BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 420d Exhaust Advice
proTUNING Freaks
      01-12-2019, 03:57 PM   #1
S5N
Drives: F32 Estoril Blue
420d Exhaust Advice
Hi all,
I know there are hundreds of threads about this but I haven't been able to get my answer I'm afraid!
I'm looking to convert the single 'pea-shooter' exhaust on my pre LCI F32 420d to a twin, similar to a 435d. Now I've been in contact with a exhaust specialist and I've been told this won't be possible? The backbox apparently will need to come off and just a pipe will be run, thus meaning I'll have a backbox delete?
I'm not keen on the idea and would like a second opinion. All I'm wanting done is the tips to be changed (no noise or performance gains), apparently there is not enough room under the car to fit this and this is the only solution. Has anyone else done this change and can advise how to go about doing it?
Questions I have;
- Can I fit a backbox off a 435d onto my 420d and be done with it?
- Are the tips bigger on a 435d compared to a 430d?
- Is it possible to just change the tips on my car?
- Can anyone recommend an exhaust specialist in the South/West London area? Can travel if the job is going to be right as I don't want a mess to be made of my car!
- How much should I expect to pay for something like this? Was quoted £210 today for this work.
TIA.
      01-12-2019, 04:03 PM   #2
Lincoln61
Lincoln61's Avatar
Drives: 2018 430d Msport+
the simple option is this
https://www.ebay.co.uk/itm/Genuine-B....c100505.m3226
Current - 2018 F32 430d M Sport+
Previous - 2013 F30 320d M Sport
Previous - 2008 E92 320d SE
      01-12-2019, 04:06 PM   #3
Lincoln61
Lincoln61's Avatar
It's a cut and fit job, just need the pipe and new diffuser
S5N26.50
Simon8919.00
      01-12-2019, 04:51 PM   #4
s11nny
Drives: 420I M Sport
Any exhaust shop can weld a tip on. I had mine done by an exhaust place. The only thing you have to do is fit the diffuser for a double or cut it.
Powerflow in cov quoted me 120 for mine, i ended up doing at mij in walsall.
S5N26.50
      01-12-2019, 05:51 PM   #5
robbiep
Drives: F31 325d M Sport, Z4 20Si
I see no technical reason it can't be done, or that it should be horribly expensive to accomplish. The 325d / 425d (which on the F3x series is the same 2.0 engine, but twin-turbocharged) came with twin exhaust pipes, as do the post-LCI 320d/420d cars.
Different tailpipe / back box, different diffuser.
S5N26.50
      01-13-2019, 01:41 AM   #6
RENT-A-GOAT
RENT-A-GOAT's Avatar
Drives: F31 320D Xdrive Msport+
The twin tips were fitted to the 420D at LCI so look for a 420D LCI back box with these on and get a twin exit diffuser to go with it for the proper oem look/job there's bound to be a few of these for sale as a lot of owners go for the duel (one on each side) style as per the 440
S5N26.50
      01-13-2019, 10:41 AM   #7
S5N
Cheers for the help guys, I'm going to go elsewhere and have a chat as well. The specialist I spoke to was Powerflow so will be worth going to another exhaust place and seeing what they say. I have already bought a diffuser from a 430d so no worries there, it's just the actual exhaust I need fixed now.
The original M Performance accessory tail pipe trim I'm not a fan of. I don't like the look of the thin tailpipes and would rather go something like the original with thicker tips.
Does anyone know of any decent exhaust specialists around London?
      01-13-2019, 05:07 PM   #8
C320
C320's Avatar
Drives: '15 F30 320d, '15 F86 X6 M
I would have thought Powerflow would be able to do what you were looking for? You should be able to get a single outlet on each side or the twin on one side quite easily but it will mean cutting your existing system. When I had a 2009 E60 520d, I had a twin outlet exhaust trim fitted by these guys in Romford, not too far from East London. It was fitted by them when the car was about 3 days old and it was fine in the 4 years I had it. Someone local bought the car and I last saw it about a year ago and the trim is still on there (after about 9 years!)
This is what I had, it wasn’t quite the same as the 530i / 530d style it was a bit beefier looking, almost like the 550i
https://www.mstyle.co.uk/twin-chrome...trim-7177.html
      01-13-2019, 05:32 PM   #9
S5N
The guy I took it to at Powerflow definitely said it can be done, it would just mean that he would delete my backbox and put a pipe in its place as there isn't enough space for a bend underneath. I don't see what the issue is though, I'm only wanting tips changed so surely it can be changed like above except with different tips?
The tips you've linked are exactly what I want! OEM look, nothing aftermarket.
      01-13-2019, 05:43 PM   #10
s11nny
looks like he is taking the easy option, as there is less work involved in a backbox delete. with welding tips on they have to cut and then weld new pipes etc.
don't know if the 20d exhaust is diff to the 20i, but I managed to weld a diff di on mine
      01-13-2019, 05:50 PM   #11
S5N
Thought that, not keen on the idea of having a backbox delete on my car. It'll cause me all sorts of problems come MOT time and selling time as well, not to mention the stupidity of having a backbox delete on a 420d.
I'll try a different Powerflow branch and see what they have to say. Also going to try Profusion if anyone's used them before?
