06-24-2018, 10:28 PM | #1 |
Rep 63
Amber side markers disable not working
Hi,
I went into FEM BODY and set MAPPING_SIDEMARKER_L_OUTPUT to off MAPPING_SIDEMARKER_R_OUTPUT to off This resulted in the amber side markers off when DRLs are on, but they remain on when low beams are on. In addition, I wanted to code fog lights on w/ DRLS and on automatically w/ low beams. I was able to do this successfully by making the following changes: MAPPING_SIDEMARKER_L_FUNCTION = 03 (Low Beam) MAPPING_SIDEMARKER_L_OUTPUT = 0B (Fog Lamp L) MAPPING_SIDEMARKER_L_PWM_LEVEL_STANDARD = 64 (100%) MAPPING_SIDEMARKER_L_FIXED_PWM = 01 (fixed) MAPPING_SIDEMARKER_L_PRIORITY = 03 (bottom priority) MAPPING_SIDEMARKER_R_FUNCTION = 03 (Low Beam) MAPPING_SIDEMARKER_R_OUTPUT = 0C (Fog Lamp R) MAPPING_SIDEMARKER_R_PWM_LEVEL_STANDARD = 64 (100%) MAPPING_SIDEMARKER_R_FIXED_PWM = 01 (fixed) MAPPING_SIDEMARKER_R_PRIORITY = 03 (bottom priority) The bold must be at that setting in order for the fog light automation to work. With the above settings applied, once again the markers are only off with DRLs. Is there a way to maintain all the functionality I have now, but with amber side markers off in low beam mode? |
