BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Exhaust rattle
      03-01-2017, 12:36 AM   #23
DJsirkit
DJsirkit's Avatar
Drives: BMW 428i x-Drive M-sport
nobody?
2014 BMW 428i xDrive M-Sport
      03-01-2017, 03:05 AM   #24
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3032
Drives: 340 6MT, 50e, others
My car does the same thing
      07-09-2017, 11:49 AM   #25
TheBlackTruth
Drives: 2013 F30 x-Drive
Similar or same issue here
2013 335i xDrive
      07-09-2017, 12:29 PM   #26
TheBlackTruth
Didn't find much useful in other threads so decided to try and tackle the problem myself. This is by no means a permanent solution but it got rid of the rattle!
Solution: Electric tape!
      07-09-2017, 06:49 PM   #27
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3032
Originally Posted by TheBlackTruth View Post
Didn't find much useful in other threads so decided to try and tackle the problem myself. This is by no means a permanent solution but it got rid of the ....
High temperature electrical tape?
      07-10-2017, 11:22 PM   #28
Dinan_Rated
DINAN SELLER
Dinan_Rated's Avatar
170
Drives: BMW X3MC X3M40i, DINAN M5 V10
Update
      07-11-2017, 12:22 AM   #29
asuh1991
Drives: 335i, M4, RRS Autobiography
i think your tips are cracked, should be replaced under warranty
      07-18-2017, 06:41 AM   #30
radeohedca
Drives: 2013 320i
Check for a loose oxygen sensor. My car sounded like a tin can POS. After much investigation I found that the wire going to the 02 sensor was clanging off the exhaust pipe and the sensor itself was loose. It resonated through the entire exhaust system.
Solidjake945.00
      07-18-2017, 07:37 AM   #31
ChubbyWilly
ChubbyWilly's Avatar
Drives: 2015 BMW 335i
Originally Posted by Austinformedude View Post
Fixed! Finally convinced the dealer to replace the muffler assembly under warranty. This completely fixed the problem! It appears that sometimes the baffles inside the muffler become detached and rattle inside when warm (bad welds?) So if your problem is not with the flap, or heat shields, the next step would be replacing the muffler.
Just do an exhaust delete!
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
      07-18-2017, 08:56 AM   #32
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
it's the flap, it should be replaced under warranty. Contact BMW central for this.
SOLD: 2012 335i Mineral Gray
      07-19-2017, 09:56 AM   #33
redbullfan
redbullfan's Avatar
356
Drives: 22 TR X3MC
2022 BMW X3MC  [0.00]
The clip for the exhuast flap cost from $5-$8 at the stealership, and I bought one and replaced it myself and it only took 20 min. I also did my buddies 328i which had the same problem
2022 X3M Comp
2013 335i xDrive (Sold)
      07-22-2017, 09:07 PM   #34
Paul13F30
Drives: 2013 328xi
I confirm this. The valve rattle is usually caused by a pin connecting the actuator to the valve going missing. According to my SA, it's a common problem. Luckily, the part is $8 and 20 minutes is all you need to replace it.
      08-15-2017, 12:25 PM   #35
MacklinUSOB
Drives: f30 328i 6MT Sport
Does anyone by chance have a BMW part number for that little guy?
This rattle drives me insane, ecstatic to know that I can fix it for 8 bucks.
      08-15-2017, 05:18 PM   #36
WallySlash
WallySlash's Avatar
Drives: 2014 428xi Sport Line
2014 BMW 428xi  [9.00]
18307620323. Fixing bow.
www.realoem.com
      09-04-2017, 12:28 PM   #37
DLeMs
Drives: 328ix
Has anyone figured out how to get the replacement fixing bow into the slots? The slots don't line up exactly parallel to each other. I've been trying to install the replacement but haven't had any luck. Any advice would be appreciated.
      05-12-2018, 03:43 PM   #38
happygilmore99
Drives: 2013 BMW 328i xDrive F30
I just did this myself today. If you remove the actuator controller on the right by unplugging it and loosening the 3 bolts, you can line up the new spring in the slots and then install the actuator controller again. Use a 10mm socket to loosen two of the bolts. I didn't have enough clearance for a socket wrench for one of the bolts so I used a crescent wrench. Hope this tip helps someone!
      05-29-2018, 07:45 PM   #39
Ashhong
Drives: 2014 335i
Sorry for the bump but my car recently started making this noise and it's just embarrassing. It's not at cold starts either because I heard it while waiting at a drive thru and thought it was the buildings AC or something. So loud. It goes away when parked though for the most part and I only hear it when in drive and holding the brake.
Anyway, my question is, is the issue that this horseshoe shaped pin in the pic is missing? So if I look under my car I should see a missing pin?
      05-30-2018, 04:05 AM   #40
Ikester19
Ikester19's Avatar
2124
Drives: G20 M340ix; F30 328i msport
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
My car has the same issue which I noticed this morning on startup,it was so loud and lasted a few minutes until the car warmed up a bit then went away. Sounded like a 20 yr old rattling Camry!
Will have to contact the dealer and hopefully get it repaired under warranty.
Very annoyed!
      05-30-2018, 10:50 AM   #41
Ashhong
Drives: 2014 335i
Very annoyed!
Try rolling down a window at a stop sign after driving. Is it completely gone?
      05-31-2018, 04:34 PM   #42
Ikester19
Ikester19's Avatar
2124
Yes sound went away a few minutes after start up. The next morning I started the car (cold start) but the noise was not there!
So not sure why the loud rattling sound would be there on one day but not the next. Will have to monitor and see if it recurs
      06-02-2018, 11:10 PM   #43
Paul13F30
Drives: 2013 328xi
That is correct. If the pin is missing, it's the valve inside your exhaust pipe that's causing the rattle.
      08-09-2018, 09:06 AM   #44
TwinScroll18
Drives: 2013 F30 335i Sport Line
I have a similar issue where there is no rattle in the morning, but in the afternoon when I leave work, it's there. The fixing bow is still attached, so that can't be the cause. Were you able to resolve your problem?
If I just zip tie the bow in its open position, would I get any dash warnings if I don't remove the electronic plug?
