BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Coding HK to B&O. Anyone tried it?
      09-18-2017, 03:55 AM   #1
Chelsea_Tractor
Chelsea_Tractor's Avatar
Drives: X5M
See here for details on how to do it:
http://f80.bimmerpost.com/forums/sho....php?t=1322442
Please share your thoughts if you have tried it.
      09-18-2017, 04:06 AM   #2
vorph
Drives: F30
You can code head unit for 6F2, no problem, unfortunately without proper B&O amplifier those settings are useless
      09-18-2017, 05:21 AM   #3
Dr Forinor
Dr Forinor's Avatar
Drives: 2015 F31 335d
I would have imagined as far as speakers go, software can only make so much difference? The majority of the difference would come from the hardware, ie amplifier and speakers?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs. Poly bushes.
      10-12-2017, 12:49 AM   #4
Chelsea_Tractor
Drives: X5M
I got around to it finally and I can say I notice a difference. Love it. Anyone doubting it can try it and if you don?t like it then you can always revert back.
What it does is code the amp so the amp shapes the signal different and the speakers handle it quite well.
JLR19691489.50
      10-12-2017, 02:30 AM   #5
Dr Forinor
Dr Forinor's Avatar
Interesting, thank you for your update.
      10-12-2017, 03:09 AM   #6
ciscopete822
ciscopete822's Avatar
356
Drives: S5 , RS5 , Golf R
B&O dsp was designed and engineered with components of different class and characteristics in mind , it will sound different but deffo not better. Good find though.
F30Andy871.50
      10-12-2017, 03:46 AM   #7
Chelsea_Tractor
Drives: X5M
There is a noticeable difference. Expanded mode is better than Logic 7. However, we all buy in with our ears. So it may not be to everyone?s taste. After about 3 hours of listening I can say it was a good idea for me.
The feedback in the original posted thread link probably captures it best with more views.
It is not true B&O by any means. More like a mutation.
      10-12-2017, 04:06 AM   #8
R99
Drives: 2016 330d F31 Touring
I would love do see a full B&O retrofit into a F31 - I wonder if anyone has ever done it?
I assume the amplifier wiring would be the same, but tne amp & speakers (plus HU Coding) would the the physical differences?
      10-12-2017, 04:54 AM   #9
stu14t
stu14t's Avatar
Scotland
382
Drives: 335d MSport+
The feedback in the original post probably captures it best with more views.
I agree. It will be different, but saying it will be better or worse will be down to individual taste alone.
I'm going to give it a whirl and listen for myself.
To be fair, I'm a keen audiophile and IMO I've only ever seen B&O as a stylistic statement more that sound alone. I would like to see a good UK name like Bowers and Wilkins in BMW's. I've had a few pairs of their speakers over the years and for me, they are the best.
New - 2017 F30 335d M Sport + in San Marino Blue
Gone - 2015 F30 LCI 320d M Sport+ Step Auto
Gone - 2012 F30 320 ED
Gone - 2011 E87 118d
      10-12-2017, 05:06 AM   #10
PA11L JJ
PA11L JJ's Avatar
51
Drives: F30 335d LCI M Sport
+1
Current: F30 335d
Gone: F56 Mini JCW - F80 M3 - F20 M135i - E89 Z4 - F30 335d - E92 M3 - E81 118d - Audi Q7 - E90 335d - VW Scirocco 2.0GT - And a few bangers not worth mentioning.
      10-12-2017, 07:14 AM   #11
Chelsea_Tractor
Drives: X5M
Right on!
Still using my BW DM601
stu14t382.00
      10-12-2017, 07:31 AM   #12
vorph
Drives: F30
Wiring is bit different as B&O use different setup with ASD for 16 speakers and LED surround in few of them. Personally use 4x B&O mids and tweeters already, have amplifier ready to go, but no time to finish my project.
      10-12-2017, 07:43 AM   #13
R99
Will you be using existing HK wiring loom with your project? Or making a custom loom?!
      10-12-2017, 08:25 AM   #14
vorph
Drives: F30
I did my HK sound system from scratch, all loom build from new genuine parts.
      10-12-2017, 08:35 AM   #15
R99
I was just trying to work out what you are doing with your B&O parts?
Are you going to run a B&O amp with HK wiring and a mixture of B&O mids / tweeters & some HK speakers (e.g subs)?
      10-12-2017, 08:54 AM   #16
vorph
Drives: F30
As said above had fitted B&O 4x middle and tweeters, SWS-8 subs, and HK rear parcel shelve. Everything powered by LCI HK pro amp.
Must manage housing first for B&O subs and find set of rear parcel mids and tweeters from F13/06.
      10-12-2017, 09:51 AM   #17
wibbles
Drives: M135i AT LCI
why did you not fit the B&O amp Vorph?
Current: F21 M135i
Previous:
2015 F31 330dX, 2011 F20 120d SE , E90 335i, 2010 Alpine White N55 135i 6MT, 2009 LMB LCI N54 135i - Cobb tuned!, 2010 F10 530d SE, 1986 E30 318i,1981 E21 320i Auto
      10-12-2017, 10:26 AM   #18
R99
So B&O mids / tweeters are capable of being driven by HK amp?
How do they sound?
      10-12-2017, 11:34 AM   #19
vorph
Drives: F30
Don't have time for it, my surround camera stuff and HUD also wait.
      10-12-2017, 11:47 AM   #20
vorph
Drives: F30
How do they sound?
Of course they capable, is bit different but not as should be. I had done one B&O system on F13, completely from scratch, together with LED and ASD.
Very powerful with unbelievable sounds distinction.
      10-12-2017, 04:24 PM   #21
R99
My thought process is that surely the B&O amp would have a higher output per channel compared to the HK, hence the question is the HK amp is capable of powering them. Also, what Ohm are the B&O speakers vs HK, are they the same?
I would love to hear a B&O system and see what it offers!
2016 F31 330d M Sport Touring
Individual Pure Blue | Oyster Leather | M3 Mirrors | MP Kidney Grilles | ID6 | Custom Steering Wheel |
      10-16-2017, 04:27 AM   #22
Darth Helmut
Drives: BMW F32 435d XD
Coded the DSP to Bang & Olufsen. It does make a difference. Sound seems to have more depth, bass is crisper and the surround processing is better than the L7. I actually thought something had hit or fallen off the car at one stage because the way the sound is now better!
Using Bimmercode (iOS expert mode): HU_NBT or HU_NBT2 > HMI 3000 > HIGH_END_AUDIO_MENUE = volle_insz
stu14t382.00
Kal1012640.50
Junebug85513.00
F30Andy871.50
