BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Possible coding fix for those with soft M Sport/Performance brakes?
VIBE Motorsports
      10-29-2015, 01:16 AM   #67
Tengocity
Tengocity's Avatar
Scotland
4946
Drives: M4 CP/330e/Boxster S
Originally Posted by JinAM
Hi Guys, thanks for the info. I have done what Tangocity has posted. And I can confirm that it works and reduces the spongy pedal feel to almost none.
Really, that's interesting! I'm not sure it was ever clear exactly what one had to do, just that there might be a coding way to resolve it.
Can you share exactly what it is that you did? Settings before and settings now?
Also, do you have active cruise control by any chance?
Current: 2018 M4 Competition, 2016 F30 330e MSport
Gone...Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
      10-29-2015, 03:28 AM   #68
simon.
Drives: F48 25D mSport
Re watching this as now have a coding lead.
      10-29-2015, 03:33 AM   #69
SkyJawa
SkyJawa's Avatar
England
2281
Drives: 335d
Interesting results. What were your settings before the changes - really need to know that for reference - as there appears to be no similarity between cars fitted with the same system, unless ACC has an impact.
While mine is still spongy, since I had the front discs and pads replaced under warranty it is better.......
      10-29-2015, 03:35 AM   #70
Tengocity
Tengocity's Avatar
Scotland
4946
Do you have adaptive cruise?
That's my latest theory for spongy brakes... Cars with this are set up with soft initial bite to help the system to modulate the braking.... Thoughts?
      10-29-2015, 03:44 AM   #71
SkyJawa
SkyJawa's Avatar
England
2281
Drives: 335d
Yes mate I do, its certainly a possibility though I'm not sure theres any difference in feel when its on or off so would likely be all the time regardless of cruise active.........
ACC also has FCW so maybe that has an element where it starts braking for you and firms up the pedal for you to slam your foot on it.
Only way to tell would be seeing the coding of a few ACC car, standard cars and Safety Pack with no ACC cars (IIRC that has the FCW in the package?).......
      10-29-2015, 05:28 AM   #72
VenomUK
Drives: 428i M Sport
I cant say that mine feel soft but then again I've not driven another car with MS brakes. I always found them to be very responsive with a good level of bite.
      11-15-2016, 12:05 AM   #73
LittleBlackHawk
Drives: F30
Originally Posted by RichardM View Post
I had a look at mine and I don't have this set, but that isn't surprising as this is under "aftermarket retrofit" which ours aren't, they are factory so wouldn't be listed here.
I have no issue with my cars stopping power so I'm not sure I want to try setting them to aftermarket!
If you look at the attached I don't have these options. C_Variante_Bremsscheibe_vorne_e (Front Brake Disc) has no valid values to choose from.
C_Variante_Bremsscheibe_hinten_e (Rear Brake Disc) does have different values to select but none are in mm.
The values may change of course once you VA code the aftermarket performance brakes.
Hi I have exactly the same situation as you. Have you ever figured out why is this different from the other ppl's posting? Mine front rotor size also not changeable, and don't even have rear rotor size selection as below. Anyone could help or have any idea why? Thank you
Name:  disk rotor esys_conew1.jpg
      12-21-2016, 12:33 PM   #74
bateau
Drives: 2013 328i Sedan
Attachment 1527110
I believe that means you don't have correct pszdata for the i-level installed in your car. Get the latest pszdata and check again.
Question: Why is it necessary to manually change rotor size after adding SPBR and VO coding DSC? I would have expected VO coding to include new rotor size.
      12-22-2016, 10:17 AM   #75
LittleBlackHawk
Drives: F30
I thought it would, but some say yes and some say no....
      12-29-2016, 08:14 PM   #76
LittleBlackHawk
Drives: F30
I have updated to the latest pszdata and esys and still no rotor size options. I guess there are two different sets of the DSC contents as i have seen others who doesn't have these options, too. Quite weird....
      05-02-2017, 12:18 PM   #77
graphys
Drives: F30
Can you fix this problem. If you say yes; how to?
Regards.
      05-02-2017, 04:09 PM   #78
graphys
Drives: F30
Can any one fix this problem? Added SPBR but not change anything.
Please help this issue.
      05-03-2017, 03:11 AM   #79
graphys
Drives: F30
Hey guys. Anyone can fix this issue? Please answer.
      01-13-2019, 12:25 PM   #80
vitu
Drives: F36 LCI
This post has been continued somewhere else? I am in the same situation as mentioned in the photos
