06-09-2021, 10:52 PM | #1 |
Rep 50
Car misfire no CEL help!!
My car started to stutter while at highway cruising speeds and would stutter/shake while trying to accelerate. I limped the car home and it would shake while at idle with no CEL and still couldn't find hidden codes with my OBD2 scanner.
This happened to me a few months prior and the culprit was 1 bad fuel injector that has been replaced out of the 6. The only difference this time is that while at idle there is no sign of white smoke coming out but during the first time it happened there were puffs of white smoke coming out which is a sign of a bad fuel injector. Do you guys think this is a sign of all faulty fuel injectors? And if it is, would I need to do any sort of coding? The car is a FBO custom tuned 435i with 109k miles coil packs have 3k miles and brand new NGK spark plugs gapped to .022.
khan nguyen
06-11-2021, 09:07 AM | #3 |
Rep 844
It would be very rare for an injector to go and there not be a CEL light. Stuttering and shaking while trying to accelerate could also be a boost leak issue which could definitely happen without throwing a code. I see you have a 435... have you checked you charge pipe for cracks? Also how recent was your spark plug install... Might have a loose plug or pack
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
06-11-2021, 03:06 PM | #4 | |
Rep 50
khan nguyen
06-11-2021, 03:10 PM | #5 |
Rep 50
yes it is tuned on BM3. should i just flash back to stock and run the car til it flashes CEL? or will that not work.
khan nguyen
06-11-2021, 03:19 PM | #6 |
Rep 1,597
Did you check if the injector from a few months ago sooted up your oxygen sensor? Whats the story with the previous injector replacement, were all injectors replaced and by whom? No coding is needed after an injector replacement, just reset adaptations. I would flash back to stock.
06-11-2021, 04:58 PM | #7 |
Rep 766
06-11-2021, 05:07 PM | #8 | |
Rep 50
khan nguyen
06-11-2021, 05:21 PM | #9 |
Rep 1,597
You put in a used injector? I guess I don't blame you each being $300 new. I don't know it could be many things. Your failed injector could have affected the plug or coil or fouled the O2 sensor or even the cat. Then theres the question whether the right injector was replaced and how they determined. A stealership may advise replacing all the injectors for certain legit reasons.
06-11-2021, 05:24 PM | #10 | |
Rep 50
khan nguyen
06-11-2021, 05:26 PM | #11 |
Rep 7,598
As I said before, flash back to stock and drive the car then scan for codes. For most people new codes pop up immediately after going back to stock and typically point to one cylinder as the problem.
06-11-2021, 05:30 PM | #12 |
Rep 1,597
Yes before throwing money at it left and right, you need to know the problem you are dealing with. Get codes scanned. Opt for the most expensive option last not first.
06-11-2021, 08:25 PM | #13 |
Rep 50
thanks for ur help guys. i flashed it back to stock and a code popped up right away which was cylinder 2 misfire. next thing i did was swap coil #2 with #4 deleted codes and turned the car on. the misfire switched to cylinder #4 which was such a relief. i got a new coil pack, swapped it and it runs like new. thanks again for everyone who chimed in!
khan nguyen
06-12-2021, 12:02 AM | #14 | |
Rep 7,598
06-12-2021, 05:17 AM | #15 | ||
Rep 844
EDIT: just read through the whole chain, looks like it was a pack. Glad you got it sorted
06-15-2021, 08:25 PM | #16 |
Rep 150
Care to share where you've seen this? First time I'm hearing of this.
06-16-2021, 12:21 AM | #17 | |
Rep 7,598
Here's another recent example from this section: https://f30.bimmerpost.com/forums/sh....php?t=1830137 |
