BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      03-24-2020, 11:46 AM   #2993
F20_M135i
France
25
Drives: bmw f20 M135i Xdrive PWG
Originally Posted by davide18 View Post
lol... i Cry.....
I'm going to buy another unit ... and it's already my 3 unit ... AND THE LAST Do you recommend a seller? thx.
I think that touching the binary or the Android structure is a very bad idea, I now think I know the limits of the PX6; I would discover the S625 in a short time, but I will only set up the SU file and the ROOT rights will be assigned via PORTABLE PC / ADB / UNIT
Regarding the buying advice, I think that aliexpress direct is the best, even if I went through a SPANISH company which made me believe that they had stock then that I now have to wait 2 to 3 weeks (because it comes from China) so = Aliexpress with MEKEDE or NAVIFLY
      03-24-2020, 04:13 PM   #2994
daschacka
Drives: 435xd
Here is the method to log some data and do whatever you want with them:
Tasker event -> Logcat (Needs root)
Filter:
Code:
sendStatus Msg: {"jsonArg":"{\"acData
Then you will get this line every ~1 second while driving and everytime a door opens:
Code:
sendStatus Msg: {"jsonArg":"{\"acData\":{\"AC_Switch\":false,\"autoSwitch\":false,\"backMistSwitch\":false,\"frontMistSwitch\":false,\"isOpen\":false,\"leftTmp\":0.0,\"loop\":0,\"mode\":0,\"rightTmp\":0.0,\"speed\":0.0,\"sync\":false},\"benzData\":{\"airBagSystem\":false,\"airMaticStatus\":0,\"auxiliaryRadar\":false,\"highChassisSwitch\":false,\"key3\":0,\"light1\":0,\"light2\":0,\"pressButton\":0},\"carData\":{\"airTemperature\":11.5,\"averSpeed\":0.0,\"carDoor\":0,\"distanceUnitType\":0,\"engineTurnS\":1315,\"handbrake\":false,\"mileage\":214,\"oilSum\":23,\"oilUnitType\":1,\"oilWear\":0.0,\"safetyBelt\":true,\"speed\":78,\"temperatureUnitType\":0},\"mcuVerison\":\"615054dALS-NBT-GTH-190330-B18\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\\u0000\",\"systemMode\":1}","type":5}
You can split it in Tasker. For us the entries in carData are useful
airTemperature - is the temperature outside
averSpeed - doesnt seem to change
carDoor - equals a number =
4 is trunk
8 is engine hood
16 is front left door
32 is front right door
64 is back left door
128 is back right door
If for example 2 doors are open at the same time the number adds for example
front left door (16) and back left door (64) the number is then 16+64=80
distanceUnitType - doesnt seem to change
engineTurnS - is the actual rpm
handbrake - is true or false regarding your handbrake status
mileage - is the left mileage in km what you can drive with your gas
oilSum - is the gas left in your tank in Liters
oilUnitType - i havent found out what this is. Mine keeps at 1
oilWear - i havent found out what this is. Mine keeps at 0.0
safetyBelt - is true or false regarding your safetyBelt status
seems like it only affects driverside
speed - is your actual driving speed in km/h
temperatureUnitType - i havent found out what this is.
Then you can process these values to display them in a widget or anywhere else.
I've saved images for the door value. Each value have its image with displaying what door is open
You can get the images here:
https://mega.nz/#!78sXETiK!Xt1BPGNPG...S3cy_MnjboIV3A
I made my launcher look like this:
Since i got asked a few times, this is the Wallpaper:
View post on imgur.com
Mirjam43.00
      03-25-2020, 05:01 AM   #2995
b777rky
Drives: f45
[QUOTE=F20_M135i;25962250]Hello
it is indeed very curious as a defect, I can not find an explanation here. Try downloading a FIX GPS application from the google Play store and see how your unit reacted (that was the goal of my first message) Maybe you should update your unit, you will find in this thread what to do.
The gps test app used in the video, it have an option "gps fix" but it doesn t help, like you see în the video after pressing fix option, i tried to enter again in sygic and no signal image appear.
I tried to find an update for my mcu but i can t find, mine is 012042bJLY-NBT-HW7190628[B1290_170325]
      03-25-2020, 08:29 AM   #2996
F20_M135i
France
25
please take a photo like the one below :
      03-25-2020, 09:41 AM   #2997
F20_M135i
France
25
Exclamation
IMPORTANT INFORMATION /!\
After dismantling my PX6 RK3399 unit I see that I no longer have any control over the brightness of my original Idirve, I am not talking about the counters, which react to them, but rather the original screen which does not respond more to the settings or lights on.
I need to code the car I think, I'm going to get started tonight with BimmerCode.
I think you should know that.
NB : I'm used to coding on vehicles, I'll tell you what it is here.
      03-25-2020, 09:51 AM   #2998
daschacka
Drives: 435xd
You mean in iDrive - Settings -> Control Display -> Brightness
doesnt affect when you turn it up or down?
      03-25-2020, 10:07 AM   #2999
davide18
Drives: BMW E87
i found the limit editing the Kswcarlauncher.apk or KSWCarlauncher.apk ... When i put the modified apk on system app folder the system is crashed and i reboot in bootloader....
I have order a new unit in Spain to XTRONS... Snapdragon 625 64+4 android 9.0 470€.
      03-25-2020, 10:08 AM   #3000
davide18
Drives: BMW E87
Filter:
Code:
Code:
4 is trunk
8 is engine hood
YEAH!! AWESOME!! Can u share your apk? I like that!!
      03-25-2020, 03:28 PM   #3001
F20_M135i
France
25
yes the electronic module "FEM 01" was affected by the brightness adjustment of the android unit (it was faulty with a value on #FF instead of being in #yes or #no)
It is a good choice, the Xtrons are very famous.
For the unit crash: do not touch the launcher!
Setting up a modified and poorly signed / compliant .apk file can have serious consequences, this is only my opinion.
      03-27-2020, 03:37 AM   #3002
bun0708
Drives: BMW F11(2011:NA30)
Hello, for the first time post.
I always refer to this forum.
I was wondering whether to post this.
But, I will post it because you seem to be always struggling to get MCU and firmware.
I discovered this site by accident.
So I don't know when it will disappear, but it's like a developer archive.
(It seems that you can download without an account.)
https://mega.nz/#F!kbYFBS5C!gE-QFJoUp__YMrh0SPxiJA
I thank the archive maintainer.
      03-27-2020, 03:40 AM   #3003
zorglubxx
zorglubxx's Avatar
Netherlands
Drives: 2010 E91 Touring
(Also posted on Android10 site)
It's been referred many times in here. I believe it's maintained by Kri
      03-27-2020, 03:53 AM   #3004
bun0708
oh, sorry.
Excuse me.
It's embarassing.
      03-27-2020, 04:34 AM   #3005
Kri
Austria
322
Drives: E87
Nope i`m not the owner of this archive ^^
Kri
      03-27-2020, 06:55 AM   #3006
F20_M135i
France
25
for once, maybe we should save all this right?
      03-27-2020, 09:18 AM   #3007
SupersixM
SupersixM's Avatar
158
Drives: Bmw X6M
[IMG]undefined[/IMG]
any available MCU & Firmware upgrades?
      03-27-2020, 09:54 AM   #3008
b777rky
Drives: f45
Hello
davide18 Very bad news, your unit is in FASTBOOT mode, i.e. it is waiting to receive either a download via computer / or physical manipulation (impossible on our unit) It seems that there is no possibility at this stage (see page before and my warning on this mode).
Tried the gps fix, same problem, where can i find an update for rom or for muc, because i google it, and nothing.. And from github they not working when i push update.. It s say "Waiting" and after 15mins i close it..
      03-27-2020, 01:05 PM   #3009
Alves_369
Drives: BMW e90
Hi, on the dashboard where we can see the info from the car speed and rpm etc..how can i setup the mileage from liters to km?
      03-27-2020, 05:25 PM   #3010
pitoncho
Drives: bmw e87
hello, is ther any update for the px6? i see in avin usa that they have the avin usa theme, does anybody have the rom file or update of this?
Thank you!
      03-28-2020, 06:34 AM   #3011
SupersixM
SupersixM's Avatar
158
Drives: Bmw X6M
For those of us that brought the PX6 720 units from Carnavi @Aliexpress. Maybe we should bombard them with requests ONLY on the Aliexpress.com chat line for a release of the latest MCU and Firmware. And when they dont respond or cooperate we report them to Aliexpress.com for not following through on 1 year customer support..At least you'll have a record of trying to reach them.
I'm on MCU Version:: 61504b3-ALS-NBT-HWL-191017[1920
I have to do the music app trick to hear Waze direction and alert. Which I'm hearing they fixed.
I have minuscule iDrive controller support on Android side which I heard it's now universal. And a couple other things.
It's not fair to hear you shelled out 700 bucks and you cant get a basic MCU update. Not like I want an Android 10 update.
      03-28-2020, 07:59 AM   #3012
F20_M135i
France
25
      03-28-2020, 04:54 PM   #3013
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013
Thank you!
The last one is the one they released on December but doesn't work
Gabo
      03-29-2020, 03:41 AM   #3014
jgostarr
Drives: BMW F30 (328i)
Originally Posted by Mirjam View Post
The splash.img is empty, or black, to replace the static boot picture, so that only the animation is shown. To change this, you can either choose a boot picture in Factory settings, or replace the black splash.img in the animation package you downloaded.
You can download the boot animation package I'm using here (available 7 days, feel free to upload to a permanent location); the BMW logo is displayed first (splash.img), then the BMW M car animation is run. To install, unpack the zip file to a USB stick root, OEM folder will be created automatically (overwritten if exist), then just insert the USB stick to the unit and wait a few moments for a confirming message that boot animation has changed.
By the way, I tried to speed up the animation by deleting half of the pictures. It runs twice as fast then, but the total boot time is not affected anyway. My boot time is 24-28 seconds, average 26 seconds.
Do you mind sharing your bootanimation again?
