03-19-2017, 02:54 AM | #1 |
Rep 1,291
Camber adjustment bushings
Just wanted to share this, I have not tried them but I had never heard of/thought about this sort of solution before; if you're looking for a way to achieve camber correction:
http://www.superpro.com.au/find/supe...999501545/vid-
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
03-19-2017, 10:49 AM | #2 |
Rep 4,515
Lancelot
Have a read of this BB thread http://www.babybmw.net/forum/viewtop...erpro#p1227022 Hoss from Australia on BB has installed these bushes. Powerflex say they are about launch F series bushes too BP |
03-19-2017, 01:15 PM | #3 |
Rep 1,291
Thanks, good to know as powerflex seem easier to source for me.
On a similar topic, do you happen to know if the M4 TS can take the F30 TS bushings? with a hydrolic press we can probably take out my original bushings and fit them on to the M4 TS if the size is the same. I've had a very nice B-road drive today, which reminded me of how much I like my setup now, despite the wheel arch rubbing.
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 03-19-2017 at 01:43 PM.. |
03-21-2017, 02:23 AM | #6 |
Rep 4,515
03-21-2017, 09:16 AM | #7 |
Rep 1,252
Yes with quaife lsd too.
Docrace 6266
03-22-2017, 11:03 AM | #9 | |
Rep 1,291
Would you say they strike as being bright purple or is it rather low key? asking because don't want to raise questions from insurance if I opt for these because not using standard parts.
03-27-2017, 02:47 AM | #10 |
Rep 4,515
OK - and increase on NVH was negligible/noticeable ?
Current '22 X3M LCI.. |
03-27-2017, 07:38 AM | #11 |
Rep 1,252
I already run coilovers Tckline, I didn't feel any increase in noise. stock bushings are just too soft it plays by handforce.
Docrace 6266
04-17-2017, 06:22 PM | #12 |
Rep 888
Can these camber adjustment bushing be done at home? How difficult is the process (besides needing a press)?
I'm trying to decide if these are worth installing while doing Dinan springs on my 340i. |
04-18-2017, 01:09 AM | #13 |
Rep 1,291
Well yes and no... installation you can perhaps do it's only a couple of bolts, but any camber change requires alignment immediately afterwards.
04-18-2017, 12:00 PM | #14 | |
Rep 888
Any feedback from people on here who have them? |
07-19-2019, 03:19 PM | #15 | |
Rep 1
07-19-2019, 10:16 PM | #16 | ||
Rep 1,291
Although looking back at that i'd fit the millway uniball i now have on my tension struts, not the oem bushings!
thisismikeyb114.50 |
07-20-2019, 08:05 AM | #17 | |
Rep 31
I have found that the OEM subframe dampers ( VIBRATION ABSORBER Part Number: 31106861027) for runflats really make a difference to NVH but they are only fitted to cars which leave the factory with runflats. Thanks in advance! |
07-21-2019, 06:00 AM | #18 | ||
Rep 1,291
In fact the only changes that made a real difference in this area were the dampers when i moved to KW DDC, but bushings not really.
