BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Fixes for Rear End Slop
European Auto Source (EAS)
      03-27-2020, 03:03 PM   #1
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
I have a 6MT and I feel a hard jolt when shifting fast. I think it's probably from slop in the diff or control arm bushings, but not really sure. It's rough when shifting 1-2 or 2-3, but not as noticeable at higher speeds.
Has anyone experienced similar? And what did you do to correct it? It might not be limited to 6MT. I'm guessing if your 8AT downshifted to 2nd when you floor it, you'd feel something similar.
Options I'm considering now:
1. Diff bushings/supports
2. Control Arm (Trailing Arm) bushings
3. Motor mount bushings, but that's a big maybe since I don't want the car to rattle to pieces
Instagram @kern417
      03-27-2020, 04:58 PM   #2
BMWILUVU
Drives: 340ix
http://ultraracing.my/ecatalog/index...-lower-bar-4p/
      03-27-2020, 05:27 PM   #3
andino
Drives: F31 328i xdrive
I would start with the diff bushings. That's where I've helped reduce the amount of slop in previous cars. I haven't felt the need to it with my f31 yet but I'll probably want to do it after an LSD.
2016 328ix F31 | Bilstein B14 PSS w/ Custom Spring Rates | MPBBK | ER Catted Downpipe | MPE | VRSF Chargepipe | G-Plus FMIC | BM3 Stage 2 | K&N Drop In Filter | KC Front Strut Bar | VAC LCA Monoball | BMS OCC | Millway Camber Plates | KMAC FCA Monoball | KC RSB | OEM 513m | OEM 437m
kern4172802.00
      03-28-2020, 06:26 AM   #4
kern417
Cheapskate
Originally Posted by BMWILUVU View Post
I doubt that will help. I'm not really bought into chassis bracing to be honest. I'm looking for something more like this, that helps lock down the diff or control arms.
https://www.lowgo-shop.de/shop/diffe...r-modelle-f3x/
Yeah and I'm still on the stock diff. I'm not sure an LSD would help, or if it would potentially make it worse. I really hope it's not the diff itself.
On my VW a lot of people did motor mount bushings to reduce engine slop, because the issue was the engine torquing hard with the axles. Kind of like how you see fast drag cars pull a wheel off the ground. I think that *might* be a part of the issue as well, I just don't like how motor mounts ruin the NVH.
Also should note that I don't feel any wheel hop. Just a sharp thud when i bang into the next gear. So I assume it's something in the drivetrain shifting hard.
Instagram @kern417
      03-28-2020, 02:06 PM   #5
andino
Yeah I would be hesitant to go with motor mounts on a car that's daily driven. I suspect stiffening up the diff mount would help reduce the shock from the engine moving down the driveshaft. Alternatively, you could also look into rear subframe inserts to help tighten up the rear of the car. I notice a lot of flex/vagueness when pushing hard from the rear of the car because my front end is pretty tight now after replacing a lot of bushings.
kern4172802.00
      03-28-2020, 04:07 PM   #6
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
vagueness and thudness sounds like a broken sway bar end link...did you check them?
      03-28-2020, 08:39 PM   #7
kern417
Cheapskate
That's probably a lot of it. I have coilovers/camber plates already and control arms going in soon. Just can't make up my mind on what to do first for the rear.
No but i doubt that would cause the issue I'm having. It's when accelerating in a straight line. After the shift, i feel the drivetrain lurch.
Instagram @kern417
      03-29-2020, 12:37 PM   #8
nate158
Drives: F30 335i, E46 325i, 66 Mustang
Has anyone tried this bracket from Burger?
https://burgertuning.com/collections...-f-chassis-bmw
I haven't done much research but the description on the product page sounds like it does a great job of stabilizing the diff.
kern4172802.00
      03-30-2020, 04:44 AM   #9
kern417
Cheapskate
Nope, but I agree. That's why I made this thread to see some options. It's interesting that I never see anyone upgrading these. I guess maybe it's not as obvious with the auto.
Instagram @kern417
      04-09-2020, 02:32 PM   #10
nate158
My car is a 6-speed as well and I seem to have the same feel. I think it could also have something to do with the Clutch Delay Valve in these cars. CDVs make shifting a lot more rough. The CDV in the F30 is built into the slave cylinder on the clutch, but there is a write up somewhere on these forums where someone removed it.
I might install the brace I mentioned above. Seems like an easy and effective. Worth a shot. CDV delete would be a good idea too.
      04-09-2020, 02:47 PM   #11
exE36M3
BMW CCA Member
exE36M3's Avatar
244
Drives: 2015 435i M Sport
Now this is interesting. I recently got the motorsport LSD in my 8spd-auto. Been doing some rolling start 20-80 runs in manual and sport mode testing a JB+ I just put in. On hard acceleration and shifts, I can feel the rear-end twist mildly. This what you are experiencing?
      04-09-2020, 02:47 PM   #12
Eschmacher
Car Hypochondriac
144
2014 BMW 335i  [0.00]
This probably will increase NVH considerably, wouldn't you think? Also, $130 for some bolts and a bracket :/
If someone gives this a shot, let us know how it is!
Edit: I just noticed the "drilling required" note...
Power mods: VRSF CP/IC/Catted DP - AFE Cat-back - BM3 S2 93 - XHP S2
Handling mods: B6 damptronic - Eibach prokit - M Performance LSD - M3 brakes - EBC yellow
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      04-09-2020, 03:14 PM   #13
kern417
Cheapskate
mine is already removed.
it's basically like a slow, swaying motion. The car drives straight enough that I don't need to do any correction in steering angle, but it just doesn't feel direct. It's mostly on a low gear rolling start, right when you peg the throttle.
The initial feedback I got was it's due to the open diff, so that's disappointing if you still get a similar feel with an LSD. I've also heard that it's indicating the rear shocks are worn or too soft, but it's not really a bouncy feeling that I would expect from it being a suspension issue.
On my vw, I got a great improvement from doing motor mounts and it prevented a lot of vagueness in the steering and wheel hop. So i figured similar bushings in the rear would alleviate this effect.
Instagram @kern417
      04-12-2020, 11:18 AM   #14
Jvac
Drives: 2015 335i rwd
I don't agree that there is any squirm on acceleration with the LSD in back. The difference after going from the stock diff to the m performance is substantial in improving power delivery and rear end stability during acceleration and braking. And I don't even have any engine mods. If you have increased power from stock and or upgraded front suspension gear for added stiffness, then the rear should feel sloppy in comparison. From what others on the forum have said, the next steps to address the problem would be diff mounts, solid rear subframe mounts and/or rear control arms to dial out the stock system's compliance and bring it up to par with the front end. I have yet to take those steps on my own car because they require more time and money than I have right now, but the LSD was well worth the price and is highly recommended.
Sorry if any of this has been said already.
335i rwd auto, 2015 with m performance LSD and Dinan stage 1
kern4172802.00
      04-13-2020, 06:15 AM   #15
kern417
Cheapskate
Yeah I'm still thinking bushings will be the best fix. I don't have any slip so I know an LSD would be better, but in my experience it doesn't make a hug difference in straight line acceleration.
People in the WhatsApp group have been raving about solid subrame mounts. I think I'd start with the diff mount first, and then do the whole subframe if it still doesn't fix it.
And yes, my front end is very tight now. But it's not so much sloppy in "comparison," just sloppy period. I'm also wondering if increasing my tire pressure would help, so I'll probably try that first.
Instagram @kern417
      04-13-2020, 08:18 PM   #16
Jvac
A guy in the f80 forum uploaded a video that he took with a gopro mounted under the rear end doing some acceleration runs where you can see the rear subframe dancing around with the stock setup. There's definitely a good bit of slop there that can be dialed out between the diff mounts and subframe mounts. If I can find it again I will post a link.
kern4172802.00
      04-14-2020, 07:46 AM   #17
kern417
Cheapskate
Thanks man. That's actually what I was wishing I could do, but I don't have the balls to do lol. I just know something is shifting under there.
Instagram @kern417
      04-14-2020, 05:24 PM   #18
Jvac
I've searched for a while, and can't find that thread anywhere now. Must have been deleted or something. I came across it last time I researched the rear end mods about a year ago. This was something I always wanted to do but it is a big job. I haven't seriously considered moving forward yet because this is my daily driver and the economy is on shaky footing at the moment so I am saving, not spending. The entire subframe usually needs to be removed because the stock bushings are so hard to extract. One guy said he needed to blowtorch them out because they were stuck so bad...
Anyway the gist of all the research is this: the solid subframe mounts didn't add vibration or harshness. Only some reported a little additional noise, but if the car was already modded with things that increased nvh (ie monoball up front), then the mounts weren't noticeable. The majority of drivers who went down this road said that the differential and tranny mounts were the ones that really increased nvh. Here is a snapshot from a thread where the shop who is doing the installs gives feedback based on the work they've done and how their customers felt. It's not my personal experience but everyone appears to be very happy with the results.
      04-14-2020, 05:25 PM   #19
Jvac
pic
Pic
kern4172802.00
      04-15-2020, 06:47 AM   #20
kern417
Cheapskate
Found one on E90Post. I'd bet ours is similar if not worse from the E92 ///M3.
https://www.m3post.com/forums/showth...2#post21135012
Instagram @kern417
      04-15-2020, 11:52 AM   #21
Eschmacher
Car Hypochondriac
144
I just wanted to add my two cents... I have the bimmerworld solid subframe mounts, it was worth it. There was no increase in NVH at all. But it did accentuate the diff mounts weaknesses. Wish I had done the diff mount in the subframe at the same time, but I understand that one does add NVH.
kern4172802.00
Polo088161176.00
      04-15-2020, 12:48 PM   #22
kern417
Cheapskate
What do you feel that indicates the diff mounts are an issue?
Instagram @kern417
