02-26-2023, 03:54 PM | #1 |
Rep 7
Staggered Rims xdrive
greetings all.
Hello all, I am in desperate need of knowledge/info. I have a 335 GT xdrive, i have bought the e90 M wheels to replace the stock rims not knowing about staggered rims going to mess up transfer case. wheel specs 19x9.5 for front, and 19x8.5 for the rear anyway, i am trying to figure out what size tires i can fit my wheels. i am currently running 245/35/19 for the front, and 265/35/19 for the rear. Can i just switch out the rear to a different tire size? if so what can i get? please and thanks in advance! |
02-26-2023, 04:13 PM | #2 |
Rep 6,234
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
19 x 9.5 front and 19 x 8.5 rear doesn’t make sense. Exactly what style of wheels did you buy? Staggered wheels in and of themselves don’t cause a problem with xDrive. The tires need to be the right size. It’s unlikely you can just swap the rear tires.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
02-26-2023, 04:38 PM | #3 |
Rep 7
Hello, I purchased the E90, E93 M3 220 Style Rims. I am looking for the right tire size combo I can swap out the current ones on it now.
alohasurftoad3076.50 |
02-26-2023, 09:12 PM | #4 |
Rep 4,318
rim style 220 has ET29 front, which is a bit low and ET23 rear, which is a LOT low, will poke a lot and not really good for an F34.
the tire size combo i suggest for your F34 xdrive with those offsets is 225/45/19(27.1") front, 255/40/19(27.0") rear. this is primarily to minimize the amount of poke you're going to have at the rear. 245/40/19(26.7")+275/35/19(26.6") rear is another option however there will be a decent amount of outside tire tread poking. not sure if you care about handling but fwiw, there is understeer associated with a 30mm front/rear tire width stagger. ET23 at the rear will cause even more(understeer). |
02-26-2023, 09:42 PM | #5 | |
Rep 467
OEM staggered set-up on GT (like I have), with the tires as 1st option recommended to you by @alohasurftoad: Front: 19 x 8, +30, 225/45/19 Rear: 19 x 9, +42, 255/40/19 However, I run with spacers on my GT, 10/12 mm. That makes the actual offsets to be: Front: +20 Rear: +30 It is possible to use staggered E90 rims on F cars, I've done that on wife's F30 with 225Ms: Front: 19 x 8, +37 (original offset) Rear: 19 x 9, +39 (original offset) I've had rears offset modified to be +47 by having the landings on the wheel hubs machined (8 mm of material removal). There are places that can do similar alteration to the 220s to your likings. I would leave fronts as-is and have rears machined to bring them inwards to minimiza the poke. In any case, I'd try mounting the rims first and only then make a decision to have the rears altered and by how much. That's how modified 225s look at the rear of F30 mounted:
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
02-27-2023, 12:25 PM | #6 | |
Rep 7
02-27-2023, 12:38 PM | #7 | |
Rep 467
https://www.wheel-size.com/calc/
02-27-2023, 12:53 PM | #8 | |
Rep 467
Even if you manage the offset adjustment, keep in mind that tires will be ever so slightly stretched (the 255 section). Also, if you plan/have the car to be aggressively dropped, you could have rubbing issues. GTs came with staggered set-up in M Spec package from factory (and I love the look of mine with spacers), it's just you happened to choose the rims with significant offset difference when compared to OEM fitment.
03-08-2023, 08:55 PM | #11 |
Rep 467
Would help if you listed the full specs for your set-up: tires (width/side wall and offsets on the rims (front and rear).
Your ride height looks different... I have much smaller wheel arch gaps than yours while riding on 19" OEM staggered rims. What kind of suspension do you have? I can see XDrive batch on the back... So either Xdrive or Adaptive XDrive, right?
03-08-2023, 10:46 PM | #12 | |
Rep 143
https://support.apexraceparts.com/hc...-Fitment-Guide |
