BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      01-27-2015, 10:23 AM   #89
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by Lucardos View Post
Hi Shawn,
thanks for your help. I was able to fix this problem.
I only have one problem that i don't get away. After coding my rear PDC stopped working. every time i put it in reverse i get error "no parking assistance, have the problem checked by service"
I already have put the old CAFD for Hu-CIC and REM, but the problem remains.
any suggestions?
Lucardos
Does your PDC module have CAFD with Green Dot?
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      01-27-2015, 11:18 AM   #90
Lucardos
Drives: F48 X1 192HP MINERAL GREY
Hi Shawn,
I do not have a PDC module. I also checked in previous SVT files but also there's no PDC present.
I only have rear PDC.
      01-27-2015, 11:22 AM   #91
shawnsheridan
So does REM then?
      01-27-2015, 11:31 AM   #92
Lucardos
So does REM then?
Yes, REM has a green dot. I also have replaced the old CAFD to be sure all settings are ok.
Can I do al VO code for all CAFD again, this time with no engine running, without causing problems.
could it be that during my previous VO coding something else was set wrong?
      01-27-2015, 11:39 AM   #93
shawnsheridan
Is your FA original or modified?
      01-27-2015, 11:46 AM   #94
Lucardos
at this moment FA is completely original. (old saved file)
      01-27-2015, 11:46 AM   #95
shawnsheridan
Well, I have no idea what is up with PDC then.
      01-27-2015, 11:48 AM   #96
Lucardos
Can I try to do a VO code for all CAFD again, this time with no engine running, without causing problems? I now have only VO coded REM and Hu-CIC.
      01-27-2015, 11:56 AM   #97
shawnsheridan
Yes. You can run the motor and VO Code everything except DME. DME is not the issue for sure.
      02-07-2015, 01:36 AM   #98
9114s
Life is short
9114s's Avatar
Drives: 2014-i3
Hello could you send me the last tool32?
I would like to clear the airbag fault.
thanks Chris
      02-07-2015, 08:41 AM   #99
shawnsheridan
thanks Chris
PM sent.
      02-07-2015, 12:35 PM   #100
9114s
Life is short
9114s's Avatar
Drives: 2014-i3
PM sent.
Thank you! Tool32 works perfectly with my i3 to clear up CEL.
      02-07-2015, 12:40 PM   #101
shawnsheridan
      02-16-2015, 03:37 PM   #102
sistrax
Drives: BMW F21
Hi, I can spend tool32 me too?
I have a fault in the water level indicator wiper saved want to remove.
Thanks, greetings.
      02-16-2015, 05:17 PM   #103
shawnsheridan
Thanks, greetings.
PM sent.
      02-17-2015, 11:26 AM   #104
sistrax
Drives: BMW F21
PM sent.
Thank you so much!
      03-03-2015, 09:12 AM   #105
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
Hey Shawn - since we're on the subject of REM/PDC... i'm looking to do a rear PDC retrofit on my F30. In order to do that, i need to retrofit my REM with an upgraded REM that has an additional connector needed to support rear PDC sensors.
The part that makes me nervous about this is the coding required. I've done cosmetic coding successfully for lighting, disabling warnings, etc... but nothing this major. Would it be as simple as adding a new option to the car? And actually i don't even know how to do that
Do you know what i need to do in order to code up the new REM for this PDC retrofit? I assume my current CAFD will not work.
      03-03-2015, 02:18 PM   #106
shawnsheridan
My best guess is you would need to add one of these option codes to FA (depending on exactly what you retrofit), and then VO code ICM, PDC, and Head Unit:
S507A Park Distance Control (PDC) Rear
S508A Park Distance Control (PDC) Front & Rear
      03-04-2015, 09:12 AM   #107
squidlyboy
squidlyboy's Avatar
I didn't realize you can still have a bunch of errors even though nothing shows up on the dash. That, and the fact that coding changes to one module could affect others somewhat concerns me. I'd like to see what potentially hidden errors show up as i did a bunch of seemingly cosmetic code changes recently.
Can i get a link to the EDIABAS/Tool32 software?
Also this INPA or ISTA Reingold diag tool seems intriguing - can i get a link to that as well to check it out?
Thanks Shawn!
      03-04-2015, 12:11 PM   #108
shawnsheridan
Thanks Shawn!
PM sent.
      03-05-2015, 01:59 AM   #109
petau
Hi shawnsheridan,
could i also get a link to the EDIABAS/Tool32 to clear my check engine code as well?
Thanks!
      03-05-2015, 12:24 PM   #110
shawnsheridan
Originally Posted by petau View Post
Hi shawnsheridan,
Thanks!
PM sent.
