07-15-2017, 11:49 PM | #1 |
Rep 89
Steering wheel swap Q
I currently have a 2014 335i sport line steering wheel WITHOUT the paddle shifters. Is it a simple plug and play (plus coding, I know) to install a sport line steering wheel WITH paddle shifters? Thanks in advance
07-16-2017, 01:53 PM | #2 |
Rep 53
Yes, almost - in some cases you need to route a new wire from SZL (steering column cluster) to FEM. Some cars that didn't come equipped with the paddle shifters still have the wire already in place (mine had) while some don't. In any case it's pretty easy to do. You'll find out whether you need to route the extra wire if you take out the plastic trim around the steering column (just pull) and look at the connector going in there, if it's missing wire to pin 3 you need to add it.
07-16-2017, 03:27 PM | #3 | |
Rep 89
07-17-2017, 08:54 AM | #4 |
Rep 53
Took a while but I found some images for you, should help:
http://f30.bimmerpost.com/forums/sho...1&postcount=34 Also check out this great guide with detailed instructions: http://www.mediafire.com/file/m33a3n...30+Rev.+3L.pdf You mentioned you have a sports line steering wheel, it's not the M-Sport wheel though? If not, absolutely remove the old steering wheel with this method: |
