10-04-2016, 01:59 PM | #1 |
Rep 14
Remap on F30 320d Efficient Dynamic
Hi,
Has anyone done a remap on a F30 320d Efficient Dynamic edition? As was doing some research and stumbled on this website: Celtic Tuning - they say this: The BMW 3 Series (F3x) 2012> takes the power from 163bhp up to 238bhp and the torque from 280lb/ft up to 326lb/ft. This stage of software is designed as a software upgrade only meaning it is all within safe tolerances of the engine and drivetrain and requires no hardware modifications. With our diesel upgrades you can expect to see upwards of 10% fuel saving dependent on driving style. And quoting £360 Worth it or Not? Thanks |
10-06-2016, 10:40 PM | #3 |
Curmudgeon and Pedant
690
Rep 3,489
Not a lot of people here in the States doing remaps (all our cars have DEF/SCR systems and it's a bit more complicated.)
Racelogic and Ecotune are notable tuners that I've seen, and a few reviews. |
12-04-2016, 10:33 AM | #5 |
Noob
Rep 13
for UK there's a guy called simon whom remaps bmws. I've looked him up and had a chat with him, as I was also under the impression that the 163 and 184 versions of the N47 in the 320D are the same engine, just less fuel injection in the upper range of RPM (same torque). he confirmed the same as did TC-performance, that the engines are identical.
So technically you could take both engines to 210bhp and around 450Nm. Just double check that the cooling is identical if you plan to put it on the racetrack and that the gearbox/clutch can handle that torque (gearboxes are different). |
04-02-2018, 04:04 PM | #6 | |
Rep 147
