BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 squeak - faulty tensioner/slipping belt
      08-27-2016, 07:17 AM   #67
BeaminBimmer
Drives: BMW X5 M50i
Originally Posted by insanecoder View Post
Just curious but do you guys get that stumble with auto start/stop off?
Never paid attention...
      08-27-2016, 05:34 PM   #68
BeaminBimmer
Drives: BMW X5 M50i
Originally Posted by cfm56d7b View Post
What was the build date of your vehicle?
Good luck. Hope the dealer will find the root cause.
2016-03-21
      08-27-2016, 08:55 PM   #69
arman340
Drives: Alpine White 16' 340i M-Sport
noticed mine has it too, 1st and 2nd gear
      08-28-2016, 02:21 AM   #70
HitmanHearns
Drives: 14' Infiniti Q50 / 16' Audi A4
Mine does it too when I use the paddle
Shifters and shift. Happens during 1-2 and 3-4 at times. It happens when the shift point isn't ideal. Sometimes I feel like it's coming from the wheels/tires. I'm running 403m's.
      08-29-2016, 08:13 AM   #71
BeaminBimmer
Drives: BMW X5 M50i
Originally Posted by Eriphill View Post
I stopped by a dealer today and spoke with the service manager. He said BMW was aware of the issue and was looking into it, but to date no one is sure what is causing the sound. He also mentioned that every one of their 340i demo/loaner's was making the sound. Said if a TSB was released they would call.
which dealer is that?
Current:2021 X5 M50i | 2022 XB7
Old: 2013 335i x-drive |retired 05-2016 ||2014 320i x-drive | retired 03-2018 ||2016 340i x-drive |retired 03-2018 ||2018 X5 |retired 06-2021||2018 430i | retired 10-2021
      08-29-2016, 11:02 AM   #72
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
Weird that I just heard this for the first time last night and happened to see the thread this morning. Very curious to find out what BMW comes up with, but glad it is under formal investigation now. My first thought was that I chirped the tires after slamming into gear.
BTW, 6MT here. Sounds like we're all affected.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      08-29-2016, 09:32 PM   #73
2blu
2blu's Avatar
Drives: 540i XDrive ///M Sport
Another 340 X-Drive 8AT affected here. A/C on from 2-3 and 3-4.
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
      08-30-2016, 12:25 AM   #74
HitmanHearns
I had scheduled an appointment but think I will cancel. Seems like they won't have a solution for the problem yet.
      08-30-2016, 02:15 PM   #75
BeaminBimmer
Drives: BMW X5 M50i
just got my car back... no squeak so far.
after trying a couple of things, they emptied out the freon and put it back at suggested levels or pressure... i don't remember what they said. Apparently it was the only issue they found. everything else seemed great.
So far no squeak. will keep you posted.
      08-30-2016, 03:10 PM   #76
insanecoder
Drives: 340isDrive
low coolant causes this?
      08-30-2016, 03:42 PM   #77
TheObviousChild
323
Yeahhhhh, that makes no sense at all.
      08-30-2016, 05:23 PM   #78
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
Freon is not coolant, it's refrigerant.
      08-30-2016, 06:27 PM   #79
BeaminBimmer
Drives: BMW X5 M50i
Noise is back... Dealership going to wait for TSB
      08-30-2016, 07:15 PM   #80
2blu
2blu's Avatar
My car just did it again, but this time with A/C off. From 1-2 and 2-3.
      08-30-2016, 07:31 PM   #81
insanecoder
Drives: 340isDrive
my bad.. either way thats not the solution
is there an eta on the tsb for this?
      08-31-2016, 12:34 AM   #82
soultraveler00
soultraveler00's Avatar
48
Drives: 2010 Bmw M5
8 speed auto here and i started having this issue around 700 miles. Currently at 3.5k and still happens within first 3 mins of car starting (not warmed up) in 1st and 2nd gear (sport & sport + mode only)
However the other day i was driving for 30+ mins and then decided to go WOT with a/c on and the infamous squeak came back to haunt me.
      08-31-2016, 06:19 AM   #83
BeaminBimmer
Drives: BMW X5 M50i
I had asked them if they can apply more tension on the belt... They said that we have a self adjusting tensioner... Maybe that's the problem.
The solution for the E9X M3's was to change all tensioners and belts and apply the right amount of tension. However, they can't do that with the B58's.
      08-31-2016, 03:04 PM   #84
BeaminBimmer
Drives: BMW X5 M50i
i saw a guy on Bimmerfest who said there was a squeaking noise from his engine... he degreased his belt and the noise went away.... can it be that simple?????
      08-31-2016, 03:22 PM   #85
insanecoder
Drives: 340isDrive
squeaky belts = worn belts
      09-03-2016, 05:51 PM   #86
BeaminBimmer
Drives: BMW X5 M50i
Originally Posted by JayDD007 View Post
I hear the same noise from time to time. Being a BMW tech and never hearing anything like it I assumed it was possibly the serpentine belt slipping a bit from the abrupt change in engine rpm (since the 1st to 2nd change is hardest) but i could be completely wrong there. It is quite an irritating noise though.
Any developments on your end?
      09-04-2016, 05:40 AM   #87
VVlasy
Drives: 2016 440i xDrive GC with MPPSK
Hello,
on friday, on my way to work, I also heard this sound, and assumed it was not my car. Well this confirmed it was my car and is an issue. Please keep this thread up to date on your developments! I was not able to reproduce it again. But as you all mentioned, I had the transmission in the Manual/Sport mode when it happened.
      09-04-2016, 08:44 AM   #88
JayDD007
Drives: BMW's
2020 G07 X7  [0.00]
2013 E70 X5  [0.00]
2003 E46 M3  [0.00]
2013 F10 M5  [0.00]
2009 E90 335ix  [0.00]
2009 E90 M3  [0.00]
I've been keeping an eye out for bulletins with no success yet. I don't think replacing parts with identical ones is going to do much good at this point. I'm sure NA is aware of the issue and is currently working on revised parts. I'll be sure to update if I see or hear anything.
