Rep 231
