03-21-2016, 04:51 AM | #1 |
Rep 42
Retrofitting Instrument Cluster 6wa
Iam gonna retrofit instrument cluster on my F30.
I have just buy'ed a used cluster. What do i need? What is the most fibre everybody is talking about? I have CIC Prof HU. Espen |
03-21-2016, 06:51 PM | #2 |
1/2 Asian Sensation
217
Rep 397
Drives: 2011 BMW M3 e92 ZCP
I could be wrong but I don't think 6wa can interface with a cic unit. I don't think there is a most connection on cic unit for them to talk to each other.
All too easy...
03-22-2016, 02:57 AM | #4 |
Rep 1,374
Drives: Audi R8 v10 Spyder
This is the most cable you will need but I think it's only compatible with the NBT unit.
The MOST cable is the orange one with the Red LED lights After which should join the NBT headunit to the instrument cluster.
03-25-2016, 06:43 AM | #7 |
Rep 1,374
Here's some pics behind the HU & Cluster
Original Green Cable Removed the Green Cable Inserted MOST cable Behind the Cluster
03-27-2016, 09:07 AM | #10 |
Rep 1,374
The red laser will light up automatically if correctly connected. Make sure it's correctly connected
03-27-2016, 09:10 AM | #11 |
Rep 1,374
Hmm, good question. I forgot what I did with it. First off since it's used you might need to get the seller to clear the previous vehicles VIN from the cluster. Don't have much steps, just unscrewed the 4 screws insider the cluster and removed the iDrive Head unit to access the harness & routed the MOST cable from the cluster to the Headunit. Then it's all coding from there
11-08-2016, 04:11 AM | #15 |
Rep 938
I've always wondered if there is a complete retrofit guide to doing this?
I'm hopefully about to upgrade my CHAMP2_HU to an NBT in the coming weeks so I may have the opportunity to upgrade my clocks. The one thing I've heard is the donor 6WA must have a lower mileage than the one you are replacing. If this is the case, I'm in luck as my car has rather high mileage due to my 200km daily commute! However, I digress. If anyone can point me towards a guide, that would be great. Thanks!
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
01-23-2017, 12:34 AM | #16 |
Rep 43
I have a F20
Coding wise it was not as simple as I thought, so I was lucky to have a friend to the coding for me. The installation is not that hard. for anyone interesting the MOST cable link here http://www.ebay.com/itm/MOST-Fiber-O...-/262306481634 |
02-06-2017, 10:34 AM | #17 | |
Rep 1,252
Docrace 6266
01-11-2019, 09:40 PM | #18 |
Rep 210
does this work with nbt
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
01-11-2019, 10:22 PM | #20 |
Rep 210
6wa is m3 cluster correct?
01-11-2019, 10:24 PM | #21 |
Rep 765
6wa varies from build to build. Example: F10 6wa is not the same as f30 6wa but can b retrofitted into f30 with some modifications.
