06-02-2021, 06:59 PM | #1 |
Rep 1,381
et30 square setup on F32?
I don't seem to be getting anywhere with working out my offsets so apologise if this is seen as spam..
I'm wanting to run the following setup: 235/35/20 8.5 et30 front 255/30/20 8.5 et30 rear Does anyone see any issue with this setup? I plan on getting Eibach pro kit springs in a few months too so a slight drop will be happening.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
06-05-2021, 12:26 AM | #2 |
Rep 246
I think you'll be fine with those spec. I've seen people run 9" wide with et30 and were ok.
fortythirtyfive639.50 |
06-06-2021, 10:54 AM | #3 |
Rep 1,381
thank you - I'm going to bite the bullet and just order the new setup, HRE don't recommend it but I'm going to put it down to them not having the chance to trying it
2015 435i - 401whp
06-06-2021, 11:24 AM | #4 |
Rep 4,322
with staggered tire sizes, have you considered staggered rim widths?
i'd go 235/35/20 & 265/30/20(or 275/30/20) on 20x8.5 ET30 & 20x9.5(or10") ET42ish. here is a thread with 20"...https://f30.bimmerpost.com/forums/sh....php?t=1047084 FYI HRE 20x8.5 ET30 will be flat face and no concavity, but if you don't care or that's what you prefer and you've already ordered it, post pics after you get them. . Last edited by alohasurftoad; 06-06-2021 at 11:47 AM.. |
06-06-2021, 11:27 AM | #5 |
Rep 1,934
Not sure I understand the purpose of going staggered if the et is the same. You can't tell the wheels are wider than the from from the rear. And there's no concavity with this setup. Seems to just be a headache as you can't rotate tires correctly. Are you big turbo looking for grip?
alohasurftoad3076.50 |
06-07-2021, 08:14 AM | #6 | |
Rep 1,381
Stock turbo
2015 435i - 401whp
06-07-2021, 10:35 AM | #7 | |
Rep 4,322
But if you're happy with four fronts(no concave), i'm happy. . Last edited by alohasurftoad; 06-07-2021 at 11:14 AM.. |
