06-17-2016, 01:31 AM | #1 |
Rep 372
wheel and tire help :)
finally locked my eyes on XO Verona 20'' wheels. its kinda a replica of the vorsteiner v103 but cheaper... so i have 335i xdrive on stock suspension. wondering what set up i should get without rubbing. 8.5vs9 Front, and 8.5vs9vs10 Rear. what about tires? im just looking for cheap tires.. below 200 each would be great.
thanks |
06-17-2016, 09:59 AM | #2 |
Rep 10,256
The tires on xDrive models should have the same circumference. There are several threads on this topic in the forum. If you have questions, the team at TireRack is always helpful.
The base suspension on your xDrive vehicle may not tolerate 20 inch wheels well, especially if the new wheels are substantially heavier than the current ones. Compare the weight before purchasing. |
06-17-2016, 11:43 AM | #3 | |
Rep 372
06-17-2016, 11:58 AM | #4 |
Rep 10,256
BMW offers staggered wheel configuration on xDrive models. My vehicle is 2013 BMW 335i xDrive sedan ordered with 19" 401 Style wheels and staggered tires. The key is maintaining the same circumference on front and rear tires from day one.
06-17-2016, 12:02 PM | #5 |
Rep 372
How to maintain them when the width is different???
06-17-2016, 12:13 PM | #6 |
Rep 617
You can use tire calculators to determine the overall diameter of your wheel and tire. Please see link below. http://www.wheel-size.com/calc/?whee...cl=50mm&sr=0mm 245/30/19 and 295/25/20 for 8.5 and 10-10.5 wide setup has less than a 1% difference in overall diameter. 2058mm for fronts, and 2059mm for rears. ***Typo Correction - 245/30/20 ***Summer Clearance Sale*** Sales @ UPWheels.com * Ph. 657.888.4UPW * FacebookDOTcom/UPWheels Last edited by UPWheels; 06-17-2016 at 02:18 PM.. |
06-17-2016, 12:29 PM | #8 | |
Rep 372
06-17-2016, 12:34 PM | #9 |
Rep 617
06-17-2016, 01:02 PM | #10 |
Rep 372
06-17-2016, 01:06 PM | #11 | |
Rep 5,140
Staggered diameters front to rear isn't common, even though it's possible. 245/30-20 and 285/25-20 has matched diameters, 255/30-20 and 295/25-20 match as well. However those sizes are a bit wide for F30. I would recommend a square setup: 8.5x20, 245/35-20 |
