BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > JB4 Issues and Impressions (F30)?
      02-16-2013, 12:38 PM   #45
Bavarian Beast
Too many wagons on the bahn.....
Bavarian Beast's Avatar
98
Drives: LMB 2011 BMW e93
Originally Posted by ljt335msport View Post
I have Stage 1 and have put about 3000 miles on it. I love it! Big horsepower and torque gains. No loss of mpg's. Turbo spool up is immediate and the turbo whistle is much more noticeable than stock. The only complaint I could make is that you can feel the turbo hit hard and then a second or 2 later you can feel the boost drop off. I love it though. I'm looking forward to stage 2 because this thing is already a beast! FYI, I have the 8-speed. If anyone is on the fence I'd say go for it!
John
I wonder if a DP would fix the boost drop off.
      02-16-2013, 12:49 PM   #46
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
only a manual boost controller would do that with a strong Forge DV.
SOLD: 2012 335i Mineral Gray
      02-18-2013, 02:43 PM   #47
Bavarian Beast
98
I am coming from a NA engine so the whole turbo engine is a new gig for me. Thanks for the info.
      04-19-2013, 09:27 AM   #48
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
Is everyone using an aftermarket charge pipe? How important is an aftermarket charge pipe for a stage 1 tune?
      04-19-2013, 09:28 AM   #49
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
No aftermarket charge pipe here. I have stage 2 with downpipe fyi.
      04-19-2013, 10:43 AM   #50
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
No aftermarket CP available yet..... I did however just start to experience the rough cold starts. Almost like the car has a hard time starting like the starter isn't strong enough.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-19-2013, 12:02 PM   #51
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
Happens to me almost every morning.
      04-19-2013, 07:25 PM   #52
mikew2069
mikew2069's Avatar
413
Yea that sucks. Wonder if its something they can tweek to fix or what...
BM3/H&R/Borla
      04-22-2013, 01:54 PM   #53
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Originally Posted by Mike@N54Tuning.com View Post
There is no JB4 for the F30 yet. Only the N55 Stage1 tune. It does not leave codes behind but if you are worried they sell a complain tool called the "CAN Tool" that will delete hidden codes. Alternatively you can get the BT Tool which lets you read codes via laptop from all modules on the vehicle.
Gains are 40-50hp and well worth the 5 minute install time.
Mike
Just to clarify, for the F30/N55 Stage 1 tune, there is only 1 map, correct?
Will Stage 2 essentially be the "full" JB4 with map switching a la PBX or will the full JB4 be following the stage 2 release?
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      05-07-2013, 02:20 AM   #54
Underated
Drives: F30 N55
Waiting an answer to this question. Secondly, Will the JB stage 1 delete the CEL from installing catless DP?
Just to make sure before actually getting the JB.
      05-07-2013, 07:08 AM   #55
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
Stage 1 will not delete CEL.
      05-07-2013, 11:14 AM   #56
lazycat
Drives: f80 m3 CP
I have the stage 1 JB for n55 f30, it is awesome and I love it. I also have the ER cat**** DP for the last 3 months working with the JB stage 1. They work well together and so far, after 8k Km, no CEL ever came up.
I will be getting JB stage 2 this week
      06-11-2013, 01:12 PM   #57
RJCrew
RJCrew's Avatar
Drives: 2016 ///M4 ZCP SO/SO
I've been waiting for a month now for my MPPK with DME, but my order changed to August deivery date due to DME issues. Now, I'm thinking about getting JB4 stage 1 and AFE Cold air intake with air scoop. What do you guys think/
RJ
      06-11-2013, 05:47 PM   #58
s1k0ne
Drives: ..
where's the STAGE 2??????
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      06-11-2013, 09:30 PM   #59
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
I installed my stage 2 last week...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      06-12-2013, 12:40 PM   #60
s1k0ne
Drives: ..
Is it official or the beta version? I also have a 335i in manual and have been waiting for the stage 2 for a while
F85 (17) - DG/AB
F30 6MT 335i - EBII
      06-12-2013, 01:21 PM   #61
tdizzle
Drives: 2017 F80 ZCP
The F30 is still in beta as far as I know. Haven't heard otherwise. It's been in beta awhile and many are running it without issue.
      06-13-2013, 04:42 PM   #62
abe12345
Drives: 2013 F30 335i M-Sport Manual
If I'm running a catless DP with jB4 stage 2, 91 octane, can I safely run map2? Or should I stick with map 1 because I'm using 91oct not 93oct
      06-13-2013, 05:35 PM   #63
tdizzle
I'd ask someone from BMS, but someone asked about using 91 octane and a DP and terry told them to use map 1 over map 2 with that fuel.
      06-13-2013, 05:59 PM   #64
Mak135i
Drives: 911 GTS, X3M
+1. On the technical forums of BMS, there is a thread specifically for this issue. In it, it is clear map 2 needs 93 octane or higher
2019 911 GTS
2017 M4 CV
2017 Mini JCW
      06-21-2013, 11:27 PM   #65
M.Suka
M.Suka's Avatar
Drives: 2013 335i M Sport
Just picked up a stage 1 from someone that had it on his 2012 535i and was wondering should I install the third connection to the boost solenoid (my car is a 9/13 build), how many are running with it connected with no problems.
European delivery 9-19-2012
      06-22-2013, 10:57 AM   #66
tdizzle
You're not supposed to install that connection unless you're using Stage 2. As far as people who may be doing it? Not sure but I'd go with what BMS recommends.
