09-17-2018, 04:45 PM | #265 |
Rep 482
Drives: 2014 Glacier Silver F30 328i
09-17-2018, 07:08 PM | #266 |
Rep 657
yes I am on stock fuel pump as of now my stg 2 lpfp was acting funky for some reason.
Current: 2017 Bmw 540i M sport bluestone metallic
Previous:F30 328i 2012 PWG: FBO Vrsf 6 stepped fmic, Afe intake, Catless DP ER, FTP CP's, FTP turbo inlet, GFB DV+, Gplus oil cooler, BM3 stg 2 tune, Cary Jordan E50 tuned stock fuel system. |
rjd_F301999.50 |
09-17-2018, 08:39 PM | #267 | |
Rep 482
Update on the car: Tech ran into a problem getting the o2 senor out. Even said after a few attempts with heat they still couldn't get it out. They are letting it soak overnight. He said it looks as if it was cross threaded on. Not sure, what's going on with that or what could have caused it since it was never touched by me. If they can't get it off would they just replace it since the DP is coming off anyway? He also asked me if my car has ever been in a front end accident because my condenser unit was all banged up. I was like not that I know of. Car was purchased a year ago through a very reputable BMW dealership certified preowned/clean car fax. Not sure what could have caused that or what that's going to cost to fix it?!?!? Hopefully, the rest of the job goes smoother tomorrow.
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
09-17-2018, 09:31 PM | #268 | |
Rep 3,679
About your 02 sensors, I have heard of them getting hot enough that they essentially weld themselves to the DP, that could be your problem. The shop should just replace the 02 sensor, shouldn't be a big deal.
09-17-2018, 09:40 PM | #269 | |
Rep 482
Any idea as far as price what I'd be looking at to do the condenser and the O2 sensor? I looked up condensers and I saw it should be around $100 for the part not sure about the O2 sensor though.
09-17-2018, 09:47 PM | #270 | |
Rep 3,679
I really have no idea how much the labor would be on a condenser job. I don't think its a really simple job though... 02 sensors should go for around $115 for the pair if I remember correctly, and it's obviously a very easy job. I would have the shop just do two new 02 sensors, it will probably take them an additional 15 seconds, considering they already have the DP out.
09-17-2018, 09:51 PM | #271 | |
Rep 482
09-17-2018, 10:11 PM | #272 | |
Rep 3,679
09-17-2018, 10:18 PM | #273 | |
Rep 482
09-17-2018, 10:30 PM | #274 | |
Rep 5,456
Drives: F30
And why is your tech dropping the manifold?! Not necessary! |
09-18-2018, 09:01 AM | #275 | ||
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
09-18-2018, 02:17 PM | #276 | |
Rep 482
09-18-2018, 03:23 PM | #277 | |
Rep 2,382
The only difference is AGG has more aggressive burbles.
09-18-2018, 04:18 PM | #278 |
Rep 482
Diverter valve in. He ended up swinging the turbo to get it in. Smells and sounds are a lot different! Something I’ll have to get use to. Driving home to flash to Stage 2. Hopefully I’ll get some logs tomorrow. Thanks for the clarification.
BunkerJ1032.00 |
09-18-2018, 07:23 PM | #279 | |
Rep 3,679
Let us know what you think of stage 2.
09-18-2018, 07:53 PM | #280 | |
Rep 482
1. ER Catless DP 2. ER DP 3. ER FMIC 4. Go Fast Bits DV+ Valve 5. New spark plugs gaped to PTF specs My impressions so far are... First flashed with the more aggressive burble tune and it was too much for my liking. Then took it down to the lesser aggressive burble tune. Burbles sound good I may end up toning it down a little more not sure how I feel about them just yet. Power feels strong through revs. Power feels stronger when you ease into the gas rather than just punching it. Good loud, long burbles and backfires when you let off gas once turbo has spooled up and you back off the gas. Car feels light and pulls a lot stronger off the line. I'd like to get some logs over the next few days to see if everything is dialed in correctly. Also, I feel like with the new DV valve the car seems to hold boost a little longer. Maybe a placebo effect? but something feels stronger. Butt dyno feels GREAT! In my opinion if you want to push your car safely to it's limit this is the best way to go. Question: I noticed there's a setting to turn off "heating your cat" during a cold starts. I'm running catless so I'd like to cut down on noise during cold start up's but is it recommended? Should I continue to heat my cat when cold starting. If yes, what are the pro's? And con's? Thanks
09-18-2018, 08:21 PM | #281 | |
Rep 3,679
About your question, turning off cat-heating will disable the cold start entirely, so the car will just startup very mildly and quietly every time to remedy the fury that is a catless N20 cold start. I recommend turning cat-heating off because it's only there to heat the cat, which you've just removed. It really quiets things down well. There are no cons to turning it off. That said, I did experience a rough idle after startups with it turned off, but that has fixed itself over time through adaptations, I assume. So if you experience the same, don't worry it will go away eventually. It took about a month of rough starts before it finally adapted to not having a cold start cycle, but it's smooth as butter now.
09-18-2018, 08:23 PM | #282 | |
Rep 482
09-19-2018, 09:25 AM | #283 | |
Rep 2,382
Concur with above on cat-heating. Mine was so loud it'd set off car alarms, so 10/10, do recommend turning it off.
09-19-2018, 10:00 AM | #284 |
Rep 482
Looks like my cat heat was turned off when I flashed so that’s good. I’ll try and post some logs over the next few days once the rain clears around here.
rjd_F301999.50 |
09-21-2018, 01:44 PM | #285 | |
Rep 482
Question: How do you diagnose with bootmod to check for fault codes? Is it something you can do while on the server after you flash? I'll be getting some logs this week.
09-21-2018, 01:47 PM | #286 |
Rep 2,382
Go to Diagnostics > Read Codes
