04-26-2020, 10:57 AM | #595 | |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
I was getting the code from cylinder 4, moved that coil to cylinder 3 and now the code has moved to cylinder 3. Replacement coil is on the way. Without any codes, it's a lot harder for you to diagnose.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
04-26-2020, 11:49 AM | #596 | |
Rep 180
Just uploaded a video so you can see how mine is. Here I am holding the rpms around 1,000 so the problem sounds more pronounced on video. |
04-26-2020, 12:02 PM | #597 |
Rep 684
And this is with JB4 completely removed?
What do the misfires under acceleration feel like? Do you feel a stumble?
2020 X3M
04-26-2020, 12:13 PM | #598 | |
Rep 180
Yeah. It just feels like a small hiccup. Again I have only felt it probably twice while actually driving. |
04-26-2020, 12:41 PM | #599 |
Rep 684
I would remove the JB4 and confirm that it's definitely still happening, take a more recent video, and then ask the dealership again to try to get to the bottom of it. Ask to work with the tech to recreate the problem for them if you know it only happens under certain conditions.
2020 X3M
04-26-2020, 01:05 PM | #600 | |
Rep 180
Second video is engine sound. You can hear small knocking sounds very faintly in the background. |
04-26-2020, 01:24 PM | #601 | |
Rep 180
Thanks! |
04-26-2020, 03:39 PM | #602 | |
Rep 684
I've had some various issues come up but as far as I can tell, they're mostly of my own making. This cylinder ignition issue is the only thing that I don't think was due to me doing something dumb. This I will say- with every mod we stray further from God's light lol. The car starts way harder on E85. A full tank of gas is gone in 200 miles. It's no longer the car you bought at the dealership. It's still a daily for me, but it requires a lot more attention. https://giphy.com/gifs/parks-and-rec...-Xj1GHC7mXPquY
2020 X3M
04-26-2020, 04:02 PM | #603 | |
Rep 180
I don't know if you saw what happened to LJ (No Clutch garage) his Big Boost Stage 4 340i blew up due to inefficient fueling. But I mean, we learn with every mistake. Thanks for the feedback and help for my engine issue! Appreciate it big time |
Supr3me552.00 |
05-21-2020, 09:46 AM | #605 |
Rep 201
2016 340i, 40k miles. Was in for a random noise (seat, not mechanical) issue and ended up having valve cover gasket replaced after routine inspection. Supposedly "just" starting to leak. No prior tangible signs that it was an issue however.
Bm3 stg 1 since 37k miles. |
05-21-2020, 03:42 PM | #606 | |
Rep 1,454
Curious to see your work order if you don't mind posting it! How did they find the leak? Thanks. |
les anderson145.50 |
05-21-2020, 04:09 PM | #607 | |
Rep 98
05-22-2020, 01:43 PM | #608 | ||
Rep 201
G.Newt810.00 |
05-25-2020, 06:04 PM | #609 |
Rep 20
This is my 340i made in Rosslyn Power check result by Dynapack shows its max power is 409ps (tcf:1.0)@4th gear. My modification so far: ENGINE: •DME tuned by private tuner in Japan(maybe using ecutech or alientech device) •TCU remapped by D.I.Y :xHP stage3 v1.7 •akrapovic revolution line exhaust and linkpipe with akrapo sports cat. •K&N air filter •OKD ignition coil(multi-spark coil),which is very popular tuning parts in Japan •CSF heat exchanger (v.1) •B58TU HPFP
fake_bimmer
05-27-2020, 04:50 AM | #610 |
Rep 13
Hi Everyone,
last night something happened to my 35.000km M140. I was escaping form an attempted theft (two cars tried to squeeze me but I managed to escape) and I went uphill close to my neighborhood to leave them behind. I lost them after a few turns but I kept pushing for a while to be sure to escape them definitely and gain some time to put the car in the garage when at home. After 60-70 seconds of driving up the hills the car started to heavily whine when I was full gas. I could hear the noise since mid low revs up to high revs. Noise comes from the front (engine bay). I felt no power loss at all. Car is stock with just M Diff. Once at home I couldn't hear the noise anymore and this morning the car felt quite normal. with the dashcam I recorded a couple of video so you can hear the noise. Should I be concerned and go to an appointment with service? Here's the noise: https://youtu.be/dwPe266iXbA https://youtu.be/eiXzWeWsDTg |
05-27-2020, 06:31 AM | #611 | |
Rep 106
What the fu*k is wrong with people. Highjacking cars pure idiots !
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
05-27-2020, 06:34 AM | #612 |
Rep 13
05-27-2020, 07:10 AM | #613 |
Rep 106
M140 with ZF mate
05-27-2020, 08:08 AM | #614 |
Rep 151
That's classic ZF whine. Mine does the same thing at trackdays when car is pushed hard without cooldown laps.
Kirill @ OdinTuned
theone197360.50 |
05-27-2020, 08:15 AM | #615 |
Rep 13
05-27-2020, 03:46 PM | #616 | |
Rep 1,454
Regarding your cold starts: I see you're in a colder climate like me. A lot of the N54/N55 boys here running full E85 needed tuning adjustments to be able to start in the winter. I'm only on E30 and noticed a slightly longer start time, nothing that I'm really concerned with though. I know the HPFP upgrades just became available this spring, so wondering if we'll see complaints come up during late Fall/winter. |
Supr3me552.00 |
b58 |
