09-05-2018, 12:27 PM | #45 |
Rep 5,082
09-05-2018, 09:41 PM | #46 |
Rep 56
12-05-2018, 09:05 PM | #50 |
Rep 56
12-05-2018, 09:06 PM | #51 |
Rep 56
12-06-2018, 01:30 AM | #52 |
Rep 1,827
I've got parts and tools en route, scheduled for delivery tomorrow for a day of fun under my car. Planned projects:
Brake fluid flush Differential fluid drain & fill Replace serpentine belt, tensioner and idler pulley Re-torque bolts for the oil filter housing (I seem to have sprung an oil leak and I'm hoping it's just that again and not something more costly/labor intensive. I'll replace the gaskets again at my next oil change) Speaking of the leak, I've got a bunch of oil down the front of my engine, on and around the belt & pulleys, and it seems to have sprayed off the belt onto the side of my air box and other surrounding areas. Is it advisable to spray the area down with brake cleaner to try to isolate where exactly the leak is coming from? Any thoughts of what else might be leaking? I thought maybe the valve cover gasket, but I'm not getting any oil down the passenger side where it usually leaks and vaporizes on the exhaust manifold, and it originates higher up on the engine, so I don't think it's the oil pan gasket...at least I'm hoping it's not. That project seems like a PITA. I'm hoping re-torquing the OFHGs will quell the leak enough until I can replace them again and that that will solve the problem, but I'll probably get the VCG and oil pan done at some point anyways, just based on the mileage (102k ish). Any other thoughts/insights would be welcome!
12-06-2018, 12:18 PM | #53 | |
Rep 235
12-07-2018, 04:21 AM | #54 | |||
Rep 54
01-01-2019, 10:58 PM | #55 |
Rep 1,407
Drives: 13' F30 328i 6MT
I cant find any info on here ( I think I searched every way ) has anyone performed a walnut blasting on the N20 yet? Im at 98k miles and getting ready to do a ton of preventive maint. Being the N20 is more or less an N55 with 2 less cylinders I would assume its in need now or real soon.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
01-14-2019, 03:26 PM | #56 |
Rep 1,407
Nobody has info on whether or not we need to walnut blast? My cars approaching 100k, I get wierd hiccups here or there with idle but other than that its fine.
01-16-2019, 05:37 AM | #57 | |
Rep 308
How do I know if my 2017 328xd LCI has transmission cooler?
2017 F31 328d xDrive
M Sport M Performance Last edited by Hypermile; 01-16-2019 at 05:44 AM.. |
01-18-2019, 09:41 AM | #58 | |
Rep 235
01-29-2019, 10:40 PM | #59 |
NewFinishColumbia/detailer
604
Rep 2,096
Be careful with the big bolt that holds the isolator on the rear diff. It's a steel bolt threaded into the aluminum diff cover. The isolator has to be removed to access the drain/fill plug. I cross threaded mine and had to spend an extra 45 minutes tapping the threads back out before the bolt would go back in. There's no drain plug unless you have the MP LSD so you have to suction the fluid out through the one plug.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
