10-24-2020, 10:23 AM | #816 | |
Rep 137
Rbrown2765.50 |
10-24-2020, 10:33 AM | #817 | ||
Rep 4,576
Have a look at a wiggle. They have the larger frame size at 59cm. It's a great bike for the money - they are like hen's teeth at the moment. https://www.wiggle.co.uk/cube-sl-road-race-bike-2021 |
GMT23427.50 |
10-24-2020, 02:26 PM | #818 |
Rep 2,048
So for those of you who run winter bikes to protect their shiny summer bikes from a tiny bit of water on the road, I'll raise you this:
You just can't beat a day of sliding around on steep and rooty trails in the mud. Would you believe that the first Karcher I bought was a petrol one and used for washing bikes multiple times a day when I was racing, rather than cleaning cars? This is why I would have gone for a black alcantara interior over the white opal leather I actually have if I'd been in charge of the original BMW order for my car! Oh, and the dig at winter bikes is clearly in jest... |
10-24-2020, 02:45 PM | #819 | |
Rep 1,264
Can I borrow your rear cassette |
10-24-2020, 03:08 PM | #820 |
Rep 2,048
10-24-2020, 03:37 PM | #822 | |
Rep 2,048
My go to for lube is Progold Prolink, partly as my mate sells it in his shop, but also because it's an awesome thin film oil. It needs put on the night before ideally, but it's super thin and helps to disperse water from the links and prevent corrosion. It's good for dripping into pivots, suspension seals (to help lift dirt out) and bushes too as it creeps well. I do use Finish Line XC wet lube though too as I've got a 25 year old gallon jug in the garage that refuses to run out from back when we'd ride as a family. It's a bit sticky and makes the chain a bit black but it's decent enough if it's really muddy. My main one though is preventative, I build everything up with thick marine grease (including popping bearing seals off, rinsing out the thin OEM stuff and then rebuilding with this glue). It's amazing for keeping water out and helping things last longer, although I do also use Hope stuff with stainless bearings which helps too, especially on the wheels where you don't want the friction of the marine stuff. A far cry from when I'd remove seals from bearings to make them spin faster, and just replace them once a month! On the faster alpine race tracks that could make seconds of difference over four minutes, enough to drop you from top ten to top 30/40. Oh, and as for the cassette size...you need it when the bike weighs 38lb! |
JR16641146.50 |
10-25-2020, 02:55 AM | #823 | |
Rep 25,113
My car made front page of Bimmerpost
Ennoch2257.00 |
10-25-2020, 06:36 AM | #824 |
Rep 1,228
I've got oyster leather in mine. Even with the hatch bag there's still bits of leather exposed when the seats are down. Best thing I've bought is a Hippo Mega Bag. Bike goes out and gets covered in crap in Wolburn or Surrey Hills etc, gets put straight in the hippo bag and lobbed in the back of the car, then washed when I get home. £13 from Wickes and far tougher than any expensive bike cover.
10-25-2020, 05:38 PM | #825 | |
Rep 2,048
We had another day out today in the rain. Quite amazing as it was exploring some new trails in the borders which were built in the main by a mate of mine I used to race with and they're proper mental. Some were average 41% gradient, and they're rooty, slimy, rocky and wet as sin. I haven't been that cold and wet in a long time. It was actually a struggle to get enough heat into the brakes and suspension to get them to actually work properly! Some fairly committing low speed 6-7ft drops too. Wild, and just the sort of janky technical stuff I love, and a complete contrast to the popularity of 'flow' trails that seem to be everywhere now. I can see why they were good World Cup training tracks! This is what the day started like, it didn't look like this at the end: As a bike it's pretty old for the amount of abuse it's had, but it's still going strong and I can't find anything I desperately want to change it for. On the steep stuff it's all about angles anyway, rather than suspension, and it's got some offset shock bushes in there to drop the rear end down and slacken the head angle to 63deg. The brakes are 7 years old (rebuilt with new seals during lockdown), the wheels are 8 years old, or at least the hubs are, and the Shimano XT cranks I've had on every bike since 2011! And after the rear Maxle snapped last month I can happily say there now isn't one piece of plasticky SRAM junk on the entire bike. |
11-07-2020, 11:50 AM | #826 |
Rep 3,285
Lovely ride today, quite slippery though. Still cannot quite believe how well these things last. The only other thing in my life from 2011 which gives me so much joy is SWMBO
Spent the afternoon chasing my daughter on her bike, hopefully one day she'll be smashing my segment times on Strava |
11-07-2020, 08:25 PM | #827 |
Rep 1,325
Chaps can anyone recommend a cheap but passable set of lights? Need something bright on the front so I can see where I'm going now the nights are drawing in fast, thanks!
11-08-2020, 03:24 AM | #828 | |
Rep 4,576
https://www.dalescycles.com/cateye-v...able-light-set |
11-08-2020, 03:49 AM | #829 |
Rep 3,285
I've got these on my commuter bike, but on the road bike if its dark enough to need front lights I don't take the road bike. Far too many pot holes, mud, generally unsighted opportunities to knacker a 23mm tyre/wheel.
https://www.amazon.co.uk/OCOOPA-Rech...cycling&sr=1-6 |
11-08-2020, 05:20 AM | #830 | |
Rep 749
Drives: F31 320d xDrive M Sport
I can't recommend any that fulfil both requirements. Maybe others can. I spent £90 on a Moon Meteor Storm Pro and would definitely recommend getting a good high-output light. But they're not necessarily cheap.
JustChris17487.50 |
11-08-2020, 06:53 AM | #831 | |||||
Rep 1,325
11-08-2020, 10:55 AM | #832 | ||
Rep 404
The cateye volt 200 is 200lm so will give you an idea of what to expect, I'd say you'd want 800+ for unlit riding Quote:
How fast you plan on going does factor in e.g. you'll want a longer throw if you plan on going at speed. |
11-08-2020, 01:24 PM | #833 | |
Rep 2,048
200 lumen would be fine for seeing a bit as a get you home in an emergency light, but if you're going to be doing it regularly then 4-500 lumens is probably closer to what you want, albeit beam pattern would also have an effect on this. My choice would be to go for a spread rather than spot if you're only going to have one light. |
11-09-2020, 03:37 AM | #834 |
Rep 669
The halfords advanced 1600 lumen light gets good reviews and is comparable to a lot more expensive front lights.
11-11-2020, 02:44 PM | #835 |
Rep 1,264
Strong southerly today but mild. Managed to get in a 30 mile loop, no dramas as avoided the school run mums.
Changed the diet over the last few months. Cut out peanut butter on toast every lunchtime (since time began) for weetabix but more so the late night choccie fest for some 90 calory choc bar thingy . 5 kilo loss with the usual rides and turbo...diet does it more than anything but I've always over compensated for long rides (reward syndrome) Can't quite bring myself to cut out the ale mind |
11-11-2020, 03:01 PM | #836 | |
Rep 4,576
My body let me down today. Not been stretching enough - piriformis playing up....it's a pain in the butt!!!! |
