BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Bimmercode update - BEWARE
proTUNING Freaks
      09-20-2018, 01:47 PM   #23
TiredGeek
Old Fart
TiredGeek's Avatar
Drives: 335dx F31 Shadow EB
* UPDATE *
Car has been restored by stealer today, they were really baffled, couldn't for the life of them figure out what had happened, and it took three hours of looking
Anyhoo, all is working again and I must say the guy from Bimmercode has been really helpful
The conclusion I have come to is that coding was either interrupted or corrupted by my phone connecting to the car while it was doing the coding. I never considered that before. I'll be either deleting the phone from the car or the car from the phone before I do any coding again.
What I think happened is that as the head unit was coded it rebooted, this in turn dropped and then reconnected to the phone - mid coding.
Bimmercode didn't report a failure but maybe it was a corruption of data or a few missing packets...…
As for my mirror issue, well, that's a case of
Turns out that if the mirror switch on the door is set for passenger mirror it won't tilt in reverse, set for drivers mirror and it will. DOH
Thanks all who offered advice, I think it's safe to install the update, just learn from my mistake and make bloody sure nothing can interfere with the coding
The doctors said it's OK to listen to the voices..... just don't do what they tell me
F30Andy1774.00
      09-20-2018, 02:56 PM   #24
Techno 9000
Drives: 435D Estoril Blue
Good news.
I'm just about to start down this road myself and have read that you ought to place the phone in 'flight mode' to prevent incoming calls etc from interrupting the coding process.
      09-20-2018, 03:25 PM   #25
TiredGeek
Old Fart
TiredGeek's Avatar
Originally Posted by Techno 9000 View Post
Good news.
Yep, it was in flight mode.
But you have to have Bluetooth on to talk to the OBD adapter, at which point the car then connects to your phone over Bluetooth as well.
The only safe way as far as I can see is to delete the connection between the car and the phone to be certain they don't try talking during the coding.
You can't even just disconnect the phone in idrive as when it reboots during coding it'll see the phone and try connecting to it.
Good luck and make sure to keep multiple Bimmercode backups in various different places / devices for safety
      09-21-2018, 01:28 AM   #26
richatha
richatha's Avatar
England
166
Drives: 340i
@TiredGeek when you mentioned the mirror tilt for the drivers. Do you have to code that or is it in the idrive settings as I can only get the passenger one to tilt like you previously.
      09-21-2018, 05:49 AM   #27
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Bimmercode is a great idea but I'd never recomemd it as it drops connection regularly then bricks ECU's.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      09-22-2018, 02:28 AM   #28
Mikesmith2939
Drives: 2013 320i xdrive
My obd dongle is WiFi with a very stable connection on iPhone.
I think it's bluetooth dongles that suffer with the dropouts etc because as others have stated it connects to the car head unit.
      09-22-2018, 03:21 AM   #29
Rhino at Work
Rhino at Work's Avatar
Drives: G21 330i Portimao Blue
Isn't that why they tell you to put it in flight mode before coding? (or is that for some other reason)
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition
Previous: EB F30 330d xdrive
      09-22-2018, 03:57 AM   #30
rlmesq
Drives: 2018 440i M Sport
The driver's mirror doesn't tilt. He was saying the passenger mirror tilts on reverse when the mirror adjustment switch is in position to control the driver's side mirror.
      09-22-2018, 05:11 AM   #31
TiredGeek
Old Fart
TiredGeek's Avatar
Yes, and I'm an idiot
I simply had the mirror selector switch in the wrong position
      09-22-2018, 10:57 AM   #32
Hooded
England
1669
Drives: F30 330d M-Sport
A new update for the IOS BimmerCode app has just popped up on my phone. Who wants to test it out first?
      09-22-2018, 11:57 AM   #33
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
How are your reading skills?
If good, how about having a look at Post #18 and Post #22 of this thread?
      09-22-2018, 12:29 PM   #34
Hooded
England
1669
Lol .. cheers .. I only looked at page 2 of the thread today (and it's been a while since I checked this thread)
      09-22-2018, 01:35 PM   #35
TiredGeek
Old Fart
TiredGeek's Avatar
Well, Bimmercode got updated again yesterday, not just new coding data, but a new build with bug fixes.
I think I might leave it a day or two
      09-22-2018, 02:05 PM   #36
SkyJawa
SkyJawa's Avatar
3719
Drives: F10 530d
I always turn off BT in the car before using BC and it’s been fine.
      09-22-2018, 02:27 PM   #37
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
I just used it again today. No abnormalities.
      09-23-2018, 04:17 AM   #38
Mikesmith2939
Unfortunately if using a bluetooth adapter even in flight mode it will still connect to the headhunt.
      09-23-2018, 02:19 PM   #39
TiredGeek
Old Fart
TiredGeek's Avatar
Sacrificed a chicken to the coding gods and it must have worked cos I had no problems
Deleted phone from the car and car from the phone just to be sure. Made sure wifey's phone was well away so no chance of it being seen by the car...
Went back in and sorted:
all seat belt warnings off
close mirrors, 1 second delay
door handle LED on reverse
stop / start off
stop / start remember last setting to on
stop / start in eco poo not active
stop window with door open to not active
decoupled ambient lighting from dash lighting
mirror tilt on reverse to aggressive
acoustical lock checkbox in menus to on
warning sounds to Rolls Royce
ring tone to Rolls Royce
tires to pressure and temperature
start animation to M
rear DRL outer to active
So glad to have stop / start deactivated. What a stupid system.
Can't figure out the footwell switch to close the tailgate, changed the only one that said "close with long push" that was inactive to active but it still only opens the tailgate from that switch, pushing and holding it does nothing
      09-23-2018, 05:23 PM   #40
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
I figured that one out (with some help from Bimmercode)
The only thing you need to code is "Tailgate rocker switch position 1 operation mode" to "Open and close". Ignore all the rest
Now the trunk even closes with a single button-press. No need of long press anymore
Could you explain that one please: „stop window with door open to not active"?
TiredGeek360.50
      09-24-2018, 01:20 PM   #41
TiredGeek
Old Fart
TiredGeek's Avatar
If you open your drivers window fully, pull the switch to close with one shot so the window starts to go up without holding the button, then open the door. The window stops.
God alone knows why that's needed, but if you change it to not active then the window just carries on going....
I've just had an email from Stephan...
Hi Greg,
please try to set position 2 operation mode to “Open and close” and “Position 2 close with long press” to “Not active”.
Schöne Grüße / Kind regards
Stephan Gauch
I'm working tonight so I probably won't have chance to do it 'till the weekend but from what you've said it looks like we have a winner
      09-24-2018, 09:38 PM   #42
RobinFL
Drives: BMW 440GC
Just got a Kiwi3 and played with Bimmercode for the first time this weekend. Updated in my phone and ipad and there were no problems at all connecting wirelessly through my ipad. Cool stuff. Only thing I couldn't figure was speedometer reading to neutral or -1 mph, from its current -2mph. I'm not sure this is there, or at least I didn't see it and I went through the menus a couple of times. I'm curious what mini or Rolls Royce sounds sound like.
      09-25-2018, 01:49 AM   #43
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
Hi Greg,
Stephan Gauch
Stephan was initially suggesting Position 2 as well, but that won't work, as we don't have a rocker switch with 2 positions.... there is only one position, hence Position 1 needs to be modified.
      09-25-2018, 09:23 AM   #44
TiredGeek
Old Fart
TiredGeek's Avatar
I tried it this morning, Stephan's suggestion didn't work. I'll reset to stock and try your version, thanks
