01-13-2019, 02:06 PM | #1 |
Rep 22
328i ran with Low Oil Light 2k miles later its okay?
Hey guys I am looking to get some advice on whether I should keep or sell my car. I have a 2015 328i with 43k miles on the odo. I changed my own oil at 41k because I am a second owner and the free maintenance didn't transfer. My dumbass stripped the drain plug and didn't realize it. Two days later the low oil light comes on, I drive for about 4 miles until I pull over and have it towed to the dealer. They told me they drained only half a quart out and the engine is "shot" and not covered under warranty. Quoted 15k to replace. So I come pick up the car and it runs fine, sounds fine, I don't hear any knocking, although they claim they heard it knock.
I drive it off the lot and 2k miles later here we are the car is still fine. I haven't babied it the whole time either it's definitely had some hard pulls and 100+ MPH runs. I am however worried that this is a ticking timebomb and the engine could fail any month now even though it isn't making any weird noises or acting strange. The warranty is also going to be up soon. I asked BMW if they would explain exactly why the engine was 'shot' and they said well that would cost about $1k to open up the engine to look at the camshaft and everything I think. So essentially do you guys think it's worth it to keep the car and should I have a 3rd party do an inspection for less? I'm really leaning towards selling it as I don't want it to fail and then I'm just out all that money, it's hard though as I love the car, I've done a lot of mods and it will be paid off in less than a year. TLDR: Car ran with low oil (1qt-0.5qt) for about 4 miles, dealer says it's shot but I've driven it with no issues for about 2k miles now. Sell the car or risk it and keep it? |
01-13-2019, 02:24 PM | #2 |
Rep 1,170
Personally I’d drop that car like a hot rock. May the car God’s have mercy on the next owner.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
01-13-2019, 02:46 PM | #3 |
Im real pressed.
104
Rep 203
I would hate to trade it for someone else to have to deal with a failed engine, but if that's what you have to do, do it and do it fast. I would've probably traded it the day the dealer told me the engine was shot before any issues arise.
Current Lineup: 2017 Tesla Model S 100D/2017 340i Xdrive/2015 Audi Q5 Prestige Quattro/2017 Kia Optima SXL
01-13-2019, 02:49 PM | #4 |
NewFinishColumbia/detailer
604
Rep 2,096
Change the oil again without doing any damage and have a Blackstone analysis done to check the condition of things. Just so you know, a new Steve Dinan forged N20 built for racing is only 10k.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
CSBM52695.50 |
01-13-2019, 02:52 PM | #5 |
Rep 10,229
The suggestion that engine is "shot" with a suggested $1K diagnostic fee doesn't strengthen one's confidence in the dealer, unless the dealer can explain how the knocking sound has been detected. Did the technician use mechanic's stethoscope? At the very least, you are owed a clear explanation.
Still - disposing of this 4 wheeled asset would be prudent. |
01-13-2019, 02:57 PM | #6 |
Rep 4,841
What do they consider "shot"? Low compression? Bearing material in the oil? Knocking? Piston slap?
You need oil for lubrication, so if it's cylinder wear, it will show up in a compression test. If it's knocking then rod bearings are done. The easiest check would be to send your oil to a place that does oil analysis, and get your cylinders scoped with some pictures. That will paint a decent picture of where the engine truly stands. |
01-13-2019, 03:03 PM | #7 |
Rep 3,674
It doesn't sound like the dealer really did any real tests to prove that the engine was actually shot. If it worries you that much, forget about trying to see if they were right and just ditch the car ASAP. If you want to really get to the bottom of it, go to a good indy that will perform a compression test and send your oil out to Blackstone.
Billfitz8169.50 |
01-13-2019, 05:02 PM | #8 |
Rep 15,962
You probably had a lot more oil than that in it before you stopped. The warning light would have come on with at least 3 quarts of oil still in the pan. I doubt the oil stopped leaking while the car was towed to the dealer, or when waiting for the tow truck, explaining why he only found a quart. If you had done any damage chances are you'd know about it by now, if only by the engine making a lot more noise than it used to. The components that could have been damaged won't silently continue to deteriorate, they'll make a racket.
01-13-2019, 10:56 PM | #9 | |
Rep 22
So yeah analysis that's a good option if I decide to keep it I imagine that's a lot cheaper than opening up the engine to inspect it. Luckily there were no metal shavings in the oil they drained out, but that doesn't mean engine damage didn't occur. |
01-14-2019, 03:15 AM | #10 | |
Rep 15,858
Oil light comes on. Was there a 'low oil' message ahead of this? Oil Level Sensor should have picked up an oil level issue, once the oil was beyond a quart low, (1litre in Europe). If you simply had a leaking sump plug, there should have still been plenty of oil in the engine when you stopped. Did the rest leak out during recovery? Standing at the garage? I'm not convinced you were so low as 1qt of oil when you stopped. I'd change the oil, as others have said, get oil analysed, plus pull the filter and closely examine. Last edited by HighlandPete; 01-14-2019 at 03:30 AM.. |
rjd_F301997.00 |
01-14-2019, 03:16 AM | #11 | |
Rep 15,858
01-14-2019, 06:41 AM | #12 | |
Rep 3,674
01-14-2019, 07:55 AM | #14 |
Rep 227
Drives: 2000 BMW E39 M5
I think that this explanation makes the most sense. Surely there was a block of time between shutting the engine down and when the dealer drained the oil, during which it continued to leak. I'd be willing to bet that while the engine was running there was at least enough oil in the sump for the pump to continue to operate.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
01-14-2019, 08:36 AM | #15 | |
Rep 15,858
Perhaps the OP could add a bit more detail.
Did the sump plug come out while driving, or simply oil leaking out? Were there any oil level warnings? Check Control warnings? If it was simply a low oil warning light, the following should apply. From an F30 Owners' Manual. Quote:
01-14-2019, 12:39 PM | #16 |
Rep 1,503
Agree with others, the dealer’s explanation sounds way too fishy. Your low oil warning would’ve come on much sooner than 0.5 qt remaining. And yet your dealer didn’t diagnose a faulty oil level sensor - and surely you used the sensor right after your oil change to verify the oil level?
And then how can they tell you the engine is “shot” and recommend a 15k replacement but then demand 1k to explain why that repair is needed? Surely those two things are in the wrong order. Anyway, your plan to drive for a while then do an oil analysis is solid. Figure out your next step once you get the analysis back. And get a new dealer. |
rjd_F301997.00 |
01-14-2019, 05:22 PM | #17 | ||
Rep 22
I think it's very possible that it continued to leak a while at the dealer, I'm sure they didn't look at it immediately, I was in that loaner for about 1.5weeks. It is very frustrating, they told me they were putting in a PUMA (warranty) case thru to BMWNA at first, but then they said they didn't send it through. Because they found an aftermarket oil filter and a stripped drain plug. I believe at this point they came up with the 15k quote and set it aside. It's frustrating hearing your engine is "shot" with no explanation or reason. And it's run fine for 2k miles now. But I digress. Attached is the picture they sent of the plug you can see. |
01-14-2019, 09:30 PM | #18 |
Rep 15,962
They're hosing you. Your last trip there should remain your last trip there.
Your oil pan is plastic, as is the plug, which is meant for one time use only. The correct filter comes with a new plug. If the filter you bought didn't come with a plug and you used the old plug that was probably the source of the leak. |
01-14-2019, 09:46 PM | #19 |
Rep 125
Drives: 2013 328I Sportline
Wow. What did you use to tighten that? A breaker bar? I don’t think anything is wrong with your engine especially since you didn’t experience any drivability problems.
01-14-2019, 09:50 PM | #20 | |
Rep 22
01-14-2019, 10:00 PM | #21 |
Rep 22
Just screwed it in by hand, the large disc part broke off, and the o-ring looks misaligned as you can see in the picture.
01-15-2019, 10:12 AM | #22 |
Rep 230
The torque for the plug is 8Nm if I remember correctly. Which is probably 5 lb/f. With standard foot long 3/4 ratchet you get that pressing on handle with 2 fingers. Good indicator - plug is flush with the pan surface. Sorry for you, hope you will get thru this with no loss. Good luck.
