08-12-2019, 02:04 PM | #837 | |
Rep 2,302
https://www.bimmerfest.com/forums/sh...d.php?t=983244 |
08-12-2019, 04:46 PM | #838 | |
Rep 40,774
08-17-2019, 11:35 AM | #841 | |
Rep 40,774
08-20-2019, 04:56 AM | #843 |
Rep 404
Drives: 2008 335i montego blue - 2011
Hi Shawn would you mind sending me the PsdZData full and lite please. Need to get the right stuff for a 2011 f10 535xi. Thank you very much in advance. God bless!
08-20-2019, 05:26 AM | #844 | |
Rep 40,774
08-20-2019, 07:37 AM | #847 | |
Rep 40,774
08-20-2019, 07:46 AM | #848 |
Rep 53
Drives: 2012 335i
Hi Shawn,
I am in need of full PSdzData as well. Appreciate it. Thanks |
08-20-2019, 07:48 AM | #849 |
Rep 40,774
PM sent.
08-23-2019, 01:18 AM | #851 |
Rep 40,774
PM sent.
08-24-2019, 11:20 AM | #853 | |
Rep 40,774
And why are your Connection Targets missing? Is PSdZData properly installed? You will not be able to connect via VIN unless PSdZData is properly installed, and the Car and Laptop have a connection. For this: 1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good and making good contact in OBDII Port 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it) If the "Open Connection" window under "Target" is empty (no targets), verify the following:
08-25-2019, 11:22 AM | #854 |
Rep 10
tnx Shawn,
just realised i am using win 10 and this won't work under 10 ? connect under VIN is not possible either, and the boxes bottom right are all odd too, this due to win 10 as well ? Simon |
08-25-2019, 11:25 AM | #855 |
Rep 10
assuming i have the wrong win version, just about to borrow a win 7 laptop
can you send me suitable links for the latest latest psdzdata files and E sys please coding an 2018 i3 - if that makes any difference tnx |
08-25-2019, 11:27 AM | #856 | |
Rep 40,774
08-25-2019, 11:32 AM | #858 |
Rep 10
tnx, must be the wrong files i have DL then
can you send me the correct links please. tnx ah, just seen your link Atze. https://www.bimmerfest.com/forums/sh...d.php?t=983244 |
